Larry Patrick
Vessel Name: Sea -Jo
Posted: Sat May 23, 2015 9:13 pm Post subject: Second anchor suggestions |
The 23 venture has a 25lb manson supreme. I will check archives also. I would like to have an emergency anchor ,if windlass got jammed or just to have a second anchor. Wife will be nervous to be anchoring overnight,not in a marina. I like the idea of being able to drop another anchor if ever need to. Will probably keep it in a milk crate ready to go. Would a 7lb fortress be good? Not sure where will be boating Lake erie, Cayuga ,Chesapeake,florida ect. What anchor grabs in most conditions,also can use it when backed into shore,like everyone does at lake powell. With a single motor feel like a second anchor should be on board. Thanks for ideas. |
Posted: Sat May 23, 2015 9:47 pm Post subject: |
Absolutely the Fortress FX7 is what I have for back up, and stern. Actually two are the fortress, and the 3rd is the Guardian 7. One of the Fortress I got at a neighbor's garage sale for $5 (it was a bit corroded but cleaned up well.) These anchors only weigh 4#. _________________ Bob Austin
Lost Petrel
Joined: 10 Aug 2014 Posts: 138 City/Region: Potter Valley
Vessel Name: Wild Blue
Posted: Sat May 23, 2015 10:20 pm Post subject: |
I also picked a Fortress for back-up, good for that especially since will try and get to Powell this year. _________________ Tim
http://lostpetrel.blogspot.com/
Other boats;
Cape Dory Typhoon
Pearson Ariel
My Galleries |
Steven Dore
Joined: 08 Apr 2004 Posts: 100 City/Region: Ocean Marine - Portsmouth, VA
Vessel Name: Orca
Photos: Orca
Posted: Sat May 23, 2015 10:43 pm Post subject: |
The Fortress is a good choice for sand and mud, but not for rocky bottoms. I boat on the Chesapeake and have been using a Fortress FX 11 for the bow and a Fortress FX 7 for the stern, since 2004. They set easily and hold firm. |
Larry Patrick
Posted: Sun May 24, 2015 11:11 am Post subject: |
Thanks for informed replys,will be ordering one. Defender marine says the magnesium alloy is stronger than the others,are you guys using the magnesium alloy,or which metal are you suggesting thanks. Any suggestions where to order. Also the 4lb fortress fx7 should be sufficient for the heavier 23 venture? |
Posted: Sun May 24, 2015 1:40 pm Post subject: |
I would think that with that light of an anchor (4-7#) it would be a good idea to have at least a boat length of chain or a sentinel to keep it dug in. Or am I thinking "Over build" again?
SleepyC
Posted: Sun May 24, 2015 1:46 pm Post subject: |
We are suggesting the Fortress or Guardian. Here is the difference according to Fortress:
Quote: | Benefiting from years of Fortress Anchor Research and Development, Guardian offers excellent quality, performance and economy. Guardian is made from the same high tensile, corrosion resistant aluminum magnesium alloy and manufacturing precision as Fortress.
The use of slightly smaller extrusion profiles and the elimination of some of Fortress' extra features, such as anodizing, adjustable fluke angles, and several machining steps has resulted in a very affordable alternative to those heavy, rust-prone steel anchors.
Features:
Made of aluminum magnesium alloy |
The Guardian 11 is $90 at Defender, and the Fortress FX is $137. There is the second angle (mud angle of 45 degrees, vs the 32 degrees for the standard "sand".
The Fortress looks nicer initially, and should have less corrosion due to the anodizing. I just sold a FX 16 for $100 plus shipping (about $25)--too big for the C Dory, but I had used it on a 30 footer as primary anchor. I have owned it for many years, but not used a lot. It looked like new. If you anchor a lot in thick soupy mud--and these is some in the Chesapeake area, then go with the Fortress. The Fortress tests show a 840 holding power in soft mud, the Guardian only 420 for the 7 The 11 is 1080 vs 540.
