nmitch2859
Joined: 28 Apr 2013 Posts: 71 City/Region: virginiabeach
Vessel Name: Delfin
Photos: Delfin
Posted: Tue Jul 12, 2016 5:49 pm Post subject: Honda 150 Trim Gauge |
I have a Honda 150 on a 25ft Cruiser. The trim gauge does not work. I did replace the helm gauge. Still not working. I traced it to the part on the motor. Has any one had any problems with it. And how hard is it to change out. Thanks Neal _________________ Neal J |
MikeR
Joined: 21 Apr 2013 Posts: 475 City/Region: Mill Creek
C-Dory Year: 2016
Photos: MikeR
Posted: Tue Jul 12, 2016 7:40 pm Post subject: |
Can't speak to the Honda 150 or answer your specific question, but do empathize as I've not have not had good luck with trim gauges in general - A 2003 Honda, 2006 Evinrude, and 2014 Tohatsu, all purchased new, and all with trim gauges that worked marginally within the first year or two, due to the little plastic indicator tab that gets stuck or out of alignment in the trim/tilt mechanism.
The best "trim gauge" for me is to look back and see how far the outboard moves when pushing the button one way or the other, while watching your RPMs, GPS speed and boat handling characteristics (i.e. no porpoising). Even when it works I typically ignore the trim gauge. Take it out and put in a volt meter or fuel gauge instead! (haha, just kidding, those are others I never seem to find much faith in).
-Mike |
Posted: Tue Jul 12, 2016 7:41 pm Post subject: |
It's a rotary resistor. Journey On's is always quitting. I just bump it and hose it down.
Should be easy to replace, but try above first.
Boris |
Dreamer
Joined: 01 Jan 2006 Posts: 1764 City/Region: Really Sunny SaddleBrooke
Photos: Dreamer
Posted: Wed Jul 13, 2016 10:26 am Post subject: |
I had to replace that part on the Port engine. It's not too hard. Small hands are helpful. _________________ Roger
Dreamer- Sold 25 Feb. 2013 |
gulfcoast john
Joined: 14 Dec 2012 Posts: 992 City/Region: PENSACOLA
C-Dory Year: 2010
Vessel Name: Cat O' Mine
Photos: CAT O' MINE
Posted: Wed Jul 13, 2016 6:40 pm Post subject: trim sender |
Neal,
Since you've found the trim sensor on the motor, you'll see it's a lever-actuated resistor like Boris noted. If you have a 'full up' or 'full down' indication, or in between if the mount has slipped, rather than a blank gauge, dried salt and sea crud gum them up. At this point you have nothing to lose by prying at the sensor lever with a screwdriver and 'working' the lever up and down after removing it's mount and spraying it with Boeshield or your fav water-displacing lube. Mine both got stuck in 2014 and both are still working great.
If you have a blank new gauge, the sensor wires are the most likely culprits and replacement will fix. They all have a 1 year warranty because they all tend to last 365.01 days before failure, agree with Mike there and that it can all be done by 'feel' if that's your style. As my pilot buds like to say, 'To Hell with the Force, Luke...believe your instruments!"
Good luck,
2010 Tom Cat 255, Cat O' Mine
Yamaha F150, LXF150 |
nmitch2859
Vessel Name: Delfin
Photos: Delfin
Posted: Thu Jul 14, 2016 6:09 am Post subject: |
Thank You for the responses, I will just replace the trim sensor. I had already tried everything. |
