homerjack
C-Dory Year: 1988
Vessel Name: 49er
Photos: 49er
Posted: Wed Jun 01, 2016 4:00 pm Post subject: |
Possible. Is there an internal pathway in hull from aft to fore? |
homerjack
C-Dory Year: 1988
Vessel Name: 49er
Photos: 49er
Posted: Wed Jun 01, 2016 5:46 pm Post subject: |
UPDATE: Launched again today and moored in slip. About a 1/4 cup of clear FRESH water inside cabin door. No rain in several days. No water tank on boat. |
BrentB
State or Province: IN
Photos: BrentB
Posted: Wed Jun 01, 2016 7:25 pm Post subject: |
Is it condensation? _________________ Brent Barrett |
homerjack
C-Dory Year: 1988
Vessel Name: 49er
Photos: 49er
Posted: Wed Jun 01, 2016 8:59 pm Post subject: |
Not at all, too warm now. No signs. |
BrentB
Photos: BrentB
Posted: Wed Jun 01, 2016 9:09 pm Post subject: |
Do you any thru hull fittings or keelguards attached with screws?
Do you have access to under the berth areas? |
homerjack
C-Dory Year: 1988
Vessel Name: 49er
Photos: 49er
Posted: Wed Jun 01, 2016 10:01 pm Post subject: |
Thru hull fittings: water tank breather, bilge pump outlet. Keel guard is original (see discussion above). No access below berth. |
Posted: Wed Jun 01, 2016 10:39 pm Post subject: |
homerjack wrote: | UPDATE: Launched again today and moored in slip. About a 1/4 cup of clear FRESH water inside cabin door. No rain in several days. No water tank on boat. |
Any chance this is leftover wash water? I believe you are launching into salt water, correct?
SleepyC
homerjack
C-Dory Year: 1988
Vessel Name: 49er
Photos: 49er
Posted: Wed Jun 01, 2016 10:45 pm Post subject: |
Yes Harvey into salt. If you mean washing of boat, that was couple of weeks ago. |
Fairbro
Vessel Name: Minnie Swann
Photos: Minnie Swann
Posted: Thu Jun 02, 2016 7:21 am Post subject: |
Ok, here's a wild shot in the dark inspired by my one time experience of a cup of clear water in the v-berth step down area. Do you keep your portable-potty there like I did? My upper tank leaked the flushing water. This won't explain the larger amount of water but... Wishing you a speedy solution! _________________ Gary & Gerrie former Minnie Swann owners
It's something in the water! |
BrentB
Photos: BrentB
Posted: Thu Jun 02, 2016 11:01 am Post subject: |
Are you considering opening space in the V berth? maybe it contains wet foam |
Wandering Sagebrush
Joined: 21 Jan 2005 Posts: 2770 City/Region: Northeast Oregon
Vessel Name: Constant Craving
Photos: Constant Craving
Posted: Thu Jun 02, 2016 12:33 pm Post subject: |
Another thought. I know of one boat where the rivets to the hull/deck joint were not completely sealed. Yours may have sustained some damage over the years. You might check along that seam to see if you have any indication of a water path. _________________ "And in the end, it's not the years in your life that count. It's the life in your years." - Abraham Lincoln |
Ranger
Joined: 24 Sep 2014 Posts: 18 City/Region: Port orchard
Posted: Thu Jun 02, 2016 2:06 pm Post subject: |
I had water in the cabin while moored last weekend (just inside the door) I was able to track it down to the stove breather. The outer gasket was dried and cracked. I haven't made repairs yet but seems simple enough (fingers crossed). |
homerjack
C-Dory Year: 1988
Vessel Name: 49er
Photos: 49er
Posted: Fri Jun 03, 2016 12:04 am Post subject: |
Slowly headed into the Twilight Zone...went fishing today in salt. Came back with a quart of FRESH water in cabin all accumulating by door. Again, no water tank or other fresh water on board. I may have the only CDory made with an onboard well. It's pretty mind boggling. |
Posted: Fri Jun 03, 2016 3:15 am Post subject: |
homerjack wrote: | Slowly headed into the Twilight Zone...went fishing today in salt. Came back with a quart of FRESH water in cabin all accumulating by door. Again, no water tank or other fresh water on board. I may have the only CDory made with an onboard well. It's pretty mind boggling. |
Hey, nobody asked this yet. "Did you turn the watermaker off"
I'm wondering if there is water that has collected in the forward chamber under the V-birth and has found a way to leak into the cabin. Maybe through the "inspection port" in the floor where the porta potty sits.
You have really got a good puzzle going.
On Edit: Are you sure it is fresh water (tasted) or just clean water?
SleepyC
homerjack
C-Dory Year: 1988
Vessel Name: 49er
Photos: 49er
Posted: Fri Jun 03, 2016 10:35 am Post subject: |
Oh I've tasted it. More than once. Not leaning to berth foam theory. Yesterday entire berth area and potty cubby stayed dry. Water was appearing from door area first. |
