Comprop-Limited lifetime warranty?
Chica
City/Region: Butte
State or Province: MT
Vessel Name: Chica
PostPosted: Fri Sep 23, 2005 11:18 pm    Post subject: Comprop-Limited lifetime warranty? Reply with quote
On the third day of use my motor started to vibrate, stopping and raising the motor showed one of the blades had broken in the middle. I was two miles off shore, but was lucky to have a trolling motor and the original aluminum prop. Found an island with a sandy beach and replaced the damaged prop. Having not hit any thing, and inspection showed on marks on the other blades, I returned the prop. I received a form letter telling me that the other blades showed "scratches and marks". The are correct in that I did pick up some eel grass, but struck nothing more rigid. My last Comprop. The point of this note is to remind boaters' to have a good quality spare prop, and remind myself of what all are parents have told us, "You get what you pay for".
Chica
Jon - CLou
C-Dory Year: 1986
Vessel Name: C-Lou
Photos: C-Lou and Pee Wee
PostPosted: Sat Sep 24, 2005 12:49 am    Post subject: Reply with quote
Chica, I posted the same problem a few days ago on a different thread. This is really interesting because after inspecting both of my props, I think it's a stress break that's causing it to fail. I ordered another and installed it today. I also sent the broken one back to Comprop and I should know something in about a week.
I'll try one more time and then try something else if it fails again. It's to bad because I really like how the boat performs with this prop.
If anyone is using this prop, check for stress cracks because I think sooner than later it's going to happen. The last two props I used have lasted approximately 1 1/2 years each.
PostPosted: Sat Sep 24, 2005 12:55 am    Post subject: Reply with quote
Jon - I would make you one out of that plastic Permadork material, but they won't let us have stuff from work anymore. Now, if you get twins with little props, I can get 'em in my lunchbox.
Speaking of Permadorks - you still got that thing? If you do, please bring it to Sequim. I might break down and try it on my barge.
It might be the hard water up there that breaks them props. I lost one whole blade off an aluminum after Blakely last year, and I am sure I didn't hit a thing.
Jon - CLou
C-Dory Year: 1986
Vessel Name: C-Lou
PostPosted: Sat Sep 24, 2005 9:39 am    Post subject: Reply with quote
I have the permadork sitting by the boat shed. I'll put it in the truck this morning so I don't forget. That thing you made is something else, it convinced me to spend $100 bucks on the factory Peratrim and I'm very glad I did.
Jon - CLou
C-Dory Year: 1986
Vessel Name: C-Lou
PostPosted: Fri Oct 07, 2005 11:12 am    Post subject: Reply with quote
I spoke with Comprop this morning about the broken prop I sent back to them. They inspected it and sent me a new one at no charge. I asked if they had an explanation for the failure. She told me once in a while they get a bad batch (composite cure,voids, etc.) but assured me that the return rate is very low. Time will tell. Rolling Eyes
PostPosted: Fri Oct 07, 2005 2:57 pm    Post subject: Reply with quote
Jon-
Are you using a 15 or a 17 inch pitch Comprop? What's your max RPM and MPH ? Thanks, Joe.
Jon - CLou
C-Dory Year: 1986
Vessel Name: C-Lou
PostPosted: Fri Oct 07, 2005 3:50 pm    Post subject: Reply with quote
Joe,
The prop is a 15 pitch 4 blade prop and I can turn 5500 rpm at 30 mph.
PostPosted: Fri Oct 07, 2005 4:03 pm    Post subject: Reply with quote
Jon-
Thanks. Those numbers are about ideal, and the speed very near the max most of us seem to be able to get out of a 90 hp engine. Joe.
Page generation time: 0.0289s (PHP: 65% - SQL: 35%) - SQL queries: 21 - GZIP disabled - Debug on
