Sink and stove mod on a 19
Goto page Previous  1, 2, 3
PostPosted: Mon May 23, 2016 5:38 pm    Post subject: Reply with quote
haliman wrote:
I used this exact same setup when I installed my washdown system. When I installed the bronze thru-hull I undercut the material back, epoxied then installed with 5200. No problems thus far. If I was the OP I would ask exactly how he installed/prepared the hole for the thru hull as he seems concerned.
Unrelated to the main post but when EQ installed my raw water wash down system the hole is well above the water line and a PCV pipe/strainer system is attached to the outside of the hull. That way one avoids the entire through hull below the water line problem.
PostPosted: Mon May 23, 2016 8:15 pm    Post subject: Reply with quote
Although, wouldn't this be in the uncored topsides? I'm not at my boat right now, but I don't think the bottom core extends up the sides after the chine.... does it?
South of Heaven
City/Region: Sharon
Photos: Blue Water
PostPosted: Mon May 23, 2016 11:32 pm    Post subject: Reply with quote
Greg: Thanks for the "pliers" and simple valve suggestions. I think I'll try the plastic valve and also buy the pliers (just to have them and add them to my toolbox).
Yes, the passenger seats fit over the boxes. He installed new snaps on the boxes to attach to the cushion.
Sure. More pics to follow!
<><><> Jason <><><>
Page 3 of 3
Page generation time: 0.0933s (PHP: 87% - SQL: 13%) - SQL queries: 21 - GZIP disabled - Debug on
