RobLL
Joined: 05 Aug 2014 Posts: 421 City/Region: Bremerton
williwaw
Vessel Name: Williwaw
Photos: Williwaw
Posted: Fri Nov 27, 2015 11:37 am Post subject: |
You need a higher amperage USB charger. I've had good luck with these: USB Car Charger |
AstoriaDave
Posted: Fri Nov 27, 2015 12:01 pm Post subject: |
rob,
Another choice. I have not used this one, but Belkin has always served me well.
http://www.target.com/p/belkin-2-1-amp-car-charger-red/-/A-14511470
The item you linked would be my preference, but demands some installation. I would install two, at their low amperage you could run them both off the same fuse Like the low profile compared to most chargers that plug into the cigarette lighter fixture. At any electronics store should be a couple choices of the latter. _________________ Dave Kruger
Astoria, OR |
Posted: Fri Nov 27, 2015 1:11 pm Post subject: |
I just found one of these at Costco:
Lithium Jump Starter and Portable Power Bank
Features: High Output Jump Starter
2 USB Ports for Fast Charging of Mobile Devices
8000mAh High Capacity Power Bank
3 Mode Flashlight
Item #750766
Your Price$59.99
Shipping & Handling: $5.99 *
It weighs 1.1 pound and is about 3” x 5’ x 1”. It is replacing the jump start pack that I have been carrying for 9 years that weighed 12 pounds and was the size of a basket ball.
SleepyC
Posted: Fri Nov 27, 2015 1:31 pm Post subject: |
I prefer to install a cigarette lighter socket rather than the dedicated USB socket. Then you can use any appliance, which plugs into the Cig lighter socket. This includes various amperage, USB phone chargers, lights of all types, including spot lights, fans, inflators for the dinghy, or even small cup type of water heaters. (Also the small inverters)
I use at least #10 wiring and fuse it for 30 amps. I have all of my fuses in the Blue Seas fuse panels, it makes it much neater than separate fuses in line. You also want a switch if you are going to put in a dedicated USB charger. Often the deliated are not enough amperage for the i pad or other tablets.
Blue seas panel, available in 6 or 12 fuse. I changed out the single six which came with the boat to two 12 fuse panels, and labeled each fuse and circuit.
_________________ Bob Austin
Posted: Fri Nov 27, 2015 1:42 pm Post subject: |
I agree with Bob's advice and installed several Cig plug receptacles and then plug my devices into the cig plugs. I have one cig plug that is hot to the battery even when the 1-2-Both-Off switch is in the Off position. That way I can use that plug to power my rear view camera when towing, and everything else is off. When anchored, I use that plug for my small Garmin GPS to monitor my anchored position wanderings.
Cell phone charger, hand held VHF chargers, inverter for lap top, and spot light chargers all plug into the cig lighter plug.
SleepyC
RobLL
Posted: Fri Nov 27, 2015 2:35 pm Post subject: |
Thanks for all the information and alternatives. I have a friend who is the sort of 'master of all trades' coming up, so will have him look at these replies. And that Costco back up looks like the sort of thing I would also want.
Bitterend guy did a presentation on electronics at the Seattle boat show, and his first three pieces of advice was batteries, batteries, batteries. |
Two Bears
State or Province: ID
Vessel Name: Two Bears
Photos: Two Bears
Posted: Fri Nov 27, 2015 4:03 pm Post subject: |
This summer I had same problem with just I-Pad charging. I tried two different Cig/ USB port adapters, one of which was the Amazon one listed above. The I-Pad lost battery charge while hooked up running a Marine chart program while we were running. The Cig lighter sockets were add-on that I installed and tapped into other wires for power in the left corner or forward passenger side of the boat. I concluded that wires are too small for that long a run for the draw needed by our devices. This last trip we had the following needing charging from a USB port: 2 laptops, a Verizon "Hotspot" WiFi, 2 camera batteries, a Kendal "paperwhite" and the I-Pad. We had to schedule what got charged and when.
With that in mind, this winter's job list includes running a new dedicated line of a larger gauge wire from a dedicated helm switch/ fuze to the underside of the table and install multi outlets there.
