NMEA link problem- NavMan FUEL 3100 and Garmin 178c
AK Angler
City/Region: South Central
Vessel Name: Rod Holder
Photos: Rod Holder
PostPosted: Fri Sep 02, 2005 2:16 am    Post subject: NMEA link problem- NavMan FUEL 3100 and Garmin 178c Reply with quote
I just installed a Navman 3100 fuel flow meter and am trying to interface it with my Garmin 178c chartplotter. Problem is that even though both units are powered up and working independently, they won't seem to talk to each other. I found the menus in each unit to turn on NMEA, but still no dice. Without the link I can't get the "range" feature to work. And I don't want to be trying to do the math while I'm supposed to be driving the boat. Any suggestions?
-Rod
PostPosted: Fri Sep 02, 2005 5:49 am    Post subject: Reply with quote
Rod-
At the risk of asking the obvious, you do have the correct connecting cable installed, don't you? I'd check the continuity of all the wires in the cable after the required wiggling tests. Is there a way you can check he signal coming out of the fuel flow meter? Often the factory tech reps can be of great help here with the least time lost to scratching one's head! Joe.
Anita Marie
City/Region: Oak Harbor
Vessel Name: Anita Marie
PostPosted: Fri Sep 02, 2005 10:19 am    Post subject: Reply with quote
Rod, I had the same problem with my NAVMAN. The problem is the installation instuctions by NAVMAN. They have the polarity wrong on the NEMA wiring. If you reverse the wires hopfully it will work.
Fred
tpbrady
Vessel Name: Bidarka II
Photos: Bidarka
PostPosted: Fri Sep 02, 2005 10:54 am    Post subject: Reply with quote
Same problem with mine and a Lowrance LCD20x. The factory wants me to send it back.
Fred, do you mean by polarity that transmit and receive are reversed? I'll try it this evening.
Thanks for the tip.
Tom
22 Cruiser Bidarka 2004-2009
42 Nordic Tug 2015-
28 KingFisher 2009-2014
14 Jetcraft 2000-
17 Scanoe 1981-
tpbrady
Photos: Bidarka
PostPosted: Mon Sep 05, 2005 10:40 pm    Post subject: Reply with quote
That fixed the problem. The NMEA receive on the Navman 3100 is the yellow wire. It is labelled as transmit in the installation manual.
AK Angler
Photos: Rod Holder
PostPosted: Tue Sep 06, 2005 12:53 am    Post subject: Reply with quote
Just got back from Big Lake after switching the Navman wires. Everything's just fine now.
Thumbs Up
Thanks Fred. That's why I ask these kinds of questions here. Somebody usually has an answer.
Page generation time: 0.0268s (PHP: 61% - SQL: 39%) - SQL queries: 19 - GZIP disabled - Debug on
