butchpaula
C-Dory Year: 1990
Vessel Name: C-WEED
Posted: Fri Apr 29, 2016 3:35 pm Post subject: in need of impeller R&R asap for Anacortes |
We picked up boat from shop yesteday after 7 months of being jacked around unmercilously!
Now all shops and mechanics are booked until mid-June. We live in Mendocino county and can tow boat almost immediately a repair site.
Do you have any suggestions?
(707) 895-3757
bbrjpaula1@yahoo.com |
Jim & Dara
Joined: 25 Aug 2009 Posts: 43 City/Region: Santa Rosa
Vessel Name: PLAN B
Photos: Jim & Dara (TBD)
Posted: Fri Apr 29, 2016 4:08 pm Post subject: |
I have had no luck with any Outboard shops here in Sonoma County.
We did try having our motors serviced at Outboard Motor shop in Alameda shortly after we purchased there. Unfortunately while I was towing home across the Richmond bridge my bilge pump started discharging into the lane next to me. When I pulled over I found water in all of the drawers in the cabin and in every compartment. I'm still unclear how they did it. I received the equivalent of a shoulder shrug over the phone and have never been back.
I now do almost all of the servicing of our motors my self. When I need anything else I go to Eagle Marine in Martinez. They know their stuff and have treated us very well. It is a bit of trek from Philo but it might be worth while.
http://www.eaglemarineonline.com/
Good Luck,
Jim |
Joined: 27 Oct 2012 Posts: 3370 City/Region: SW Michigan
Posted: Fri Apr 29, 2016 4:19 pm Post subject: |
Don't know what engine you have, but you should be able to buy an impeller kit with all the parts you need for an impeller replacement plus a tube of grease. You should also be able to get a step by step instruction sheet like this:
http://cdn.powerequipment.honda.com/pe/pdf/pubs/pci54309pdf.pdf
If you can work a ratchet set you can do it yourself. If you have never done it before it is only about a 2 hour job, at least with the Honda BF90. Online stores should have the kits if there is not a place near you. |
SEA3PO
Vessel Name: SEA3PO
Photos: SEA3PO
Posted: Fri Apr 29, 2016 5:05 pm Post subject: |
At 500 hours I decided to replace the impellers...easy job and I just bought the impeller...no need for any of the other stuff....lots of Utube videos to watch and a dab of silicone grease will make it go much easier....
Joel
SEA3PO |
BrentB
State or Province: IN
Photos: BrentB
Posted: Fri Apr 29, 2016 6:50 pm Post subject: |
I agree with the others. DIY, It is faster, tools are free using your labor, online tutorials and CBs will help, just post some pics. Change the lower unit fluid, too. Check the anodes at same time, Clean the speedo tube if present, and water pressure valve might need replacing
Also, lube mounting bolts, spline of the driveshaft and bushing area (replaceable part), as well as the spline of the prop shaft. Some motors have a zerk fitting behind the propeller on the housing.
ex
http://www.simyamaha.com/category_s/1992.htm
I would change the thermostats too _________________ Brent Barrett |
SEA3PO
Vessel Name: SEA3PO
Photos: SEA3PO
Posted: Fri Apr 29, 2016 6:55 pm Post subject: |
When you buy your lower unit oil, don't bother to buy that miserable pump junk that they sell to make the job easier.....it really would be if the fittings were even anywhere close to the size of the drain hole....metric I am sure...the package says it will fit.....but nope...
Another wonderful thing they sell that does not come close to working...
Joel
SEA3PO |
Posted: Fri Apr 29, 2016 7:03 pm Post subject: |
SEA3PO wrote: | When you buy your lower unit oil, don't bother to buy that miserable pump junk that they sell to make the job easier.....it really would be if the fittings were even anywhere close to the size of the drain hole....metric I am sure...the package says it will fit.....but nope... |
That must depend on the engine/pump. I just used a Yamaha branded pump kit to change the lower unit oil on my Yamaha engine and the threaded tip that came with the pump matched the lower unit threads perfectly. I happened to buy it from SIM Yamaha where they have a set package that includes the lower unit oil, two gaskets, and the pump kit.
