Loose Perko connection and blown fuses
skiptowns98033
City/Region: Cornet Bay
Vessel Name: Plan C
PostPosted: Sun May 17, 2015 12:31 pm    Post subject: Loose Perko connection and blown fuses Reply with quote
I had just finished installation of a new depth finder, zip tied all the cable runs and was idling at the dock, looking at the new display menus and admiring my work.
And the engine just............quit. The engine - Honda 90 - wouldn't turn over and I couldn't even raise it. Dead.
Long story short, the nuts on the connections in the Perko switch had worked loose and the arcing was most likely the cause of the blown fuse. When the engine quit last year, we checked the fuses, replaced the one that was blown but never went any farther. It was fortunate that I missed seeing the blown fuse this time -it was hard to see on the bottom corner - so that we had to look for other causes.
It was even suggested the loose Perko connections might have been the cause of the stuttering problem that led me to a new ECU last year..........
SGIDave
City/Region: St. George Island
Photos: SeaDation
PostPosted: Sun May 17, 2015 1:18 pm    Post subject: Reply with quote
Hello Skip,
Your switch as well as battery terminals, etc are all locations which should use a split ring lock washer under the nut OR use a nylock type of nut.
Fair winds and solid electrical connections,
dave
PostPosted: Sun May 17, 2015 2:10 pm    Post subject: Reply with quote
I agree 100% on the lock washer. There have been some cases of melting of the Polymer/nylon, in the Nyloc nut when used in electrical connections due to heat when under high power or a short.
skiptowns98033
Vessel Name: Plan C
PostPosted: Sun May 17, 2015 10:32 pm    Post subject: Reply with quote
Great ideas! Thanks guys!
Page generation time: 0.0526s (PHP: 47% - SQL: 53%) - SQL queries: 17 - GZIP disabled - Debug on
