Webminer2
Vessel Name: "Sweet C"
Photos: Quiet Time
Posted: Fri Jul 31, 2015 1:40 pm Post subject: --16' Cruiser for sale in NC |
C-dory 16 cruiser description
Search for "quiet time" for pictures
1999C-DORY 16' CRUISER $14,000
1999 40 HP Honda Outboard with Hydraulic lift
1998 6HP susiki kicker
Full Canvas Camper Cover
Cabin cover
New storage full canvas cover, never used.
VHF Radio
Lowrance GPS, Depth Sounder sonar
3 portable gas tanks (total 18 gallons)
Dual batteries with selector switch, running lights, horn, bilge pump.
1 electric wipers, anchor and line, fenders
2 Rod holders and mounts
Interior has small v-berth with cushion, two chairs and table. Portapotie
Wesco Loader Trailer with spare tire, easiest boat to launch and retrieve I have ever owned: guide rails plus guide bunks, it can only go on one way, always centered, drive right on.
This is a very fuel efficient, seaworthy, and comfortable boat.
porta potty
set of 4 life jackets
cabintop mounted forward light
bimini cover zips onto stainless steel frame
cockpit cover (snaps on) prevents rain from getting into cabin.
Bow rail.
electric bilge pump
swim platform with stainless steel boarding ladder
docklines
A salty little cabin affords plenty of protection from the elements. It's this cabin that sets C-Dory's 16' Cruiser model apart from the competition.
Very few boats this size offer a hard top cabin, and none as good looking or as ruggedly built as the C-Dory.
The cabin seats two people on swiveling seats mounted on storage lockers, two additional people can be seated on the aft edge of the "V" berth.
The berth area is open with only a dash on the starboard side. A removable table mounts along the port side. Storage space is available under the berth and under the two swivel seats. The aft deck is about 3', from the back of the seats to the motor well.
This is a low hour clean boat that is seriously for sale. Read below abut the model and check out the recent pictures.
One of the most successful C-Dory model, the 16' Cruiser. It has enjoyed a steady production run. Many refinements based on customer input rather than on fashion trends, have been incorporated over the years. Materials used in the construction of the boat have been constantly upgraded, ensuring that the model keeps pace with the technology available today.
A practical boat, the C-Dory 16' is designed and built to be seaworthy, easily maintained and affordable to operate. Although a full-size cabin cruiser, it is relatively light and well balanced for easy towing and invites the owner to explore distant waters. Average towing weight is about 1600 lb. boat, motor, trailer, & fuel.
Many owners compare their C-Dory to a trusted old Volkswagen or Jeep because of its go-anywhere qualities and simple maintenance. Yet these boats are thoroughly modern, incorporating the best of proven materials and ample space for the latest electronics.
By definition a dory is a flat bottom boat, with high flaring sides. The C-Dory is a modern refinement of this classic design type. The planing hull is nearly flat at the stern and gradually becomes a “V” at the bow. Deep reverse chines channel the flow of water, holding it under the boat, increasing lift and decreasing wake and spray. Heavy plank lines along the sides contribute to the C-Dory’s classic, salty appearance. They also stiffen the hull and serve as spray knockers, making the boat pleasantly dry running. The brow of the cabin roof reduces glare in the windows and adds to the boat’s distinctive lines.
This boat will plane comfortably at as little as 9 ~ 10 MPH. Economical cruise ranges from 12 ~ 20 MPH at well over 6 MPG. (rated test performance is in measured running in a straight line, in perfect trim, on good water, real boating use will normally yield about 4.5 ~ 5 MPG average). She will top out at about 28 MPH with a Honda 40 HP
Maneuverability at speed is balanced and predictable, even in heavy seas. The boat holds her course with little effort. The hull’s flatness toward the stern greatly reduces the rolling motions, making cruising in rough water much more pleasant. Fishermen will love the way the boat trailers even behind a regular mini van. |
Webminer2
Photos: Quiet Time
Posted: Thu Aug 06, 2015 11:19 am Post subject: 16 cruiser |
"Sweet C" is sold and on it way to PA. |
Eric
Joined: 28 Jul 2015 Posts: 11 City/Region: Mechanicsburg
Posted: Thu Aug 13, 2015 2:06 pm Post subject: Made it to pa |
And I love it. Great little boat. Thanks Alan |
