Wiring Wallas
A Fishin C
Guest
PostPosted: Tue Feb 23, 2016 8:53 pm    Post subject: Wiring Wallas Reply with quote
Getting ready to install my Wallas 800.
I will wire to battery within an inline fuse.
One battery I have already wired the 2 downriggers directly to with inline fuses.
1. should I wire the wallas to this battery also, or the other one?
2. If the answer is to wire to the other battery, can I start and run my engine switched to both batteries?
jennykatz
City/Region: naples
Vessel Name: Little Treasurer
Photos: Jennykatz
PostPosted: Tue Feb 23, 2016 9:26 pm    Post subject: Wallas Reply with quote
You need to wire direct to battery with a fuse use the size wire i gave you i had 3 things wired direct trim tabs ,wallas, fridge this is the way it came from cc factory Good luck take care Jim
jennykatz
City/Region: naples
Photos: Jennykatz
PostPosted: Tue Feb 23, 2016 9:27 pm    Post subject: Wallas Reply with quote
There were instructions in the box with wallas
A Fishin C
Guest
PostPosted: Tue Feb 23, 2016 10:40 pm    Post subject: Reply with quote
sounds good Jim, thanks
will be installing when I get it back serviced from Trotac Marine
Page generation time: 0.0901s (PHP: 86% - SQL: 14%) - SQL queries: 21 - GZIP disabled - Debug on