Take that for what it is worth--the difference is the 45 degree fluke angle, not the different in the anchor themselves. I feel that the FX 7 is adequate for the 23 (and the 25, especially as a stern anchor--and I used the FX 7 as stern anchors on my C Dory 25).
Yes, they are not as good in rocks--no question. The SuperMax, the Manson, the Boss, and the Bruce style are better in these.
Although I used the HT Danforth for many years, I favor the Fortress now. |
Posted: Mon May 25, 2015 1:28 am Post subject: |
It may be overkill, but I use a Fortress FX-16 plus 100 feet of 1/4" GS40 chain (and 250 feet of 1/2" 3-strand nylon rope) on my CD-22.
Seems to hook up anywhere, anytime.
Some of these steep walled reservoirs like Shasta Lake, have a mixed bag of rocks, sand, mud, clay, and more on their bottoms, which, combined with the steep gradient and narrow coves in which room to anchor and put out a lot of scope is at a premium, makes one want to hook up good and fast.
The FX-16 seems to do the job. And I'm sue the chain is a major factor in making it work.
The biggest "hang up' is when you manage to hook in to an old stump, pine or oak tree, but that's another story I have logged away on this web site about 8-10 years back in time.
roydawn
Joined: 24 Jun 2012 Posts: 45 City/Region: No Fort Myers
Posted: Mon May 25, 2015 7:56 am Post subject: |
For my 25, I use a Fortress fx 11 for my back up anchor. 25' of chain & 200' of rode. Works like a pro in Fl. Roy |
Larry Patrick
Posted: Mon May 25, 2015 11:18 am Post subject: |
Thanks for informed answers,cant beat expierence. |
anchorout
Joined: 03 Jul 2013 Posts: 357 City/Region: Lake Charles
State or Province: LA
Vessel Name: EZ DUZIT
Photos: EZ DUZIT
Posted: Mon May 25, 2015 1:20 pm Post subject: fortress |
These Fortress anchors are excellent, especially for folding spares. I had a sizable one on my Morgan 33, and because of their being so light, I used one as both a stern anchor and a backup primary ( double duty).
But, beware. They are aluminum. They will tend to slide along the bottom in some situations. It is important you use a good length of chain to help it dig in and hookup.
I was once anchored inside Cat Kay Cut in the Bahamas. A squall blew through the anchorage. I watched a sailboat being blown backwards through the fleet, ending up off the banks, back through the cut and luckily, missing the reef, back out into the ocean. The captain was kneeling on the deck the whole time tending the anchor line and trying to make it set. Talking to him later, he had lost his primary anchor somehow, had assembled the Fortress and hurriedly tied it on without chain. No matter what he tried, it would not set.
I had 50ft of chain on mine and it always set quickly and held tenaciously. _________________ I DON'T KNOW WHAT I'M LOOKING FOR - That's what makes the search so exciting! |
Posted: Mon May 25, 2015 1:59 pm Post subject: |
In line with what anchorout said, I carried a Fortress 7# for years. And then I tried to use it in some kelp at Santa Cruz Island. The damn thing was too light to set and I didn't make too many friends as I drifted. Had 25' of 1/4" HT chain on it. Great for sand or mud, not so good when you really need an anchor to dig in. A light anchor is nice to look at, but when you need it to really dig in, you need weight.
I now have a West Marine Danforth copy, galvanized steel that's twice as heavy and half the price and works well in rock and kelp. Any day now I'm going to get a real Danforth, but this WM one does work well. I'm convinced that the Danforth steel type is the best all around anchor.
I also bought a Manson Supreme for it's sharp points to dig in. And I took it up to the PNW which has a lot of mud and sand. That sucker was thin enough to just slide through the mud. Worked well in kelp and rocks, though.
I use the Bruce for mud, which has wide flanges to hold the mud though those flanges are too blunt to set in kelp.
