New Honda portables
Aurelia
City/Region: Gig Harbor
Photos: Aurelia
PostPosted: Wed Sep 28, 2016 7:21 pm    Post subject: New Honda portables Reply with quote
They finally updated the 4-5-6HP units
http://hondanews.com/honda-marine/releases/honda-marine-debuts-new-bf4-bf5-and-bf6-4-stroke-engines
Tech Specs
http://hondanews.com/honda-marine/releases/honda-marine-bf4-bf5-and-bf6-portable-engines-technical-specifications
Still 60lbs each
Greg
Greg, Cindie & Aven
Gig Harbor
Ari - 19 Cruiser sold 2023
PostPosted: Wed Sep 28, 2016 10:06 pm    Post subject: Reply with quote
Didn't see any mention of the centrifugal clutch system in the discussions of the new Honda 4, 5, & 6.
Still there?
Some folks don't like the system because the motor must be reved up to engage the prop, eliminating the slowest maneuvering speeds possible.
This is also an issue because there's no F-N-R gearshift available, either.
Thus you're left with a neutral or medium forward speed choice. (Swivel for reverse.)
Aurelia
Photos: Aurelia
PostPosted: Thu Sep 29, 2016 10:04 am    Post subject: Reply with quote
The new models have F-N-R gears and you are thinking of the little 2-2.3hp unit with that simple clutch system.
Greg
PostPosted: Thu Sep 29, 2016 12:22 pm    Post subject: Reply with quote
Thanks, Greg!
Wefings
Dealer
City/Region: Panhandle
Photos: Cruise Ship #4
PostPosted: Fri Sep 30, 2016 10:03 am    Post subject: Reply with quote
Just saw them at regional Honda dealer meeting at Lake Lanier , Ga. The big change is compression release for easy starting and a fuel selector [on 5 and 6] so you can use external or internal tank . Also biggest internal tank 1.5L in class . As the Honda folks say "for longer journeys"
No 25" models .
Marc
Wefings Marine Website
Since 1909
PostPosted: Fri Sep 30, 2016 12:45 pm    Post subject: Reply with quote
I have that fuel selector (internal tank or external tank) on my Merc 5hp. I think it's a great feature. I can keep the internal tank fuel of known good fuel, and separated from the main system - no hose - but then hook it up as/when needed. I'd look for that on any kicker now, if buying a new one.
Page generation time: 0.0979s (PHP: 57% - SQL: 43%) - SQL queries: 23 - GZIP disabled - Debug on