(While digging through my supplies I also found a Sierra pump kit from some time in the past that I didn't realize I had when I ordered the Yamaha one; but I didn't try that - maybe that would not have worked. I haven't always had good luck with Sierra.) |
BrentB
Photos: BrentB
Posted: Fri Apr 29, 2016 8:27 pm Post subject: |
Sunbeam wrote: | SEA3PO wrote: | When you buy your lower unit oil, don't bother to buy that miserable pump junk that they sell to make the job easier.....it really would be if the fittings were even anywhere close to the size of the drain hole....metric I am sure...the package says it will fit.....but nope... |
ditto bought oil and pump from SIM and works perfect |
BrentB
Photos: BrentB
Posted: Fri Apr 29, 2016 8:51 pm Post subject: |
After all of the work getting to the pump, I would do a full replacement. m2cw |
Darkwater
Joined: 12 Feb 2008 Posts: 58 City/Region: Fort Bragg
Photos: Darkwater
Posted: Fri Apr 29, 2016 9:41 pm Post subject: |
Hi Butchpaula- I too have not found a consistently good marine mechanic in Mendocino County. I bought a factory service manual for my Honda BF90D and am doing my own maintenance. But it's good to see the recommendation for Eagle Marine in Martinez. If you give them a try, I would be very interested in your experience with them. It's a long tow to get the boat there, but using them for service would give me a good excuse to do some boating on the Delta or Bay.
Do you fish out of Noyo?
Doug in Fort Bragg _________________ Darkwater Doug
Fort Bragg, Calif
Boat and fishing obsessed...
C-Ray 230DA sold Aug 2013
Retired Dec 2013
2008 C-Dory 22 Cruiser (unnamed) Jun 2014 |
butchpaula
C-Dory Year: 1990
Vessel Name: C-WEED
Posted: Fri Apr 29, 2016 10:03 pm Post subject: Impeler change follow up |
Thanks for all the ideas and feedback - think I'll by a manual and start doing the work myself. Will let you all know what I find out about Eagle in Martinez.
See you out there - thanks again.
Butch |
srbaum
Joined: 30 Aug 2010 Posts: 875 City/Region: Portsmouth
Vessel Name: Osprey
Photos: Osprey
Posted: Sat Apr 30, 2016 8:28 am Post subject: |
Butch,
If it is a Honda 90, I have very detailed color photos that I took, showing each step. I can't send all of the photos via email unless it is through a different path.
Please let me know if it is the Honda (though all outboard brands are very similar, when removing the lower unit to do water pump repairs).
I work on all brands of outboards and the Honda is dirt simple regarding removal and installation of the lower unit. _________________ Steve Baum
Homeport of Portsmouth, VA
BrentB
Photos: BrentB
Posted: Sat Apr 30, 2016 11:26 am Post subject: |
Good Luck ! Good learning activity and save a lot of time and money. I assume you will be buy a factory shop manual |
Joined: 07 Nov 2003 Posts: 7881 City/Region: marysville
Posted: Sat Apr 30, 2016 2:37 pm Post subject: |
buy the parts and the manual and stop by my place on your way to anacortes. I will help you do it. I am in Marysville wa a mile off the I 5. _________________ Thomas J Elliott
potter water
C-Dory Year: 1997
C-Dory Model: R-21 Tug
Vessel Name: Poopsy
Photos: Still C-razy
Posted: Sun May 01, 2016 11:54 am Post subject: |
One of the easiest do it yourself jobs on an outboard. _________________ You can tell a man his wife is ugly, but never ever criticize his dog, his gun, his truck or his boat.
Testosterone Tales-Amazon.com
KG7RC |
