Posted: Sun May 24, 2020 9:52 pm Post subject: |
Just talked to my neighbor who knows metals better than I. He said it is stainless steel! Still asking only $500. But I'm pretty sure shipping won't be too cheap. Colby |
smckean (Tosca)
Vessel Name: Tosca
Photos: Tosca
Posted: Mon May 25, 2020 2:44 pm Post subject: |
I am adding a 2nd AC outlet from my 1000w inverter to the port side of the boat near where the AC panel is (now I only have a single outlet which is on the starboard side near the galley; so any cord to a device on the port side has to cross the beam of the boat). I am also running a 120v cable from the AC panel to my relatively new 36 amp ProTournament charger mounted under the slashwell (now I have to pull the charger's power cord out of the lazarette and plug it directly into the generator).
I knew I would do this someday, so a couple of years ago when the boat was being re-powered with the Yamaha 200, and the shipyard guys were running engine control cables in that area anyway, I told them to run a couple of AC cables from near the AC power panel to the stern under the spashwell for future use of the charger and the inverter. Well, I presume the head guy I talked to told someone else to do this but failed to mention the intended use of these 2 cables. Anyway, they installed two 10-3 gauge cables which are normally used to carry 30 amps into the boat from shore power. They are huge! (I can't imagine what the installer thought I was going to use those for!) When the job was done, I noted that they had run the cables all right, but I never had a good look at the cables. Both devices use under 10 amps so 14 gauge would have been more than adequate.
Now I have a problem since those 10 gauge wires are a bitch to work with. Attaching them to 120v plugs, outlets, and the C-Dory AC panel is nearly impossible. I think I will get some 10 to 14 gauge step-down butt connectors before I go any further. Ah, the wonder of boats . _________________ Sandy McKean
Purchased Tosca in 2014
Re-powered to Yammi 200 in 2015 |
JMacLeod
C-Dory Year: 2018
Vessel Name: C-Shalom
Photos: JMacLeod
Posted: Tue Jun 02, 2020 5:27 pm Post subject: |
smckean (Tosca) wrote: | Now I have a problem since those 10 gauge wires are a bitch to work with. Attaching them to 120v plugs, outlets, and the C-Dory AC panel is nearly impossible. I think I will get some 10 to 14 gauge step-down butt connectors before I go any further. Ah, the wonder of boats . |
Ouch. All that wasted copper with an extra dollop of hassle to boot.
I still have to run cables to move and add to the house battery.
Not looking forward to it, or the price of massive wires.
JMacLeod
C-Dory Year: 2018
Photos: JMacLeod
Posted: Tue Jun 02, 2020 5:43 pm Post subject: |
Installed a generic winch remote to the windlass.
Works like a charm, even from 50' away and through a door.
No more walking back and forth to reach in the window.
No real instructions, so it was just dumb luck that I got the up and down wires correct the first time.
Snipped off the small ring terminals and attached the piggyback terminals so it can be quickly removed/replaced if any problems.
smckean (Tosca)
Vessel Name: Tosca
Photos: Tosca
Posted: Tue Jun 02, 2020 6:33 pm Post subject: |
JMacleod,
A word of warning on connectors. I did a bunch of research after I got some tips here (from thataway if I remember correctly). For boats at least, you want nylon connectors not vinyl. Vinyl are brittle and can break apart under vibration or strong crimps. Nylon are more expensive, and in my analysis worth it (but of course YMMV). The nylons come in 2 varieties: single crimp and double crimp (these take differing crimp tools too). The single crimp depend on internal heat shrink adhesive to provide strain relief adding cost to the connectors; whereas, the double crimp ones use the 2nd crimp for that. I decided I preferred the double crimp.
P.S. In most boat applications, the ring connectors (attach to screwed terminals) are recommended not the spade or forked ones. Also, my bet is that most folks will use more butt connectors than any other (that's been my experience), and many of these kits don't include those. I note the photo you included of connectors are for piggy back quick disconnect spades....I can't imagine what one would use those for on a boat. |
JMacLeod
C-Dory Year: 2018
Photos: JMacLeod
Posted: Tue Jun 02, 2020 8:14 pm Post subject: |
smckean (Tosca) wrote: | JMacleod,
Thanks for the heads-up.
I'd originally bought several sets of heat-shrink connectors and terminals to use with the Anchor crimping tool, but I started finding these spade terminals already in use in more than one location around the boat.
