Wood Zeppelin
C-Dory Year: 1997
Vessel Name: C-Creature
Photos: Childhood Dream
Posted: Tue Oct 16, 2018 2:56 am Post subject: Best Trolling motor / Kicker for a 16" cruiser !? |
I have a 16' Cruiser with a 4hp Suzuki 1-cyclinder. I don't like the vibration of a 1-cyclinder nor do I like the internal fuel tank. Can anyone recommend a better option?
The main motor is a Honda 40hp, and I'd like the kicker to be compatible with fuel line hookup if possible (or it could have it's own tank and fuel line)..
thanks! _________________ James Salay - Real Estate Broker / Investor, Engineer, Artist, Fisherman, Canyoneer, Outdoor Enthusiast
Current boats:
1988 16' Angler - "E-fishn-C" (Project boat)
Also:
14.5' Drift Boat - "Wood Zeppelin" |
Posted: Tue Oct 16, 2018 11:50 am Post subject: |
Well, that's interesting. To get a 2 cylinder motor one has to go to a 8 HP, which seems like a lot for a 16' boat. That's because all small engines (<6 HP,) seem to be from the same source, with different labels on them. All singles.
So, I'd check out Honda 5 HP singles. Honda builds over-engineered motors and their 5 may be smoother than others. Or Yamahas. Both are pricey.
Otherwise, Tohatsu makes the lightest 8HP. Same block as the 9.9 HP. Weight: 82 lbs. I have the 9.8 which has been a good motor.
I also have a 6 HP Johnson 6 HP twin, but they don't make that anymore. It's a 2 stroke and one of the best motors I've had.
Defender is a good place to compare motors.
Boris |
DayBreak
Joined: 16 Jul 2017 Posts: 863 City/Region: Monmouth, Or.
C-Dory Year: 2018
Vessel Name: DayBreak
Photos: DayBreak
Posted: Tue Oct 16, 2018 12:45 pm Post subject: |
I have a new Tohatsu 6hp that I use on my old 14ft. Valco. When I bought the Tohatsu, (only 55lbs.) I was pleasantly suprised at how smooth the engine ran at all speeds. It has an internal tank but if you switch a lever you can also run a separate reserve tank with a primer bulb. Like Boris said, a twin will be noticeably heavier than a one lunger. The 6hp Tohatsu has quite a bit of punch and it actually puts the Valco on plane with just me onboard and light gear. |
PaulNBriannaLynn
Joined: 26 Oct 2012 Posts: 757 City/Region: Fort White
Vessel Name: TBD
Photos: Lorelei
Posted: Tue Oct 16, 2018 1:04 pm Post subject: |
All singles are going to vibrate more. We run a 5 hp Honda as a kicker now, and it's very reliable and relatively quiet, but vibrates a lot.
I think you may have to move up in size to get a twin cylinder like a Honda 9.9, which will be obviously heavier
I have a 1984 Evinrude 9.9 which is a twin and its smoother. Its quite a bit louder though. Id have to run a separate tank for mixed fuel, and I'm getting too old to pull start the temperamental thing when its cold. _________________ 2007 22 cruiser sold 10/2021
2009 Parker 23 sold 10/2017
2003 22 cruiser sold 3/2016 |
Capn Jack
Joined: 01 Oct 2007 Posts: 525 City/Region: La Conner
C-Dory Year: 1988
Vessel Name: Pocket Yacht
Photos: Pocket Yacht
Posted: Fri Oct 19, 2018 12:21 pm Post subject: Kicker for 16' |
I'm still using the '88 6hp. Evenrude that came on my boat.
Two cycles run forever and they're lighter than most four cycles
of equal hp. ![Wink](images/smiles/emwink.gif) |
