CD 16 core in sump?
marco422
City/Region: Salt Spring Island
Vessel Name: Gaiasika
Photos: Gaiasika
PostPosted: Sat Sep 10, 2016 1:07 am    Post subject: CD 16 core in sump? Reply with quote
I am sure this question has been asked, but I couldn't find the answer with a search:
I have a 2006 16 Cruiser and want to install a Airmar P79 thru-hull transducer. Is the sump (depression) under the bilge pump cored or is it solid? Thanks for any help...
MikeR
City/Region: Mill Creek
C-Dory Year: 2016
Photos: MikeR
PostPosted: Sat Sep 10, 2016 9:51 am    Post subject: Reply with quote
There is balsa core in the sump area, it is just thinner balsa. The previous owner of my boat also installed a through-hull in the sump area and failed to seal it properly, and I ended up replacing a 2' x 4' section of the core, from the transom forward.
With that said, it should be a good area for installing your through-hull. After drilling the hole, you want to remove the balsa around perimeter of the hole and fill it back in with thickend epoxy. That will completely isolate the remaining balsa core and prevent water intrusion. The previous owner of my boat simply used bathtub caulk.
-Mike
22' C-Dory Cruiser (2016)
16' C-Dory Angler (1989)
10' C-Dory Row Boat (1995)
marco422
Photos: Gaiasika
PostPosted: Sun Sep 11, 2016 12:49 pm    Post subject: Reply with quote
Thanks.
Page generation time: 0.0215s (PHP: 58% - SQL: 42%) - SQL queries: 16 - GZIP disabled - Debug on
