Rain
Joined: 09 Oct 2015 Posts: 218 City/Region: Oak Harbor
Vessel Name: C-Glory
Photos: C-Glory
Posted: Sun Dec 27, 2015 11:19 am Post subject: 9.9 Suzuki has me puzzled |
My kicker is a new DF9.9B. It starts and runs fine, but when I try to flush it in the raised position (using ears, of course), it starts, runs for several seconds, then dies as though it is starving for fuel. It will start back up, but dies more quickly each subsequent attempt until after 4 or 5 attempts will not start at all. So I flush it with the flushing port, which doesn't seem like it would be as good. This has happened twice. Any input/opinions would be appreciated.
Additional information:
The boat is in the water, so flushing with fresh water in the lowered position is not an option.
The main, a 2008, 115 Suzuki, runs fine while being flushed in the raised position. _________________ "I swear by my life and my love of it that I will never live for the sake of another man, nor ask another man to live for mine."
Ayn Rand, Atlas Shrugged |
Spike
Vessel Name: Bootleg Hooch
Photos: Bootleg Hooch
Posted: Sun Dec 27, 2015 12:07 pm Post subject: |
If your kicker is a carburetor engine than you are problaly starving the engine for fuel trying to run it at that angle. Without knowing the exact design of the carb I would guess that fuel is not getting to the float bowl, or getting from the bowl to the jets. Your main is a fuel injected engine so not an issue _________________ Chuck
Bootleg Hooch |
My IRA
Joined: 18 Dec 2003 Posts: 233 City/Region: Springfield
C-Dory Year: 2013
Vessel Name: Aidiam
Photos: My IRA
Posted: Sun Dec 27, 2015 12:31 pm Post subject: |
I have the same engine configuration as you and flush them in one of two ways. First, warm the engines then shut off and use the flushing ports with the engines in tilt position. Second, you can tighten (using a bungee cord) your ear muffs and place them on the 9.9, then lower the engine and flush with engine running.
When you pull the boat, flush with Salt Away type product. _________________ Jerry and Helen
1984 Arima Explorer sold 1985
1985 Arima 17 SR sold 1992
1992 C-Dory 22 Cruiser sold 8/96
1992 OLympic 26XLF Sold 10/2000
1989 Arima 19 SR sold 2003
2004 C-Dory 25 sold 10/05
1992 Bounty 25 Offshore Pilot sold 6/2010
2006 Arima 17 SC sold 9/2012
2013 C-Dory 23 Venture |
Rain
Photos: C-Glory
Posted: Sun Dec 27, 2015 1:01 pm Post subject: |
Spike, both are fully injected.
My Ira, so I take it that your 9.9 will not run in the raised position. Is that correct? |
Spike
Posted: Sun Dec 27, 2015 1:31 pm Post subject: |
Maybe the fuel injection modual on your kicker will not let the engine run at that angle. Just tossing it out there. Also I sent you a PM, they may be related. You may not be getting sufficient lubrication at that angle so your engine automaticly shuts off. The oil sump on your main my be designed differently so that does not happen |
Posted: Sun Dec 27, 2015 2:26 pm Post subject: |
2.8 Questions.
Do you need to have the OB running IF you are using the flush port?
If it is vertical, does the flush port pressure drive out the salt water? If so, can you flush it in vertical position then raise it after it has the flush time and rinse off the lower section.
I don't know the specifics for hyours but on my Yami's it is "Don't run them when doing the flush with the port, and the port is the best flush."
Nice to see you getting the album going.
SleepyC
dotnmarty
Joined: 03 Nov 2003 Posts: 4209 City/Region: Sammamish
Vessel Name: LIZZIE II
Photos: Lizzie
Posted: Sun Dec 27, 2015 2:57 pm Post subject: |
I don't know it they planned it that way or not, but I don't think there's anything wrong. Just lower the engine and it will run fine. _________________ MartyP
digger
Vessel Name: C-Sik
Photos: Snoopy-C
Posted: Sun Dec 27, 2015 8:11 pm Post subject: |
Many engines have a low oil sensor that will kill the spark when oil is not registering on the sensor. Also, running in that position may starve oil by not allowing the oil pickup to pull oil-- that can damage the engine. I would never try to run any engine anywhere past the shallow water tilt position -- they are designed to handle that. |
My IRA
C-Dory Year: 2013
Vessel Name: Aidiam
Photos: My IRA
Posted: Mon Dec 28, 2015 1:26 am Post subject: |
Our 2013 Suzuki 9.9 is not injected and I don't run it raised because the manual states not to run it in a full tilt position (oil pressure concerns). |
Rain
Photos: C-Glory
Posted: Mon Dec 28, 2015 1:40 am Post subject: |
I read my manual cover to cover and do not recall seeing that. I have been reading and learning a LOT since getting this boat; I may have missed it! I will check it again when I go to the boat tomorrow.
Thanks to everyone for all the input. This is a great forum! |
Rain
Photos: C-Glory
Posted: Fri Jan 01, 2016 2:42 pm Post subject: Read Manual again |
It was there! Thanks for inspiring me to read it again. It was under "Flushing, Engine Not Running"! Technical writing isn't what it once was! Fortunately, the motor is smarter than I am, so it seems to have shut itself down before any damage was done. I ran it for over half an hour yesterday, trying to get some of the break in done. I have no tach for the kicker, but at about half throttle, hopefully around 3000 RPM, it was pushing us along at well over 3 knots. |
Bill K
State or Province: OH
Vessel Name: NIC'L PIC'L
Photos: NIC'L PIC'L
Posted: Fri Jan 01, 2016 8:16 pm Post subject: |
I put a induction tach on my 9.9 Honda.
William B. Kelleher _________________ KA8BFT |
Rain
Photos: C-Glory
Posted: Fri Jan 01, 2016 11:46 pm Post subject: Good idea. |
Tell me more. |
Bill K
Photos: NIC'L PIC'L
Posted: Sat Jan 02, 2016 2:17 am Post subject: |
Like this one.
http://tinytach.com/gasoline.php
I strapped mine to the wire bundle in my stb,lazeret (sp)
Bill Kelleher |
Rain
Photos: C-Glory
Posted: Sat Jan 02, 2016 2:23 am Post subject: |
Nice! Thanks! |
