trim tab problem
mans gave
PostPosted: Mon Jul 06, 2015 6:19 pm    Post subject: trim tab problem Reply with quote
I have a 2012 sea hunt bx22 pro , my problem is trim tabs no sound no movement both sides I can't locate my fuses to them first I looked all over the backside of the boat no inline fuse can Someone suggest where I look there is box underneath the cc where my switch is located do I remove it maybe it's on top thanks
PostPosted: Mon Jul 06, 2015 7:16 pm    Post subject: Reply with quote
Your are probably going to get a better answer on "The Hull Truth". There are a number of Sea Hunt owners there. This group is about C Dorys.
You are going to find a fuse somewhere in the circuit. Most likely it will be in the power to the accentuates. As I recollect in some of the CC boats like yours, there are two fuses--one for the control circuit and one for the actual hydraulic motors (Assuming that your tabs are hydraulic--if electric then they may also have secondary fuses)--good idea to give brand of Trim Tabs.
Regards,
mans gave
PostPosted: Mon Jul 06, 2015 7:39 pm    Post subject: trim tab problem Reply with quote
Thanks for information I'll give hull truth try thanks again
Page generation time: 0.0429s (PHP: 38% - SQL: 62%) - SQL queries: 16 - GZIP disabled - Debug on
