Honda BF 2 stalling issues
msgchef
City/Region: Washington
Photos: Seaweed
PostPosted: Sat Apr 18, 2015 5:36 pm    Post subject: Honda BF 2 stalling issues Reply with quote
Took the dink out for my first time with the Honda BF 2. A 2005 model Took about 15 pulls to start, I figured its the lack of manual priming. [Pls tell me if I am wrong]. However the trip got worse. The motor stalled approx every 4-5 minutes. Started again with about 5-6 pulls, but ran for the aforementioned 4-5 minutes and just died. Throttle speed was varied when it died. First time full throttle other times different speeds as I tried to find a rhyme or reason. It has only no ethanol fuel, however fuel could be 4 months old.
Any thoughts to assist me in my fix.
thanks
Paul
"There are good ships,
and there are wood ships,
The ships that sail the sea.
But the best ships, are friendships,
And may they always be."
2015-2018 Seaweed
BrentB
City/Region: Greenwood
State or Province: IN
Photos: BrentB
PostPosted: Sat Apr 18, 2015 7:27 pm    Post subject: Reply with quote
I dont know the exact issue.
For outboards, I use a trash can with water when servicing
I would replace the fuel and add the approximate volume of fuel system cleaner ex SeaFoam or equivalent, remove spark plug and re gap or replace it and inspect it for color and condition
I would check the plug is sparking too
if an inline fuel filter is present either clean it or replace. I am thinking it is a fuel issue and check the carb linkage is smooth and no leaks from gaskets, Sometimes the fuel bowl can removed and cleaned and examined for debris or dirt
If it has idle or high jets, the screws can be adjusted when running,'
Sometimes opening the screws to full open with remove blockage when running.
Sometimes running it in water tank for a hour a various speeds with fresh gas and cleaner will help
I dont have a manual for this OB to trouble shoot further
Brent Barrett
tsturm
City/Region: Soldotna
Vessel Name: JMR TOO
Photos: JMR-TOO
PostPosted: Sat Apr 18, 2015 7:45 pm    Post subject: Re: Honda BF 2 stalling issues Reply with quote
thanks
Paul
Tank Vent?? Wink
PostPosted: Sat Apr 18, 2015 8:18 pm    Post subject: Re: Honda BF 2 stalling issues Reply with quote
tsturm wrote:
Tank Vent?? Wink
Bingo!
My thoughts, exactly!
Fuel starvation due to lack of vent open on tank and therefore engine cannot draw fuel against pressure differential.
Most common overlooked fuel draw issue.
Does the motor have an internal tank or a remote?
(Hope it's so simple!!!)
Good Luck!
BrentB
Photos: BrentB
PostPosted: Sat Apr 18, 2015 8:26 pm    Post subject: Reply with quote
Yes I agree and completely overlooked it!!!
shellndanm
City/Region: Chesterfield
Vessel Name: Linda M
Photos: Linda M
PostPosted: Sat Apr 18, 2015 9:25 pm    Post subject: Reply with quote
Assuming the vent is open and you have good gas, I would pull the carburetor off and clean out the jets. The carbs on these small motors are pretty simple and easy to clean
I had a similar problem on the water last year with a mercury 4hp. I watched a video on youtube and cleaned out the jets with wd40( I realize it's not carb cleaner). The engine has run fine ever since.
msgchef
Photos: Seaweed
PostPosted: Sun Apr 19, 2015 9:20 am    Post subject: Reply with quote
There it is... my inexperience, did not open fuel vent on the internal tank.
Thanks so much, glad it was a simple. Will try the trash can test. It'll keep me from the long row home. Embarassed
Molly Brown
City/Region: Punta Gorda
C-Dory Model: 24 Tomcat
Vessel Name: MOLLY BROWN
Photos: Molly Brown
PostPosted: Sun Apr 19, 2015 10:23 am    Post subject: Reply with quote
The beauty of the Honda 2hp is that it is air cooled therefore you can run it "dry" without any issues. I regularly run mine in the barn hanging off a bracket.
James
Completed 01/2025
lloyds
City/Region: sublimity
Vessel Name: undecided
PostPosted: Sun Apr 19, 2015 12:37 pm    Post subject: Reply with quote
Was always curious about running it out of water as it does have a water pump that apparently cools the lower unit. Any chance of damage there?
PostPosted: Sun Apr 19, 2015 3:27 pm    Post subject: Reply with quote
I don't think that it has a lower unit water pump, since the heat generated by the lower unit is friction through the gearing and bearing. If that's significant enough to require active cooling, that motor is wasting a lot of power and needs to be redesigned. And Honda builds good engines. Honda does advertise shallow water running, as a further thought.
Unless you're counting the propeller as a pump, which it is.
Another random thought: could you have noticed the exhaust, which is under water?
lloyds
PostPosted: Sun Apr 19, 2015 5:19 pm    Post subject: Reply with quote
They have an impellar in the lower unit. They say it is to cool the exhaust. I would think running one out of water for any significant length of time would at least melt or damage the impellar. I have had to change impellars a couple of times over the years.
Wefings
Dealer
City/Region: Panhandle
Photos: Cruise Ship #4
PostPosted: Tue Apr 21, 2015 12:51 pm    Post subject: Reply with quote
There is no impeller .Air cooled motor with centrifugal clutch. Those plastic carbs are not real serviceable . They are easily replaced if you let fuel sit in them . Can run dry out of the water no problem .
Marc
Wefings Marine Website
Since 1909
PostPosted: Tue Apr 21, 2015 1:15 pm    Post subject: Reply with quote
Marc
Of course, Mark is correct. I also note that the 2hp Honda has a small screw on the carb that you can remove to drain the carb bowls. You should do that prior to storage for any length of time. The jets in this itty-bitty carb are hard to clean.
msgchef
Photos: Seaweed
PostPosted: Tue Apr 21, 2015 2:48 pm    Post subject: Reply with quote
The things you can learn from this site, you guys are awesome.
Paul
Wefings
Dealer
PostPosted: Tue Apr 21, 2015 4:35 pm    Post subject: Reply with quote
Draining the float bowl is the right way to store any carburettor , thanks Roger !
Marc
Page generation time: 0.0842s (PHP: 54% - SQL: 46%) - SQL queries: 28 - GZIP disabled - Debug on
