Posted: Sun Apr 23, 2017 9:42 pm Post subject: |
Finally got Midnight Flyer cleaned up from the last month of traveling, and covered back up as it'll probably be a week or two before I have her out again. Today I also built an insert to put in the counter top where I pulled the original KISS stove out. (We had another issue with it early in our travels last month, so rather than messing with it anymore, I pulled it, and just bought a Coleman single burner portable butane stove, that worked great for the rest of the travel!) The insert is just another small section of counter top that I put some L shaped aluminum around, then siliconed into the cutout. Not perfect, but does the job.
Also, still having a small water leak issue somewhere when towing the boat in really heavy rain. I think I've narrowed it down to the center window, so will pull that later this week and reseal it.
Next trip will be in May down to Greers Ferry Lake in Arkansas. Colby |
ghone
C-Dory Year: 2011
Vessel Name: Kerri On
Photos: Kerri On
Posted: Wed Apr 26, 2017 2:04 pm Post subject: |
Just in from two weeks of live aboard Spring trials. All running great except a tiny leak still from original Seastar steering ram. It has always seeped a little. I've carried New seals aboard and this morning put them on. Pretty easy job. A bit of new oil and a bit of a bleed. Nice form helm. No leaks! The original seals have a hard plastic flat seal on the flange. The new ones a soft oring
I take it they had an issue with leaks.
Also touched up bottom paint. All set |
Posted: Thu Apr 27, 2017 1:33 am Post subject: |
Hi George, Great to see you on the site. Be even better if I can see you on the water, I need some more good C-Dory photo and video ops. Sure hope we can connect somewhere down the line this summer.
I just put SleepyC to bed for a while. Have to do some other stuff for a bit so my boating is going to be vicariously for a while. Sure a good thing C-BRATS is available. Will be watching here.
SleepyC
Posted: Mon May 08, 2017 7:43 pm Post subject: |
Went out to pump new grease into the hubs. Nope. The blue marine grease (Sta-Lube brand) had hardened so much the gun could not pump any of it. So, I spent over an hour and 3/4 a roll of paper towels dismantling and cleaning the entire thing. _________________ "We can go over there...behind the 'little one'....."
Posted: Tue May 09, 2017 10:53 pm Post subject: |
Sorry Mark. Bummer. Now all better though
SleepyC |
Posted: Wed May 10, 2017 11:10 am Post subject: |
Thank, Harvey. Should work as good as new now...but what a messy, messy job. |
Aurelia
Photos: Aurelia
Posted: Wed May 10, 2017 11:23 pm Post subject: |
Recently installed one of these chargers in the stern connected the Start battery (combiner to house) to support running the 12v Freezer for short periods when plugged in a home. It seems to be working well, and has enough juice to support our ice habit when pre-freezing bottles in the boat so they are ready for action WITHOUT carrying that load to and from the home after pre-freezing in the house. IT replaced a smaller unit that was working well until we added the freezer and got greedier with power wanting to run the freezer from it at times.
On more streamlining move toward easier boat use.
https://no.co/gen1
Gig Harbor
Ari - 19 Cruiser sold 2023
SENSEI
Joined: 01 Nov 2003 Posts: 1067 City/Region: Stanwood
Vessel Name: SENSEI
Photos: SENSEI and SERENITY
Posted: Sat May 13, 2017 2:32 am Post subject: |
Today we wired in a dedicated power supply to the electric pot puller.
After blowing the 25 amp fuse in the downrigger power supply we went with 10-2 wire with an inline 40 amp fuse.
We also installed a sliding seat mount to raise the seat and be able to move the seat back far enough to be comfortable.
I am hoping that the last project we accomplished was to mount a wall mount plastic hose reel to one of the side mount scotty downrigger mounts.
I will try the reel out Wed. When we go out for the second day of shrimping off Camano Island _________________ Roger on the "SENSEI"
1993 22 Cruiser (sold 2014)
1983 22 Classic (sold 2017) |
Posted: Tue Sep 05, 2017 12:04 am Post subject: |
Finally got my new bimini and camper enclosure. Just a few photos, however more can be seen in my photo album under the nested "New Bimini" album.
