Solar charger for winter storage
Doryman
Vessel Name: Lori Ann
Photos: Lori Ann
PostPosted: Mon Apr 13, 2015 3:15 pm    Post subject: Solar charger for winter storage Reply with quote
For part of the year I have my Tom Cat in a storage lot that does not have electric power available. When in storage I run a couple of dehumidifiers (60W light bulb & fan) plus I need to keep the battery topped off. I'd like to get something like the Coleman unit discussed in this thread http://www.c-brats.com/viewtopic.php?t=19787 but i want a complete set-and-forget solution that includes any necessary controllers, etc. Any specific recommendations (manufacturer & product, where to buy) would be appreciated.
Doryman
M/V Lori Ann
Anacortes, WA
PostPosted: Mon Apr 13, 2015 3:30 pm    Post subject: Reply with quote
Do a search on the internet. When I was looking for a charger for the Ford truck, I ordered on from a Chinese importer in Hacienda Heights off e-bay that consisted of the panel (25 watts) and a charge controller (13.6 VDC.) Has worked well.
I don't order directly from China, because when I did that, my credit card was stolen according to the credit union, and had to be replaced.
PostPosted: Mon Apr 13, 2015 9:09 pm    Post subject: Reply with quote
Warren, if you have 110 volt power, why go with a solar charger? There are a number of both good battery chargers, which will maintain a battery, or maintenance chargers. If you don't have 110 volts, and need to use a solar charger, to power the fan, and the 60 watt bulb, then you are dealing with something entirely different--and will need a controller, plus a larger panel.
I have used the very small solar chargers for as much as a year on both my van and the C Dory to keep the batteries topped of, and were fine. Sunforce has been around a long time, and that is the one I used. For the PNW, you have low sunlight, year around, so at least a 7 watt unit would work.
BrentB
City/Region: Greenwood
State or Province: IN
Photos: BrentB
PostPosted: Mon Apr 13, 2015 9:25 pm    Post subject: Reply with quote
Sunforce and Coleman have solutions
Check their web pages
Brent Barrett
Page generation time: 0.0261s (PHP: 64% - SQL: 36%) - SQL queries: 21 - GZIP disabled - Debug on
