Goto page Previous  1, 2, 3 ... 247, 248, 249 ... 279, 280, 281  Next
Desert Dory
City/Region: Tucson
Vessel Name: Desert Dory
Photos: Desert Dory
PostPosted: Mon Sep 16, 2019 1:23 am    Post subject: Reply with quote
I'm slowly getting rid of the oxidation on the boat (light wet sand, compound, polish, then a polymer sealant I use on my truck) so, to make things a little easier, I pulled all the teak today. While I had it off I went ahead and sanded it all and applied 3 coats of teak oil. MUCH nicer!
Also put on some vinyl registration numbers making her an official AZ boat.
I have trouble imbedding pics when doing this on my phone so pics are in my album under "Mods".
http://www.c-brats.com/modules.php?set_albumName=album3028&op=modload&name=gallery&file=index&include=view_album.php
PostPosted: Tue Sep 17, 2019 12:05 am    Post subject: Reply with quote
Here are the "Official" numbers.
Like the look of the teak. Good job.
Desert Dory
City/Region: Tucson
Photos: Desert Dory
PostPosted: Mon Sep 23, 2019 9:50 pm    Post subject: Reply with quote
Thanks for posting my pic Harvey!!
Today I played hooky and burned 8 hours of my 2000 hours of sick leave, shhhhhhh, and managed to get the cabin top wet-sanded and buffed. Also got the teak bits put back on and sanded, oiled the last two pieces.
Getting stuff done a little bit at a time. Bonus! It was only in the mid 90's today!!
Edit: OH!!! Almost forgot! I managed to fall off the side of the boat while wet sanding and landed flat on my back on the ground below. Even put a pretty good scrap on my arm on the way down.
Funny how, when you know you're going, you reach for handrails that aren't there.
PostPosted: Tue Sep 24, 2019 4:03 pm    Post subject: Reply with quote
Hey, Great looking bright work. Nice job, and good on ya for getting the pix posted.
Pacificcoast101
City/Region: Torrance
Vessel Name: No Pressure
Photos: No Pressure
PostPosted: Tue Sep 24, 2019 5:48 pm    Post subject: Reply with quote
It was a hot and humid day when we went diving on Sunday. I geared up faster than Merry so I jumped in the water first. I dropped down to the reef, only to find three feet of visibility. I ascended as fast as I safely could and stopped Merry just before she was about to jump in.
We got out of our drysuits, our undergarments soaked from sweat. If I knew conditions were going to be that bad, we wouldn't have gone out. So, I just ordered a fish cam. It has a nine inch monitor with 1080P video, 165 feet of cable, LED lights and a DVR to record video. We will now drop the camera first before getting in our drysuits.
Phil Garner
2008 Tomcat 255
No Pressure
My Photos
Marco Flamingo
Vessel Name: Limpet
Photos: Limpet
PostPosted: Tue Sep 24, 2019 6:32 pm    Post subject: Reply with quote
PWorm,
What grit are you using for wet sanding. I've been using Turtle Wax Polishing Compound, but it doesn't seem to be aggressive enough. It takes forever to get a "kind of" nice finish.
Mark
Desert Dory
City/Region: Tucson
Photos: Desert Dory
PostPosted: Tue Sep 24, 2019 8:03 pm    Post subject: Reply with quote
Marco Flamingo wrote:
PWorm,
Mark
Hi Mark,
I've been starting with 1000, then 2000 then wash everything off when I'm done.
After that I've been buffing with Marine 31 Gel Coat Heavy-Cut Cleaner Wax with my Porter Cable DA (I was using a rotary but the DA seems to work just fine, especially in the tighter areas) with either a yellow or orange cutting pad. I've had no prior experience with the Marine 31 (my fishing boat is aluminum) product but it seems to work pretty well.
Once I'm done doing that I wipe everything down with Renny Doyle Double Black Bead Maker. I started using this stuff on our vehicles about a year ago and absolutely love it. I put it on like a detail spray after washing the vehicle. I get it by the gallon from AutoGeek and I usually wait for a 25% w/Free shipping coupon to show up in my email.
Hope that helps, Allen
Thanks for the thumbs up Harvey!
