Bleeding Hynautic K-13 Cylinder
CDory23
Photos: CDory23
PostPosted: Sun Jun 05, 2016 4:58 pm    Post subject: Bleeding Hynautic K-13 Cylinder Reply with quote
I researched and posted a while back about bleeding a seastar helm system with a Hynautic K-13 cylinder. I noticed my Auto-pilot wasn't working and I belive its due to low fluid in the system (helm reservior is low). I must have a leak, but need to fill the system and operate to locate it.
Here is the issue now. On the K-13 there are 2 bleeder screws that are small allen bolts which would make a huge mess and also make it difficult to tell when the air has been purged. Also it doesn't allow you to capture any expensive seastar hydraulic fluid. I purchased these bleeder fittings as they are for a front mount cyilnder, but they are the wrong size.
http://www.westmarine.com/buy/seastar-solutions--bleeder-valve-with-o-ring--10722494
I also have since found these instructions online.
http://boaterstore.com/images/Purge%20with%202%20line.pdf
Has anyone done a proper bleed by loosening the allen bolt fittings? Any help on properly completing this job would be appreciated.
Thanks
CDory23
Photos: CDory23
PostPosted: Sun Jun 05, 2016 5:05 pm    Post subject: Reply with quote
A closer look at the helm pump and it is a Hydraflex LD25
CDory23
Photos: CDory23
PostPosted: Sun Jun 05, 2016 7:34 pm    Post subject: Reply with quote
Maybe this is the right kit to get?
http://www.goodboatgear.com/detail/pd/48619/CYLINDER%20(ALL)%20TEE%20FITT.KIT
Page generation time: 0.024s (PHP: 57% - SQL: 43%) - SQL queries: 16 - GZIP disabled - Debug on