Colby
anchorout
Joined: 03 Jul 2013 Posts: 357 City/Region: Lake Charles
State or Province: LA
Vessel Name: EZ DUZIT
Photos: EZ DUZIT
Posted: Tue Sep 05, 2017 10:32 pm Post subject: water tank |
Having removed the water tank to make room for the new AC, I had mounted a bladder tank under the fwd-port settee. I have never been satisfied with the outcome. Today I realized the original 20 gallon tank would fit in this space, if I mounted it on a shelf. 20 gallons of water weighs 160 lbs, so the shelf is 3/4" ply on aluminum angle brackets. I plumbed it to the original fixtures. This moved the weight forward and I didn't have to fabricate a tank. _________________ I DON'T KNOW WHAT I'M LOOKING FOR - That's what makes the search so exciting! |
chromer
Joined: 27 Jan 2006 Posts: 952 City/Region: Anacortes
C-Dory Model: 19 Angler
Photos: Checkpoint II
Posted: Mon Apr 09, 2018 6:19 pm Post subject: |
Took "Starcraft Tom" fishing up north of A-town this morning. Tom hooked into a nice salmon. Too bad he didnt land it. In all honesty, it may have been a big Fraser fish that would have to go back anyway. _________________
Checkpoint II (SOLD 10/2020)
Alure Bertram 28 |
SENSEI
Vessel Name: SENSEI
Posted: Tue Apr 10, 2018 4:34 am Post subject: |
when I bought the new to me Sensei it was originally a Nevada boat and trailer. the trailer is a Pacific tandem axle drum brake on only one axle. In WA state we are required to have brakes on both axles so we just finished changing it all out to new disc brakes both axles.
I called Pacific trailer and told them my predicament and they sent me about 4 boxes full of new parts that fit the trailer perfectly . The cost was about a $1000.00 with shipping so it was worth fixing instead of buying a new trailer.
Maybe in a few years when I am ready to hit the road on a quest to visit as many C-Brat gatherings as I can , I will purchase a new aluminum trailer for the journey. |
srbaum
Joined: 30 Aug 2010 Posts: 875 City/Region: Portsmouth
Vessel Name: Osprey
Photos: Osprey
Posted: Tue Apr 10, 2018 8:16 pm Post subject: |
Well, pulled the C-Dory yesterday from the boat lift to the trailer, to conduct proper maintenance. I did push the hours a bit this past year and usually do the 100 hr service about twice a year. Now that the kids have moved away (one in TX and one in Spain), my routine is slipping with all the travel to see the grandkids.
Planed to wash, wax, change steering ram seals, engine oil, plugs, lower unit oil and water pump. Finished the top-end of the engine, steering ram seals and drained the lower unit oil. Something the color of cream came out. Now my work has slowed as I have ordered seal, gaskets, etc and have to wait a week to get them.
The problem is that I will be in Spain next week, so work will come to a halt and no C-Dory use for the rest of this weeks. Bummer! _________________ Steve Baum
Homeport of Portsmouth, VA
Posted: Sun May 06, 2018 5:29 pm Post subject: |
Always have wanted to remove the gold pin-striping on Au'Kai. Everything on the boat is black, gray or white. Why GOLD?
I know it's just cosmetic, but I just didn't like it. Yesterday, I took advantage of a rare day off work and attacked the hull to start, as I do not intend to replace it on the hull. I will remove the two on the cabin top later and replace them with a gray pinstripe. Yes, I know...a lot of work for something trivial. But the boat required a good cleaning/buffing anyway, so two birds and all...
I used a 3M pinstripe removal wheel on my 18v rechargeable drill. Worked pretty well and did not burn the gel coat. The yellowing of the white gel coat was quite noticeable, once the pinstripe was gone. So I followed up with some 3M "Finesse" compound followed by Colonite fiberglass cleaner and finally Colonite Fleetwax. All with a random orbital polisher from Griot's Garage and lots of elbow grease. Starboard side is done. Looks good. I'm gonna do the entire boat little by little, as it's a ton of surface area.
Pics in the album. |
Posted: Fri May 11, 2018 6:42 pm Post subject: |
Just mostly miss my SleepC right now. It drydocked for a few days while I'm taking care of some other business, but that water sure sounds good.
SleepyC |
