Tomcat door lockset
Alang
City/Region: bradenton
PostPosted: Fri Jul 22, 2016 1:24 pm    Post subject: Tomcat door lockset Reply with quote
Does anyone know what model TrioVing lock set the C Dory Tomcat 255 uses. Mine has frozen due to salt nd needs to be replaced. Thank you!
PostPosted: Sat Jul 23, 2016 12:51 am    Post subject: Reply with quote
I don't remember which lock my Tom Cat had, but many of the C dory do have the mobella Soutco lock.
http://www.uglyfishinc.com/southco-mobella-offshore-entry-door-latch-p/me-03-xxx-x0.htm
kevin ware
City/Region: Mount Vernon
Vessel Name: El Gato Thomas
PostPosted: Sat Jul 23, 2016 1:05 am    Post subject: TC door lock Reply with quote
You might check with the door and window supplier. Their name is on a sticker on the window and door, and as I recall their business is located in Vancouver, Canada.
I had a window lock fail a couple of years ago, called them and found they had all the locks in stock and readily available, even down to the color. Cost was quite reasonable.
I think they also sent me a couple replacements using the 'trust' method, that is, I would send them a check after the parts arrived. Nice.
redbaronace
City/Region: Puget Sound
Vessel Name: Tomcat
Photos: redbaronace (Name TBD)
PostPosted: Sat Jul 23, 2016 3:00 am    Post subject: Reply with quote
The windows are diamond seaglaze I believe. Not sure about the door, but they might be a good first try. Also, the factory might have some answers.
Alang
PostPosted: Sat Jul 23, 2016 10:43 am    Post subject: Reply with quote
Thanks everyone. From the Diamond Sea Glaze site the parts store advantecstore.com looks like they have what I need. I will call to make sure before ordering.
http://www.advantecstore.com/locksets/trioving/5312-8/escuthcheonset/dsg/TrioVing_5312/8_Escutcheon_Lock_Set_Select_Finish_Hand_Diamond_Sea_Glaze_Kit_13407.html
Page generation time: 0.0797s (PHP: 24% - SQL: 76%) - SQL queries: 18 - GZIP disabled - Debug on
