gulfcoast john
Joined: 14 Dec 2012 Posts: 989 City/Region: PENSACOLA
C-Dory Year: 2010
Vessel Name: Cat O' Mine
Photos: CAT O' MINE
Posted: Sat May 12, 2018 9:54 pm Post subject: |
Yesterday we puttered over to Ft McCree cove, hiked the deserted gulf-front beach for 2.5 hours, only 88 degrees and sunny, water up to 79 degrees.
Any CD-16 could have circumnavigaed the key between 7am and 11am via the Gulf; just look for predicted AM gentle (5-10K) winds from the North then.
Wet and dry storage slip (with water and power) is only 6 minutes from home.
Pretty good NAS PNS base security, with guys and gals who have Glocks on their hips and M-16's and tactical shotguns in the trunk, plus the training on how to best use them.
Life is Good.
Best to All,
2010 Tom Cat 255, Cat O' Mine
Yamaha F150, LXF150 |
Ordutch1975
Vessel Name: Boatless :-(
Photos: PennyBridge
Posted: Mon May 14, 2018 1:02 am Post subject: |
Built curtains for her. Good fun - proud of my wife - she did a great job with them! _________________ "And it is an interesting biological fact that all of us have, in our veins the exact same percentage of salt in our blood that exists in the ocean, and, therefore, we have salt in our blood, in our sweat, in our tears. We are tied to the ocean. And when we go back to the sea, whether it is to sail or to watch it, we are going back from whence we came. " -JFK |
Posted: Mon May 14, 2018 4:20 pm Post subject: |
While John and Eileen were playing, I have been working my tail off. Two C Dorys to clean and get ready...The "new" 25 needed a complete all out turn on the hose cleaning, with a lot of scrubbing. Admiral Marie cleaned all of the upholstery!
I have installed a second RayMarine MFD, glued the Starboard block to the transom. Pleasantly surprised to find that some previous owner had put epoxy plugs into the transom for the single transducer which is present. A second transducer will be installed into the Starboard Block. This time, I used a Fein tool 3/4" wide saw blade to make "Key" under cuts, about 1/4" wide and over 1/4" deep. The side cuts are angled out at 45* in both directions so there is a large surface which will allow the G Flex epoxy to give great adhesion to the transom.
There were also several pieces of teak "glued" to the galley counter with 5200. I used DeBond, and 7 strand leader (as a saw, with sinkers on both ends, to cut the 5200. Galley counter polished up like new. We are a two induction stove galley now. (Back up is a propane in the cockpit)
The "old" boat C Dory 22--with two bids on it--is also getting a spiffing up, so the new owner will not have to clean. Same thing--all out, scrub with cleaning solution and scrub brush. Then hose out, and mop dry.
The afternoon thunderstorms have cooled things off. But the Air temp inside the boats gets up over 100* as the day wears on. Our pool is also 79*, and feels great after the exertion of cleaning. Not the most fun stuff, but anything to do with C Dorys is a pleasure. _________________ Bob Austin
Joined: 27 Oct 2012 Posts: 3372 City/Region: SW Michigan
Posted: Sun May 20, 2018 12:03 pm Post subject: |
Put in Ikea floor in cockpit. The material is Ikea Runnen wood decking. https://www.ikea.com/us/en/catalog/products/90234226/
The tiles are wood slats on a plastic carrier. The carrier has little legs so it the tiles stand off the cockpit floor a la Dri-Deck tiles. This lets water run under the tiles to the cockpit sump.
The notes with the decking says that if they wear or age you can revarnish them. Since these tiles are going to be fairly exposed, I varnished them up front before I put them in. Out of the box, the wood is stained, but does not appear to be sealed, so preemptive varnish is probably a good idea. The tiles are easy to trim using a bandsaw.
It took about 3.5 packs of the tiles and about 2/3 of a quart of varnish. All in it is about US$150.
We'll see how well the hold up. But it certainly looks better than the black utility mats we were using before.
gulfcoast john
C-Dory Year: 2010
Photos: CAT O' MINE
Posted: Sat May 26, 2018 9:04 pm Post subject: |
SoBelle, looks great!
Replaced all 5 Chinese trailer tires at 48 months from date of mfg with
Goodyear Endurance ST 235/80/16R Load Range E (12,000# total) Made in USA trailer tires for just under a Boat Unit. Eileen is much happier (since it took the two of us to man-handle the spare during our 3 blow-outs (more like 'exploding trailer tires'
experiences on I-10 and one nail puncture (saved by the TST alarms).
Installed a new 6-tire TST system (over 7 years old, expect sensor batteries to last 5 years) $279 all included.
Next up, replace the EOH trailer back-up breakaway battery at 4 years from mfg in (you guessed it) China.
Double tied all lines, and checked bilge pumps for TS Alberto (we like Rule Gold with 5 year no-hassle warranty for 20% more).
Gears up for our Chesapeake Adventure in 5 days!
Happy Boating!
