SENSEI
Joined: 01 Nov 2003 Posts: 1067 City/Region: Stanwood
Vessel Name: SENSEI
Photos: SENSEI and SERENITY
Posted: Sat May 30, 2015 3:08 pm Post subject: Bottom Paint Needed For One Month @ Everrett Marina |
Looking at getting a slip at Everrett Marina for about a month. Generally trailer the boat so no bottom paint on it now. Think it is needed for a month stay in the slip with going out on the boat about 4 days a week with fishing movement? Thanks _________________ Roger on the "SENSEI"
1993 22 Cruiser (sold 2014)
1983 22 Classic (sold 2017) |
Will-C
Vessel Name: Will-C
Photos: Will-C
Posted: Sat May 30, 2015 3:38 pm Post subject: Bottom Paint Needed For One Month @ Everrett Marina |
We go to Florida for the month of February for the last five years. I wax the bottom with regular car type Turtle wax before we go. After a month in the water in the keys we pull the boat and if possible pressure wash the bottom. We just start to get little white spots (barnacles) starting I guess. I just polish the bottom again when I get home. I use a plastic scraper to remove anything that does not rub off. Then make sure anything that was there is gone and the whole bottom is waxed. I would not think the Northwest would as bad as Florida for bottom growth. Moving the boat frequently has to help.
lloyds
Joined: 02 Aug 2005 Posts: 1724 City/Region: sublimity
Vessel Name: undecided
Posted: Sat May 30, 2015 4:59 pm Post subject: |
I have done up to a month without bottom paint. The bottom itself sometimes gets the odd barnacle started but not many. The sides are the worst part, they get lots of slime and green stuff. A double coat of wax ought to solve that. There is certainly some cleanup to do at the end of the month but not as bad as you would expect. |
Posted: Sat May 30, 2015 5:02 pm Post subject: |
We left our Avon in the water for 2 weeks in the Chesapeake and it took a couple of hours to scrape off the growth. We also had a Catalina 25 sailboat in the Sacramento Delta for a couple of weeks and it also took hours to clean off the hull with a solution of phosphoric acid.
That said, putting bottom paint on is a major undertaking if it's the only time you'll need it. And note that the PNW isn't like either of the places I mentioned or Florida.
My suggestion is that you try Will-C's waxing and pull the boat for a day after 2 weeks, let it dry and look at it. If it looks good put it in for the last 2 weeks. If not, clean it and try another 2 weeks. The truck and trailer will be handy and the ramp at Evert is easy to use, except on a Sunday afternoon. Or you can look over the side when it's in the slip, but that doesn't give you the bottom view.
Boris |
Foggy
Joined: 01 Aug 2013 Posts: 1521 City/Region: Traverse City; Northern Lake Michigan
C-Dory Year: 2014
Photos: W B Nod
Posted: Sat May 30, 2015 5:53 pm Post subject: |
Here's a KISS cure for a dirty bottom whether bottom paint is
present or not.
Don your mask, fins and snorkel. Water chilly? Don a wetsuit.
Get in the water and scrub your hull, trim tabs and speed/depth
with a plastic scrubby.
Once a week should do it.
Your engine lower unit(s) should be clean if you rinse it/them
after use and keep 'em "up".
Aye. _________________ "I don't want any cake" - said no one ever.
If someone tells you they don't eat cake, unfriend them. You don't need that kind of negativity in your life.
miss ellie
State or Province: ME
Vessel Name: Miss Ellie
Posted: Sat May 30, 2015 5:54 pm Post subject: Bottom paint for a month |
In the Bay of Maine (Mid-coast ME, USA) we leave our 22 on a mooring from June 15 through October 1. In mid August we leave for a week so pull the boat, take it to a nearby boat yard and have the bottom pressure washed. This completely cleans the bottom, and by end of season the growth is rather light, so a quick pressure wash gets the bottom squeaky clean. This yard uses a little ingenuity to lift the boat enough to clean the contact points with the trailer, so there is no charge for a hoist or the Travel-lift.
The cost to do this for 5 to 7 seasons is about equal to a full bottom paint job. Plus, no bottom paint downside, such as repainting every two years, paint rubbings on the trailer and dock, and paint chemicals leaching into the water.
Hope you find this helpful. |
Larry H
C-Dory Year: 1991
Photos: Nancy H
Posted: Sat May 30, 2015 8:53 pm Post subject: |
The Everett Marina has fresh water coming down the Snohomish River. It even freezes in the winter. This helps to keep the salt water growies away. Even if you have to pressure wash after a month, that's less work than bottom paint. _________________ Larry H
A C-Brat since Nov 1, 2003
Posted: Sat May 30, 2015 11:58 pm Post subject: |
I would not consider bottom paint there. You may have some cleaning to do, but once you have bottom painted, it is difficult, and can be expensive to go back to bare gel coat.
