Trailer tire wear/alignment, etc. questions.
PostPosted: Mon Jun 08, 2015 2:13 pm    Post subject: Trailer tire wear/alignment, etc. questions. Reply with quote
Hi folks,
I'm starting this thread to ask some questions about trailer tire wear and possible measures to take to correct things (if necessary). As background, I read these two threads (the first one is especially good), but I still have a couple of questions and decided to start a new thread for this time.
http://www.c-brats.com/viewtopic.php?t=12023&start=0&postdays=0&postorder=asc&highlight=
http://www.c-brats.com/viewtopic.php?t=21750&start=0&postdays=0&postorder=asc&highlight=
I have a galvanized, tandem-axle trailer for my C-Dory 22. It tows beautifully, and I tow it with appropriate tongue weight (about 7.5%), and it is level fore-and-aft when I am towing. It's within weight ratings on trailer and tires. I have radial tires. I keep a close eye on the pressure when towing, and inflate them according to the load weight. I weigh the whole kit-and-caboodle pretty oten, just to keep tabs on things. IR thermometer shows no excessive heat on bearings or tires when running.
Right now I have around 17,000 miles on the trailer tires and they are around 3.5 years old. I am planning to replace them soon (age), and so I was giving them a close look-over. I noticed that one tire (right rear) has worn more than the others - on its outside edge. Here are some photos showing each tire, with notes. Then my questions below that.
Going around counter-clockwise from left/front:
Left front:
Left rear:
Right rear (the "bad" one):
Right front:
So my first question is how bad is this in "real life." What I mean is, obviously the right rear is compromised and I am getting all new tires anyway, but is this "normal" on a trailer? I mean, does one just have to "settle" because trailers are not that precise? Or is this something a particular person (me) should have corrected?
I will be taking the measurements suggested in the first linked thread tomorrow when I am at the boat, so I will add that information then (but posting now in case there is something else I should check that you all will recommend).
It was suggested that an outside wear like this may indicate a camber problem, but the someone else asked how do you even adjust camber on a trailer and there were no more postings to the thread. So.... can you adjust camber on these?
A little more information on the trailer:
The axles are sprung (not torsion). The springs on each side (forward and aft springs) ride together on a "carriage" that is all one piece. So there is the one-piece "carriage" for each side of the trailer. Then the axles are attached to the springs with U-bolts in about the center of the springs' downward arc. In addition to taking measurements tomorrow, I will check to make sure nothing has moved (I should be able to tell by marks/dirt/etc.).
I'd like to get this figured out before I start in on my four new tires.
Thank you,
digger
City/Region: Spokane
Vessel Name: C-Sik
Photos: Snoopy-C
PostPosted: Mon Jun 08, 2015 2:34 pm    Post subject: Reply with quote
See if the axles are parallel to each other. I suspect that the right side of the pair is slightly closer together than the left . That could be making the tire on the right rear want to turn left, with the result being that the tire is pulling the tire inward, slightly rolling the tire sideways causing the tire to scrub the outside edge.
digger
Vessel Name: C-Sik
Photos: Snoopy-C
PostPosted: Mon Jun 08, 2015 2:36 pm    Post subject: Reply with quote
PostPosted: Mon Jun 08, 2015 3:31 pm    Post subject: Reply with quote
If you got 17,500 miles out of those tyres, enjoy it. Those worn edges might be from loading, slightly misaligned axles or road camber. Don't worry is the only advice I have.
jbdba01
PostPosted: Mon Jun 08, 2015 3:45 pm    Post subject: Reply with quote
X2...I never get that many miles out of mine.
PostPosted: Mon Jun 08, 2015 4:14 pm    Post subject: Reply with quote
Thanks for the advice so far. Digger, I will measure the axles tomorrow when I'm at the boat - nice to have something to "look for."
Sounds like 17,000 miles is decent, but I still would prefer that one tire not wear so oddly (and obviously it started some miles ago). Since I'm getting new tires, maybe I can keep it from happening to the new ones. I'll check things out, but know there is likely nothing horribly awry.
Any more input: I'm all ears!
PS: Side rant: In my tires of choice, I've called like five places that stock them, had them look at the date codes, and they are already over a year old. That's a huge percentage of the tire life! The weird thing is that when one of the places got in a new truckload, they were ALSO over a year old (right from China apparently). I can live with changing them every three years or so, but gee, let's not start with them 33.3% gone due to age!
I found one place that MAY be able to get me a set of four that are six months old...