Capn Jack
City/Region: La Conner
C-Dory Year: 1988
Vessel Name: Pocket Yacht
Photos: Pocket Yacht
PostPosted: Sun Sep 29, 2019 1:15 am    Post subject: Whew!!! Stinky... Reply with quote
The range was closed today, so I pulled Pocket Yacht out of the water for cleaning and bottom paint. Whew! Was she stinky. Smile
Gave her a light wash down and tomorrow I'll fire up, "Killer", my shoulder wrenching pressure washer. Crook
PostPosted: Tue Oct 01, 2019 7:46 pm    Post subject: Reply with quote
Yesterday decided to change the complete water pump on my 2007 Mercury 115HP EFI 4-Stroke. Usually, unless needed sooner, I change out the water pump impeller and cover every two years. This time I decided it was due to have the bottom of the water pump replaced as well. Fairly simple job. And while I had the lower unit off, since the Shift Shaft bushing was looking a little worn, I replaced that also. Again, a fairly simple job. The last two years I've had occasions where the starter motor would not engage unless I hit the switch a few times. Voltage and connections are good. Doesn't seem to matter if outboard is cold or warm. Finally decided to order a complete new starter motor (includes solanoid). Once that gets here, it'll be the next install. And hoping that fixes that issue.
Also installing a screen on the main entry door. I made a few filler blocks around the door jam/frame, and then installed the velcro that came with the screen. Rosanne sewed the screen up to size. I'll try to include some photos in Midnight Flyer's photo album later.
Capn Jack
C-Dory Year: 1988
PostPosted: Thu Oct 03, 2019 12:29 pm    Post subject: Fall Clean Up Reply with quote
Pocket Yacht is back on the dollies with help from my Son-in-law and yesterday she got her bottom painted. Thumbs Up
Supposed to rain today, so I'll have to to wait to paint where the dolly pads were. Sad
Hope to be back on the trailer by the weekend. Then into the water. Wink
Desert Dory
City/Region: Tucson
Photos: Desert Dory
PostPosted: Tue Oct 08, 2019 11:55 pm    Post subject: Reply with quote
Had an unused hole at the back of my console that made a great place to add a dual USB charge port. I wired it to an unused circuit on the switch panel.
I also changed out the anchor light and interior lights to LED.
Teufelshunde
City/Region: Sebastopol
Vessel Name: Fish Wisher
Photos: Fishwisher
PostPosted: Wed Oct 09, 2019 3:36 pm    Post subject: Reply with quote
Installed Permatrim
Laughing F96FE362-ED3D-40EF-AF38-16E3CC674B7F
Pictures in album
What ever you are, be a good one 🇺🇸
Pacificcoast101
Photos: No Pressure
PostPosted: Thu Oct 10, 2019 1:04 am    Post subject: Reply with quote
We've had a plankton bloom in our area for most of the year. It usually lasts through the Spring and early Summer. On many occasions, we have anchored, gotten into our dry suits and heavy scuba gear only to abort the dive once we reach the bottom. Last week, I bought a drop camera with 165 feet of cable and a nine inch monitor. We now check out the visibility before we gear up. The water is still green and visibility is not great, but at least we have an option now.
This was from Hermosa Beach Artificial Reef yesterday.
https://www.youtube.com/watch?v=1Is4EmNNGg8
PostPosted: Thu Oct 10, 2019 9:07 am    Post subject: Reply with quote
Is the plankton bloom only along the coastal waters from MDR to the PV Peninsula, or further up and down the coast? How about in the Channel Islands including Catalina?
What has the water temperature been?
I rarely dove the coastal waters, but don't ever remember seeing a bloom, except in the warmer inner harbors where the Marinas were.
Thanks!
Pacificcoast101
Photos: No Pressure
PostPosted: Thu Oct 10, 2019 10:43 am    Post subject: Reply with quote
http://www.tempbreak.com/index.php?&cwregion=bz#
It's been heaviest nearshore, but even the Channel Islands have had less than twenty feet visibility several weeks this year. The sea surface temperature around Palos Verdes has been in the upper 60s, with thermoclines as shallow as ten feet. I'm hoping it cools off soon.
My 15mm fisheye lens makes it look better than it really is. Those Giant Sea Bass shots were taken within less than a foot from the fish.
Page 248 of 281
Page generation time: 0.204s (PHP: 49% - SQL: 51%) - SQL queries: 33 - GZIP disabled - Debug on
