new power
cut plug
City/Region: Kingston
C-Dory Year: 1983
C-Dory Model: 18 Angler
Vessel Name: cut plug
PostPosted: Fri Oct 16, 2015 5:10 pm    Post subject: new power Reply with quote
just put on a 2003 tohatsu 115 on my 83 18' C=Dory. I dips to left at speed. Any ideas to remedy this? Trim tabs etc... Thanks, Rob (cut plug)
PostPosted: Fri Oct 16, 2015 5:12 pm    Post subject: Reply with quote
One thing to check or adjust might be the trim tab on the engine itself. This may look like a little metal "wing" under the anti-ventilation plate which you can adjust from side to side to compensate.
SGIDave
City/Region: St. George Island
Photos: SeaDation
PostPosted: Fri Oct 16, 2015 8:20 pm    Post subject: Re: new power Reply with quote
Hello CP
Congrats on the new motor. The prop's right-hand rotation is causing a little 'steer' effect. Not uncommon.
To fix it, try adjusting (i.e., rotating) the tab hanging at 12 o'clock above the prop as viewed from the rear. It looks like this...it is sometimes also a sacrificial anode
dave
NORO LIM
City/Region: Olympia
Photos: NORO LIM
PostPosted: Fri Oct 16, 2015 9:58 pm    Post subject: Reply with quote
Do you also find it harder to turn the steering wheel one direction as opposed to the other at some speeds? If so, it's very likely the engine tab.
If you're not familiar with adjusting that engine tab, you may want to look at it closely, and read up a little in your manual. The adjustment can be counter-intuitive for some folks. The placement of the tab is behind the pivot point of the outboard as the outboard is steered. As you stand behind the boat, turning the trailing edge of the tab to port will make the engine and its prop swing to starboard, which will make the bow swing to starboard, as well. Think of it as a rudder for the prop, not for the boat. Try small adjustments at a time. It may be hard to find one setting that fits all speeds. I usually adjusted the tab so as to be as near neutral as possible at my normal on-plane cruising speed. (If I've got this all wrong, I'm sure I'll hear about it. Laughing) Good luck!
Bill, Formerly on NORO LIM
2001 CD 16, 2001-2006
2006 CC 23, 2006-2014
Darkwater
City/Region: Fort Bragg
Photos: Darkwater
PostPosted: Fri Oct 16, 2015 10:24 pm    Post subject: Reply with quote
My old Sea Ray would dive left at speed if the outdrive trim was fully down. This was a bit scary! Try adjusting your outdrive trim up, to a position where the ventilation plate is parallel to the bottom of the hull. With the boat on the trailer, adjust the trim to be parallel and note that position on your trim gauge. This "neutral" trim position can be a useful reference in learning to drive the boat in various sea conditions.
That new engine is a substantial amount of power for that size boat!
Darkwater Doug
Fort Bragg, Calif
Boat and fishing obsessed...
C-Ray 230DA sold Aug 2013
Retired Dec 2013
2008 C-Dory 22 Cruiser (unnamed) Jun 2014
cut plug
C-Dory Year: 1983
PostPosted: Tue Oct 20, 2015 11:48 am    Post subject: new power Reply with quote
Thanks for all the help. I wiil work on your suggestions. Thanks again, Rob
PostPosted: Tue Oct 20, 2015 12:26 pm    Post subject: Reply with quote
--->Bolding and underline is mine..Harvey
It may be that Darkwater is onto something there. Seems to me like that would be like putting a V-8 on a go-cart. Just for comparison, that is 1/3 more power than I have on my 22 Cruiser. Curious how you came up with the HP choice? Do you have trim tabs on your 18? And when you say "..at speed" What speed are you making?
Larry H
City/Region: Tulalip,
C-Dory Year: 1991
Photos: Nancy H
PostPosted: Tue Oct 20, 2015 12:44 pm    Post subject: Reply with quote
It's a torque reaction. The prop rotates to the right, viewed from behind. The torque reaction to turning the prop tries to rotate the motor and the whole boat to the left. (The left side of the boat is being pressed down while the right side is being lifted.)
You have more torque applied to the hull than the hull can handle.
Trim tabs could help.
PS: Make sure your transom is in good shape as the motor is trying to twist itself off the boat.
Larry H
A C-Brat since Nov 1, 2003
Blueback
City/Region: Qualicum Beach, Vancouver Island
C-Dory Year: 1990
Vessel Name: Blueback
Photos: Blueback
PostPosted: Tue Oct 20, 2015 2:58 pm    Post subject: Reply with quote
Right on Larry. Re: "Newton's first law of motion" said it best in the 1800's -- something like this:
For every action there is an opposite and equal reaction. Therefore, the action and force in turning the prop to the right means the motor housing absorbs the equal "reactionary" force to the left along with the transom/boat.
I'm in the third stage of life:
1-Learn to catch fish.
2-Catch fish -hopefully-
3-Work at rebuilding the endangered runs of salmonids on the West Coast
PaulNBriannaLynn
City/Region: Fort White
Vessel Name: TBD
Photos: Lorelei
PostPosted: Tue Oct 20, 2015 3:02 pm    Post subject: Reply with quote
I'd love to see pictures of the elusive 18' angler. I have seen the Toland 18'8 out on the water, but not sure I've ever heard of an 18 angler before. It sounds really cool!
Jack in Alaska
C-Dory Model: 26 Pro Angler
Vessel Name: HIGH TIDE II
Photos: HIGH TIDE II
PostPosted: Tue Oct 20, 2015 10:12 pm    Post subject: prop torque Reply with quote
My 1983 22' CD tipped to the left with a 115HP Johnson at high speeds. It scared hell out of me the 1st time.
The little rudder on the lower unit and keeping my throttle pulled back a little fixed it.
Good luck.
Jack
No. CD026021I405; AK-5008-AK
MSSI No. 338143486(cancelled)
Stolen & stripped in Aug. 18
PostPosted: Wed Oct 21, 2015 1:52 pm    Post subject: Reply with quote
A Toland 18.8 on Sequim Bay. I believe this one had a 70 on it.
Page generation time: 0.0479s (PHP: 66% - SQL: 34%) - SQL queries: 25 - GZIP disabled - Debug on