Either factory or dealer, depending on whoever was originally responsible for installing the cabin lights and windlass.
I found and bought some Anchor marine spade disconnects that match the factory/dealer ones, but their piggyback adapter isn't insulated.
This isn't the first bit of "unconventional" wiring I've come across.
Wiring from the alt and charger not properly routed to the batteries, and wrong ABYC color wire for the cabin lights come to mind.
I have a feeling I'll be buying a lot more wiring and connectors before I'm done in my boat-learning. |
Posted: Wed Jun 03, 2020 3:49 am Post subject: |
I Got to share a bit of the C-Dory experience with some interested folks. They came to visit on the SleepyC, and we had a nice time to chat, share, laugh and enjoy C-Dory speak. Kathy and Kevin is was great to get to meet and visit for a while. Best to you in your search.
SleepyC
Knipet
Joined: 11 Nov 2018 Posts: 262 City/Region: Orcas Island
Vessel Name: Pan-A-C'ya
Photos: Pan-A-C'ya
Posted: Wed Jun 03, 2020 9:39 pm Post subject: |
Watched a couple of YouTube videos on whipping rope ends. I call it going to "YouTube University". Whipped my dock lines and an anchor snubber along with making a nice splice. I remember my grandfather, a Danish merchant marine, teaching me how to splice as young boy, but it was nice to relearn the skills! |
anchorout
Joined: 03 Jul 2013 Posts: 357 City/Region: Lake Charles
State or Province: LA
Vessel Name: EZ DUZIT
Photos: EZ DUZIT
Posted: Sun Jun 07, 2020 12:50 am Post subject: moved batteries to port locker. |
With the fridge, 6hp kicker, and batteries, and captain all on the stbd side of the boat, the list became Titanic like. So I moved both batteries to the port locker. That leveled things out a bit. _________________ I DON'T KNOW WHAT I'M LOOKING FOR - That's what makes the search so exciting! |
Nancy and Bud
Joined: 02 Aug 2019 Posts: 305 City/Region: Nashville
State or Province: IL
Vessel Name: Emma Mae
Photos: Emma Mae
Posted: Sun Jun 07, 2020 4:04 am Post subject: |
Removed the rusty swim ladder off boat. New one ordered. _________________ "C-dory's are the 13th step in a 12 step program for sailors."Marc Grove, Wefings Marine |
gstraub
C-Dory Year: 1998
Vessel Name: EnDoryFun
Photos: EnDoryFun
Posted: Sun Jun 07, 2020 5:35 am Post subject: |
Pulled the boat out for some maintenance and after a good cleaning, finally put the name on the boat! _________________ Gerhard |
Pacificcoast101
Vessel Name: No Pressure
Photos: No Pressure
Posted: Sun Jun 07, 2020 1:48 pm Post subject: |
We hauled No Pressure out for the third time this year. We had to replace the drive shaft on each motor the previous two haulouts. Last week, we were hoping to dive around the south side of the peninsula but the charging alarm went off. I tried speeding up, slowing down, idling, and turning the motor off for a few minutes but nothing worked.
We made it back into the slip. I told Merry I would likely have to replace the alternator. I removed the cover to find this.
A leak on top of the motor sprayed water everywhere, frying the alternator and starter. We hauled the boat out, ordered parts including new thermostats for each motor and will try to clean off the rust everywhere else. _________________ Phil Garner
2008 Tomcat 255
No Pressure
My Photos
https://www.alamy.com/stock-photo/?pseudoid=%7bAC42A235-FD0A-464A-B559-1CC5843C95FB%7d&name=Phil+Garner&st=11&mode=0&comp=1 |
Nancy and Bud
Photos: Emma Mae
Posted: Sun Jun 07, 2020 3:14 pm Post subject: |
Sorry to see that. Good luck! |
Posted: Sun Jun 07, 2020 9:15 pm Post subject: |
Phil, How many hours on the motors? Sorry to see that. How long do you think there was a leak..? _________________ Bob Austin
Pacificcoast101
Photos: No Pressure
Posted: Mon Jun 08, 2020 2:02 pm Post subject: |
1070 hours. The corrugated hoses leading from the motors were too short and pulled away from the motors the first week we had the boat. I tried tape and zip ties but water would still get in. That is the likely cause of the starter and various bolts being rusty.
The water leak that fried the alternator is new. I just checked the oil a week before. |