To do bottom paint properly, I suggest epoxy barrier coat. Not so much for boats which are kept in the PNW, but when you sell the boat, that question should/will be asked. In warmer climates it is best to have barrier coast to prevent osmosis. (Osmosis certainly can occur in the PNW). _________________ Bob Austin
Foggy
C-Dory Year: 2014
Photos: W B Nod
Posted: Sun May 31, 2015 8:04 am Post subject: |
Best bottom treatment I've experienced on fiberglass hulls both power and
sail for decreased friction and increased performance in saltwater and fresh:
Primer: Interlux Interprotect 2000E with Microplates - epoxy based with
overlapping microplates to protect fiberglass hulls from osmotic blistering.
Bottom paint: Interlux VC Offshore - dries fast, smooth and hard, love this stuff.
I've spoken to various dealers who swear by this system for the best protection
in salt and fresh water. And, it's hard so it won't rub off on your trailer rollers or
bunks. And, yes, it is pricey but, what's the alternative?
Aye.
Grandpa used to say, "You get what you pay for." |
Posted: Sun May 31, 2015 10:49 am Post subject: |
Sounds like you've had great success with VC Offshore. A couple of things to check on though for the OP. They don't list trailerable boats as candidates, and it looks like the maximum time to immersion is 30 days. I think this may be because vinyl loses (at least some of) its anti-fouling capabilities after 30 days out of the water. This may be why they don't mention trailerable boats in the recommended uses. Might be worth a call to them as they are not exactly trumpeting that information on the data sheet.
Another thing with vinyl-based paints (VC-17 is very popular where I'm from) is that they can't go on over any other paint, and no other paint can go on over them. When I moved my boat to salt water, I had to strip off every bit of VC-17 for this reason (I wanted to put a different paint).
I haven't used VC Offshore, but I can certainly say that the VC-17 was a smooth, "fast" paint. Made a beautiful job. Also easy to apply. However we had to reapply each spring, "whether it needed it or not" (looks-wise) due to the "out of the water too long and it deactivates" property. And this was in very low-fouling area.
You can get to the product datasheet (and other info) from here:
http://www.yachtpaint.com/usa/diy/products/antifouling/vc-offshore.aspx
For me, for 30 days in colder waters (even though there is some fouling there), I would definitely not bottom paint, and just take a look at things (also raise motor when not using boat). Usually the worst growth will be near the waterline (at least in places I have been), so you can see how its going.
I have seen the "turn your back for two weeks and now dinghy weighs 3,000# due to billions of barnacles that will be very VERY hard to remove" phenomenon, but that was on the Chesapeake in hot, late-summer weather (super-fouling area!). |
Foggy
C-Dory Year: 2014
Photos: W B Nod
Posted: Sun May 31, 2015 11:04 am Post subject: |
I read that stuff about VC Offshore not being for trailerable boats.
It's 'hoey' IMHO. Maybe just a 'CYA' statement also.
Before applying the 2000E and the VC Offshore, I addressed all this
with a C-Dory factory rep and should I use it. Their reply "Definitely."
The CD factory applied it knowing it was going on a trailer. As on
other boats I've used it and love that stuff.
Sorry though. No R&D data.
Aye. |
Joined: 01 Mar 2005 Posts: 7445 City/Region: from island boy to desert dweller
Posted: Sun May 31, 2015 10:49 pm Post subject: |
Hi Roger. When we first picked up our C-Dory, we spent a couple months cruising in the PNW. With no bottom paint. The cold water there and regular movement of the boat made for very little clean-up. That same amount of time on the Gulf Coast would have made for an awful mess.
I did put bottom paint on it as soon as we brought the boat south.
That said, I would think you will be good with the circumstances as you describe. Have fun with the boat in a slip - easy to get out there!
Jim |
PaulNBriannaLynn
Joined: 26 Oct 2012 Posts: 757 City/Region: Fort White
Vessel Name: TBD
Photos: Lorelei
Posted: Mon Jun 01, 2015 12:34 pm Post subject: |
Hey Roger,
Last Fall we had our boat at the Everett marina for a full two months during September and October. No bottom paint. We'd use it about 2 or 3 days a week during that time with an odd week off here and there.
There was some green fuzz or maybe slime is a better term, but nothing else. I used a pressure washer and was able to spray off everything at the end of October.
We prefer the slips on the south end of the marina so its a faster run to get to the fish, but I've been told the slips on the northern end of the marina have much more freshwater in the mix, so that's something to consider. Either way its not a big problem! |
tcr_pnw
Joined: 05 Jan 2013 Posts: 200 City/Region: Puget Sound
Vessel Name: Sea Star
Photos: Sea Star
Posted: Mon Jun 15, 2015 6:25 pm Post subject: |
I moor in Everett from May through September/October without bottom paint. I pull it out once every 3-4 weeks and spray on some Starbrite Hull Cleaner. Let it sit for a few min, lightly scrub with my boat brush and rinse off. If you don't let the marine growth dry, it comes off clean and easy. I do it right there at the wash down area. If i take the 20 min drive home, its a pain. No issues with barnacles.
Using the boat 2-3 times per week keeps the growth down. |
Dreamer
Joined: 01 Jan 2006 Posts: 1764 City/Region: Really Sunny SaddleBrooke
Photos: Dreamer
Posted: Mon Jun 15, 2015 6:44 pm Post subject: |
I'd pay for a photo of Roger in his Wet Suit _________________ Roger
Dreamer- Sold 25 Feb. 2013 |