John |
Capn Jack
Joined: 01 Oct 2007 Posts: 525 City/Region: La Conner
C-Dory Year: 1988
Vessel Name: Pocket Yacht
Photos: Pocket Yacht
Posted: Mon May 28, 2018 1:40 pm Post subject: Pocket Yacht clean up |
I hauled out the Pocket Yacht, brought her into the yard and gave her a through pressure washing, inside and out. Laid the canvas out on a tarp in the driveway and gave it a through scrubbing, then I steel wooled the grunge line on the hull and finally pushed her off to the side for further mechanical maint. After that, I went in and sat down with 3 fingers of Scotch feeling everyone of my 78 years. |
Posted: Mon May 28, 2018 2:32 pm Post subject: Re: Pocket Yacht clean up |
Capn Jack wrote: | then I steel wooled the grunge line on the hull and finally pushed her off to the side for further mechanical maint.. :smilep |
I am wondering why you used steel wool? There are a number of products which will remove the material, and avoid leaving potential rust stains on the hull? There is bronze wool if you have to use something that abrasive. But in most cases the nylon pads in various grits do the job, and are much easier on the hull. |
Capn Jack
C-Dory Year: 1988
Posted: Mon May 28, 2018 2:53 pm Post subject: Steel wool on the sides of the hull |
It was what I had. Besides that, it rinses right off of the side of the hull and I wasn't in a frame to: "Pick the fly poop out of the pepper." |
Pacificcoast101
Vessel Name: No Pressure
Photos: No Pressure
Capn Jack
C-Dory Year: 1988
Posted: Thu May 31, 2018 12:03 am Post subject: Motor Maint. |
Yesterday, (With great effort)
I lifted the 6 hp Evinrude off of Pocket Yacht's transom and took it into my garage for some much needed work. I hadn't used it in two years, other than to see if it would run and the tilt pivot was frozen up.
After several hours of heat and penetrating fluids I was able to free it up. I then added a couple of more grease fittings to strategic places and re installed the motor. |
Capn Jack
C-Dory Year: 1988
Duplicate...Sorry
Wandering Sagebrush
Joined: 21 Jan 2005 Posts: 2770 City/Region: Northeast Oregon
Vessel Name: Constant Craving
Photos: Constant Craving
Posted: Thu Aug 30, 2018 6:22 pm Post subject: |
I finally got tired of not hearing radio transmissions, and installed an external VHF speaker today. Neither radio had a jack, so I had to hardwire it in.
The trailer got four new ST 205/75 R14 Goodyear Endurance (Made in USA) load range D tires this morning. Max pressure 65 PSI, for a load of 2040 pounds per tire. _________________ "And in the end, it's not the years in your life that count. It's the life in your years." - Abraham Lincoln |
Posted: Thu Aug 30, 2018 7:54 pm Post subject: |
I spent my 82 birthday in the trailer shop--getting to the point of letting someone who knows what they are dong do the work....Oh yes?? Last night the shop called and said the installation of electric over hydraulic was done...I had wanted to use the build in brake controller on our Yukon XL. Well, they worked for 2 more hours and could not get it to work. Something about not enough voltage.
So, I did a little research--and found that there was a relay for the 40 amp 12 volt controlling circuit--and if that relay was not hooked up, or working--no power to the trailer brakes. The trailer shop didn't know that--so this morning they found the relay, wired all properly.
We took the boat to the ramp--I had lowered the target bunks, and put slicks on them, as well the first 4 feet of the main bunks--with a little liquid rollers. This time I backed the trailer right along side the pier, we walked the boat to where the bow was starting on the target bunks, and then I attached the strap, and winched her right up all of the way--no more power loading!!!
To top the day off, I scraped 2" of small muscles (invasive species???) off the two depth sounder transducers (gong to paint them with anti fouling tomorrow!, and pressure washed the lower hull and bottom--Tomorrow I will "Rejex" The rest of the hull--the cabin is already done, and we will finish loading for the River Adventures of 2018!
How blessed we are! I am feeling better than I have in many years, I have a wonderful soulmate of over 40 years and a faithful poodle--plus many wonderful friends--including the C brats! Thank you all! |
Posted: Thu Aug 30, 2018 8:01 pm Post subject: |
Finally got a new smartcraft gauge in Midnight Flyer. My Tach was on the fritz, and I've been thinking for several years to find a way to hook up my Mercury 115hp EFI 4-Stroke to work on my Garmin GPSMAP 840 Guage page. Gave up on that idea when I found a better priced SC1000 gauge. Removed the old tach, made a spacer, and placed the new gauge in that spot. Now I can see digital readings of my RPMs, Fuel flow and fuel used, along with a few other specs in the same place. The harness that comes with the new gauge is only 3 feet long, so I had to order a longer harness to reach from the engine. Even it wasn't long enough, but I was able to splice two harnesses together. All works great, at least on the muffs. We'll see how it works on the water next week at Alton.
Also replaced two of the trailer tires (on one axle, the other is still good for another year). Stayed with the Carlisles (Radial Trail HT)as they have worked well for me.
Also replaced all 4 tires on my F150 tow vehicle. Stayed with the Goodyear Wrangler Fortitude HT's, as they too have been working well.
Lastly, I noticed my electric brakes brake away battery was not charging during my last tow. Remembering I had pinched the tow harness a while back moving the boat & trailer with my little tractor, I untaped the harness and found a broken wire. Fixed that, retaped, and back in business. Colby |
Posted: Sat Sep 29, 2018 11:55 pm Post subject: |
Another great summer traveling on the boat. Tonight as I sit here at a cute little campground on my way home from my last boating trip of the season, I did some figuring. Since March of this year I have put 15,000 miles on the boat trailer! Since May 10th I’ve only been home about 4 weeks all summer! (Usually only a few days to a week at a time!) That’s 31000 miles with the boat in the last two years! Colby |
