OffLeash
Vessel Name: OffLeash
Photos: OffLeash
Posted: Fri May 27, 2016 8:26 pm Post subject: Stern Line question |
Any suggestions on what size and length stern line for the Tomcat based on the Pacific NW and inside passage cruising?
I did not really see anything in archives?
Thanks for any ideas
Mike _________________ Mike |
Posted: Fri May 27, 2016 8:50 pm Post subject: |
For a stern line, I like at least 200 feet, and have used up to 300 feet. I presume that you mean a line for taking ashore to a tree or rocks. I also carry about 15 feet of 3/16" chain, with a couple of D shackles for the stern line, as well as 25 feet of heavy poly propylene line with eye places in both ends. The poly propylene is easier on trees than the chain.
If there is a high tide, or the beach is dicey--it is nice to be able to slip the line from the dinghy without going back ashore.
I have used both light nylon line, and floating polypropylene line for the stern line.
Others may have different amounts. I have carried these lines on hose or plywood rope reels, as well as in standard coils. _________________ Bob Austin
Ron on Meander
Joined: 17 Jun 2004 Posts: 561 City/Region: Powell River
Vessel Name: Meander
Photos: Meander
Posted: Sat May 28, 2016 1:45 pm Post subject: |
300 ft of 3/8 floating line has worked for me for 14 years of stern tying. Make it a bright colour so it can be seen easily. Many people just use the cheap yellow nylon, but I find that a double braid is much easier to handle and store. I just flake it into a milk carton.
There have very few times I haven't been able to find an anchorage that I can't double up the line so I don't have to return to shore to retrieve. In a few cases I've added a line from my spare anchor but not often. Most times I go around a tree, sometimes in the gulf islands in the busier marine parks there are anchor eyes to use. In the Broughtons it will be mainly trees or boulders.
I've recently started to use a folding 5lb grapple anchor to intially get my stern line to shore. I drop my main anchor, set it, then back as close as I can to where I will stern tie, then toss the grapple to a convenient rock or outcrop. Most times I get lucky and it hooks enough to hold the boat temporarily while the dinghy goes to shore to affix the stern line properly. Makes it a lot easier when Meander doesn't drift with the wind or tide while the dinghy is taking the line to shore. There is always one person on the Meander while the other goes with the dinghy to stern tie.
I also use the little grapple to allow me to back into a beach close enough to step off the swim step so I don't have to use the dinghy. Once the shore party is off, I pull Meander out to deeper (3 ft) water. I don't leave the boat when I do this, but it works well for quick beach breaks for the dog or visitors on the few non rocky beaches we have up here. |
OffLeash
Photos: OffLeash
Posted: Sat May 28, 2016 10:26 pm Post subject: |
Thanks for the ideas
Time to get some line and go cruising!
Mike |