Chuck _________________ Chuck & Penny Raddon
Orofino, Idaho |
Posted: Fri Nov 27, 2015 7:59 pm Post subject: |
Oh, I forgot to add that the Costco jumpstart/charger also plugs into the cig lighter for 12VDC charging. How cool.
SleepyC
Bill K
State or Province: OH
Vessel Name: NIC'L PIC'L
Photos: NIC'L PIC'L
Posted: Sat Nov 28, 2015 1:35 am Post subject: |
I found the jump start battery at my Costco store and saved the shipping charge.
Bill Kelleher _________________ KA8BFT |
RobLL
Posted: Sat Nov 28, 2015 10:33 am Post subject: |
I see that Amazon has a number of the battery back-ups which will start automobile gas motors, they all seem to include charging electronics, a flashlight, and can be charged with the cigarette lighter.
It also seems that charging one would work better with the re-wired 12 volt battery per thataway. |
Bob&Alicia
State or Province: GA
Photos: Bob&Alicia
Posted: Sat Nov 28, 2015 10:43 am Post subject: What's the amp output on the USB? |
We've been charging 2 iPhones, iPad, Mifi using the 12 volt at the helm and under table. We use a USB multi plug. The amp of the USB OUTPUT seems to be the key. 1 amp for iPhone overnight anchor watch. For ipad navionics the 2+ amp output. I bought two 12v plugs with 3 USB slots on Amazon. Amps are 1, 2, 2.2. iPad needs the over 2. No issues charging 3 devices at a time. Most USB 12v are only 1 amp output. _________________ Bob and Alicia |
Casey
Joined: 02 Nov 2003 Posts: 1094 City/Region: The Villages(FL)
Vessel Name: "Dessert 1st"
Photos: Dessert 1st
Posted: Sun Nov 29, 2015 5:47 am Post subject: |
Not all USB chargers provide the same amperage.
Here is my post from Mon May 11, 2015
For the he past few weeks we have noticed that our iPad3 was slowly loosing its charge over 6-8hours of cruising. By late afternoon the iPad would be down to <10% even though it had been plugged in to a 12V socket all day. The iPad simply required more energy than the 12V plug was providing.
As a test, we plugged our small (140W) RadioShack inverter into the 12V source, then plugged the somewhat larger iPad 110V charger into the inverter. Problem solved - but the arrangement was rather cumbersome. Using this arrangement the iPad maintained its charge all day.
When we met Steve Baum (CD22 "Osprey") few days ago, he had experienced the same iPad power-loss issue that we experienced. His solution was to use a PowerGen 12V plug that supplies more current. He set me up with one, and it seems to be working fine, and it's a simple USB adaptor that goes into the 12V socket. I've seen several of these, and most seem to supply 2.1A. The PowerGen supplies 4.2A (if you only have one device plugged in).
Here's the PowerGen link on eBay:
http://www.ebay.com/sch/i.html?_from=R40&_trksid=p2050601.m570.l1313.TR0.TRC0.H0.XPowerGen+4.2.TRS0&_nkw=PowerGen+4.2&_sacat=0
Best,
Casey&Mary
2003 CD22 "Naknek" (sold May 2008) _________________ 2013 CC23 "Katmai" renamed "Dessert 1st"
2003 CD22 "Naknek" (sold May 2008) |
Will-C
Vessel Name: Will-C
Photos: Will-C
Posted: Sun Nov 29, 2015 9:08 am Post subject: USB Charging on Board |
We use a 400w inverter plugged into a standard 12vdc socket. Then plug in a 6 way power strip. Then you can use your standard 120v ac charging adapter that came with your devices. Lets you charge camera batteries Ipads, cell phones, etc. This has worked for us for years while on the boat or towing on land in our truck.
Pandion
Vessel Name: Osprey
Photos: Osprey
Posted: Sun Nov 29, 2015 1:18 pm Post subject: |
Harvey, any idea how long that thing will hold a charge? And has anyone actually used one of these to start a boat engine?
Andy Ryan
