Refrig/freezer ideas
Post new topic   Reply to topic    The C-Brats Forum Index -> The Galley
bobliz
City/Region: Kingman
Vessel Name: catfish
PostPosted: Thu May 26, 2016 6:35 pm    Post subject: Refrig/freezer ideas Reply with quote
I have a Tomcat 255 and would like to find out if anyone has ideas on additional refrigeration/freezer locations. Ideas and comments would be much appreciated! Bob
Dreamer
Photos: Dreamer
PostPosted: Thu May 26, 2016 7:33 pm    Post subject: Reply with quote
Thataway and others have added a pull-out tray and portable Refer-Freezer in the old Refer area.
Dreamer- Sold 25 Feb. 2013
PostPosted: Thu May 26, 2016 7:34 pm    Post subject: Reply with quote
We put a chest type freezer (Norcold or Dometic etc.) under the port forward seat, on heavy duty sliders:
I'll find the picture this evening.
bobliz
PostPosted: Thu May 26, 2016 7:53 pm    Post subject: Reply with quote
Thanks, that's just the info we were looking for! Planning on taking Catfish to Lake Powell the end of July and that would work great! Bob and Liz
PostPosted: Thu May 26, 2016 8:40 pm    Post subject: Reply with quote
Roger, thank you! You find my photos faster than I do!
Here is the freezer slide out:
And the way the slide base was constructed.:
From straight above:
Some have made the face-off the cabinet slide out, rather than using the swing door. We also had room for spare parts boxes and tools on each side of the "slide out, which could be reached from above, by moving the seat bottom.
We ran 12 volt DC ,with a plug under the seat for the 12 volt DC system, and a separate plug for the 110 volt AC system.
The runners were Home Depot 300# capacity drawler slides. The base was plywood. The sides of the base and cleats (to keep the feet in place, so the freezer would not move), were made of 1 x 2, and the sides for the slides to be mounted on are cut down 2 x 4, glued and screwed to the floor (not the hull).
Post new topic   Reply to topic    The C-Brats Forum Index -> The Galley All times are GMT - 5 Hours
Page generation time: 0.0227s (PHP: 74% - SQL: 26%) - SQL queries: 18 - GZIP disabled - Debug on