Boris |
Posted: Mon May 25, 2015 4:40 pm Post subject: |
Anchors are like religion. There are lots of individual opinions. It is best to carry several types. Weight is great--except in some small craft, it becomes counter productive.
Anchoring is an art. I have had anchors not set, but left it out anyway. Got another anchor to set, and then work up in the morning, to find that the one anchor I thought had set, with good reverse power, had drug thru the night, and the one I thought had not set, we dug well in. Often anchors take time to set. There are times when identical anchors will not set in one part of the cove, which seems to have the same bottom as another part of the cove.
Kelp, I have always considered very tenuous anchoring. It is so easy for kelp to break, and the foul an anchor--and it will. Rocks can foul an anchor. One of the best anchors in most all of the tests is the Super Max. Rumor was that it was going to be made again, and today I found a web page which is active. For C Dorys the anchor is made in 9# (boats up to 3000 lbs) ($99) and #18 (boats up to 5,000 lbs) $350. They are difficult to stow.
If my anchor does not hold, or the wind shifts so I feel my boat may be in danger, than I move the boat--even if at 3AM. One night I moved our Cal 46 3 times between midnight and 6 AM due to wind shifts. The wind was blowing almost 90 knots at some points. |
Posted: Mon May 25, 2015 10:19 pm Post subject: |
Bob is correct, as usual. Kelp is really really bad for holding and can't be trusted.
When I started anchoring around Santa Cruz in the '70s, anchorages such as Pelican Harbour were fairly clear of kelp and I could find patches of sand for my (Danforth) anchor to dig in. The last time I was there, last year, there were only 3 boats in Pelican and when I tried anchoring all we could find was kelp. We tried to set the anchor through the kelp into the sand, but I honestly think that all we got was kelp. We found the same conditions at Frys Harbour. I think that fewer boats are visiting Santa Cruz Isl due to the downturn. Now that things are picking up, perhaps enough boats will visit the various harbours to clean out the kelp.
Bob is also correct in that everybody thinks their anchor is the best, just like religion. We left Pelican and went to the Ventura Yacht Club for a day. Every type of anchor was on the bow of the various boats and they all thought theirs was best. Yes, I asked. So when I discuss an anchor I try to give a few reasons why I think an anchor is good for various conditions. I think all anchors have their good and bad points.
Boris |
Posted: Tue May 26, 2015 1:24 pm Post subject: |
I don't remember if Boris had the benefit of boating in the channel Islands in the 1940's and 50's--or even the 60's. Back then there was a lot of harvesting of the kelp in the channel Islands. There were a fleet of "kelp Cutters" who would go out every morning, and bing back many tons of kelp in the evening, where it was offloaded ground up and processed, in San Pedro (not far from where Boris and we had lunch a few months ago. I think that kept the kelp down. The latest regulations in the Channel Island limit a lot of activity (and kelp cutting has not been done for many years.)
Also before the current generation of anchors, it was gospel that you had to have at least a 35 lb anchor to make it set---and a 45 was far better. Of course boats like Jeff Siegel 53 foot Defever, have two 120 lb Ronca's on the bow rollers…so serious cruiser still believe in the weight factor! The exception was the Danforth's which came from the WWII landing barges and weight was about 50 to 75 lbs and were cast, rather than forged:
There were two types of the WW Danforth anchors-the one pictured above, and one which had the "T" inner edge of the fluke, a stock which was removable, with a pin or S shaped wire to hold it in place, with the outer parts of the flukes rounded. I cannot find a single picture of these anchors--and I gave mine away during Hurricane Ivan (I think). Neither of these had the flukes attached to the stock as the modern Danforth type does. The 35 and 50 lb anchors used on the smaller landing craft in the Pacific were sold in mass numbers for about $10 in Wilmington CA right after the war. The bronze ones cost $25! The feature of all of the Danforth was the 32 degree angle of the fluke with the shank. Today that same angle is used in the Fortress, and any of the imitation "Danforth" anchors. |
