Doug Moody
Vessel Name: Currituck
Posted: Fri Feb 12, 2016 12:30 am Post subject: Hella vent fan |
Alright Brats, I have a challenge: I'm trying to find a replacement for a "Hella Rotor" vent fan. It was mounted high above the cook stove on the side wall, under the drip line of the roof. I think the use was to exhaust the vapors from the alcohol cook stove. The fan does not appear to have worked in awhile and is seized up, beyond repair. It is about 6" long and 1 1/2" wide rotary cylinder with an about 1" x 3" exhaust port. The issues is the exhaust port was cut through the sidewall and I cannot find duct tape to match!
C-Brat searches, Amazon, Google, Bing are all no goes. More pieces of the puzzle. I believe I am the 3rd owner of the boat which I believe originated in Juneau AK. The hull is a 1990 Cruiser which is pretty much stock except heater and electronics.
Does anyone have any tips, clues or suggestions where is may find a replacement?
[/img] |
Marco Flamingo
Vessel Name: Limpet
Photos: Limpet
Posted: Fri Feb 12, 2016 10:40 am Post subject: |
Have you asked Hella Marine? I'm not sure how responsive they would be, but they might give you some ideas.
http://www.hellamarine.com/en/products/accessories/fans/turbo-fan.html
Another option would be to put a standing search on Ebay. The problem would be that, unless the name/model is right on the unit, the seller might just say "12V fan." You would end up getting hundreds of notices from Ebay. I was able to do an Ebay search for a fuel gauge that hasn't been made since 2008 and Ebay came up with two NOS units in 6 months. Worth a try if you have the time.
Mark |
Joined: 02 Nov 2003 Posts: 21497 City/Region: Pensacola
Posted: Fri Feb 12, 2016 12:35 pm Post subject: |
This sounds like a squirrel cage blower type of fan. These are used in defrosters, as well as many other applications. Hella is better know for auto parts than the marine fans. It is very likely that this fan was an auto part (12 volt) and adapted for the use in your boat. Today computer fans, are also common to be small squirrel cage type: Do a Google search: "12 volt squirrel cage fans" There is a pretty good chance, that you will find a small fan, which can be adapted to fit where you need it. This may involved making a mounting of teak, or of aluminum, plastic etc for fit over the hole, and then bolt the new fan to this adaptor mounting.
Is your goal to put another fan in place, or to close the cut out area? (As good as duct tape is, it may not be the best way to plug an unused hole permanently.)
The [img] at the end of your post suggests you wanted to post an image. Can you take a photo of the fan? You can either make a link to your photo where it has a internet address, or have a moderator provide an album, so you can post the photo in the album, and then put in the threads.
To plug the hole, making a fiberglass repair is not all that hard to do. Putting another blower type of fan may also not be that hard, but finding an exact replacement may be a major issue.
[/img] _________________ Bob Austin
tsturm
Joined: 01 Nov 2003 Posts: 1172 City/Region: Soldotna
Vessel Name: JMR TOO
Photos: JMR-TOO
Posted: Fri Feb 12, 2016 1:24 pm Post subject: Re: Hella vent fan |
Doug Moody wrote: | The issues is the exhaust port was cut through the sidewall and I cannot find duct tape to match! |
If you can not find the correct color of Duct Tape in AK it does not exist!!!