Trailer tires.... Cry I'd happily pay more for a really good set, but they don't really seem to exist (at least not in my size).
Okay, just had to get that out of my system.
Montana Kev
City/Region: Bozeman/Yellowstone
State or Province: MT
Vessel Name: Grace
Photos: Grace
Sunbeam, I just replaced the two tires on my single axle load rite trailer due to dry rot/age. The tires only had an estimated 3000 miles on them but they were probably 10 years old. The wear was on the outside identical to your 3rd tire photo, the one with the most wear. It will be interesting to see what the experts here advise.
PostPosted: Mon Jun 08, 2015 4:15 pm    Post subject: Reply with quote
Nice to know that any information gleaned may be able to help you as well Thumbs Up
lloyds
City/Region: sublimity
Vessel Name: undecided
PostPosted: Mon Jun 08, 2015 4:29 pm    Post subject: Reply with quote
I had one on my tandem axle trailer that did the same thing, without a lot of miles, maybe 8 - 10 thousand. Wish I knew why. Can't find anything wrong.
Aurelia
City/Region: Gig Harbor
Photos: Aurelia
PostPosted: Mon Jun 08, 2015 5:04 pm    Post subject: Reply with quote
If alignment is good, I was going to point to road camber for the relatively higher wear on the outer edges. More so on the right if you are a slow lane cruiser most of the time. I have seen this with travel trailers but it should be minor and that looks to be the case here.
Greg
Greg, Cindie & Aven
Gig Harbor
Ari - 19 Cruiser sold 2023
PostPosted: Mon Jun 08, 2015 5:08 pm    Post subject: Reply with quote
I definitely favor the right lane when towing. Basically only move to the left to pass or sometimes to the center when going through an area with a lot of off/on traffic.
Although if it were from road camber, then wouldn't you would think it would be on both right side tires, when instead, the right front has only slight wear, but it's actually on the INSIDE of the tire.
As mentioned above, I'll measure things tomorrow and report back (but of course we can still talk about it in the meantime).
PostPosted: Mon Jun 08, 2015 5:21 pm    Post subject: Reply with quote
Sunbeam,
I can't help you with the tire wear. I missed that part of the Holiday Inn experience, but I did go check mine and they look even so far, 2 seasons. I have a friend who decided to quit messing with ?? trailer tires from China and put truck tires on his trailer. Weight load equivalents, better sidewalls and better mileage. Might be an option. I know you put on a lot of miles compared to some of us.
One thought, You have a tandem trailer, are you in a place where you are backing around tight corners, especially to the right, or forward sharp to the left? That would scrub that Right rear on the outside, but I would expect it to be even wear on all, though.
PostPosted: Mon Jun 08, 2015 5:28 pm    Post subject: Reply with quote
Just curious: Any idea of the mileage?
I think that might not be an option for me due to 13" wheels. If I ever replace the trailer, I'd go 14" wheels for the better tire selection, but this one tows so nicely (and I have it all fixed up with upgraded parts) that I'm not motivated to do that too soon - I mean, unless there is some additional compelling reason.
I don't think so, basically because I have no "regular same place" that I back it into all the time. So although of course I back and turn, it's varied.
Now I can't wait to get to the trailer and do some measuring! Tomorrow...
Aurelia
Photos: Aurelia
PostPosted: Mon Jun 08, 2015 6:11 pm    Post subject: Reply with quote
I was reading "outside" of the tire. In general many of the variables like turning directions and camber even out some over time but if you travel similar roads a similar way, that is an element of consistency and consistency can lead to wear patterns. We have all seen sections of highway with grooves worn into the lanes. What if you drove those lanes regularly and had a preferred lane position that put you to the outside of that lane. Could your tires ride the grooves in a way that would wear them faster in some sections and slower in others? Yep. Do any driving variables of this type play into your travels with the boat trailer?
Assuming correct axle alignment of course.
I would not discount the possibility of tire specific build issues if you see wear that can not be related to logical wear factors. I am constantly thinking about tire wear on my two wheeler but there are other factors at play there. We think trailers go through tires.... Motorcycles are even worse. Imagine a set only lasting a week or month.
Greg
PostPosted: Mon Jun 08, 2015 7:03 pm    Post subject: Reply with quote
I don't tend to drive any roads consistently - just because I'm out and about and take varying routes. But, I do appreciate your analytical input, as always Thumbs Up
Now I'm just primed to get over there and measure!
Page generation time: 0.1314s (PHP: 27% - SQL: 73%) - SQL queries: 28 - GZIP disabled - Debug on
