smckean (Tosca)
Vessel Name: Tosca
Photos: Tosca
Posted: Thu Mar 26, 2015 3:32 pm Post subject: Any filters in a CD25's water system?? |
One of my projects lately has been to repair minor leaks and blockages in my CD25 water system. I am finding that various small pieces of material are getting lodged in the fittings in some parts of the system. This impedes the water flow -- at times to a mere trickle. Most strange are the small hard "beads", that look like tiny pearls, which especially enjoy getting themselves lodged in one-way valves. These "beads" are maybe 2 or 3 times the size of a grain of sand.
Anyway, does anyone know if there are any filters in a CD25's water system? I've looked and can't find any. I'm thinking of installing perhaps fuel filters in the hot and cold lines to catch whatever gunk might be present.
P.S. If anyone has an idea of what these "beads" might be, I'd be interested in hearing your ideas. |
ghone
C-Dory Year: 2011
Vessel Name: Kerri On
Photos: Kerri On
Posted: Thu Mar 26, 2015 5:28 pm Post subject: |
There is likely a filter attached on or near your water pump. Mine is incorporated into the Flojet housing. The beads may be "hard water" deposits, maybe calcium maybe just crud? Give a good flush to the system.
George |
beermanPDX
Photos: Jean Marie
Posted: Thu Mar 26, 2015 6:24 pm Post subject: |
There is no real filter on my 25, but there is an "inlet strainer". The inlet strainer looks like its part of the pump, but it's really a separate component. It should be what the water hose connects to. Mine looks similar to this:
Mine is mounted on its side, right to the pump inlet. The top spins off and you clean out the metal screen.
Are your white beads all the same size...i.e., man-made or "natural"? _________________ Cheers
Rob
2008 25 Cruiser - Sold
2002 Nordic Tug 32/4 - Sold
1989 40 Tollycraft Sport Sedan |
Dan McNally
Vessel Name: Shannon- Colleen
Photos: Shannon-Colleen
Posted: Thu Mar 26, 2015 8:52 pm Post subject: |
Sounds like hard water to me, I used to get them in my camper toilet. They would collect in the last fitting and impede the water flow when you needed it most. It was a bummer removing toilet to get at the fitting to clean out, it would happen about every five years. So I started checking it before trips and fixing it before it became a problem. |
Posted: Thu Mar 26, 2015 8:58 pm Post subject: |
There are all sorts of filters for a water system. My 25 had a fine mesh screen sediment filter between the water tank and the pump. Par/Japsco makes such a filter. There are many in line RV filters such as above, which will fit in line. They are good for several thousand gallons, and will remove most taste, odors and sediments of i micron or more in size. _________________ Bob Austin
Will-C
Vessel Name: Will-C
Photos: Will-C
Posted: Fri Mar 27, 2015 9:44 am Post subject: Any filters in a CD25's water system?? |
We don't have a 25 but I would recommend you get an inline filter on the hose you fill the boat up with and always use it.. The sediment screens in faucets and in water supply lines are a source of issues. Like I have no water! Then clean sediment screens. Then it's, look Ma there's nothing wrong with our fresh water pump. Some folks pull the filters after the pump to eliminate the issues except for the last one on the faucet which is easily blown out.
smckean (Tosca)
Vessel Name: Tosca
Photos: Tosca
Posted: Fri Mar 27, 2015 12:28 pm Post subject: |
Quote: | Are your white beads all the same size...i.e., man-made or "natural"? |
I don't think they are man-made. They look like they are the result of some sort of deposition process; however, it is striking that they are as roughly spherical as they are, and that they are so similar in size.
We do have mildly hard water here on this island that the previous owner and I live on. So the water tanks have often been filled with "hard-ish" water; so certainly that could be the source of the calcium or whatever the underlying substance is. The beads are quite hard (as a calcium deposit would be I suppose). I tried to bite one once with my teeth, and gave up when I thought my tooth might be damaged before the bead .
Thanks all for the tips of where to look for a filter. I was looking for a separate unit somewhere in line in a hose. I will look at the water pump etc. I'll post here what I find. |
smckean (Tosca)
Vessel Name: Tosca
Photos: Tosca
Posted: Fri Mar 27, 2015 12:32 pm Post subject: |
Quote: | Sounds like hard water to me, I used to get them in my camper toilet. |
Dan, do you mean by "them" these little, roughly spherical, hard as a rock, pure white beads? |
Dan McNally
Posted: Sat Mar 28, 2015 8:25 am Post subject: |
Yes that is what I mean. The ones I encountered had more then one color though and where slightly larger then a grain of sand. They never caused any real issues until they would restrict the function of the toilet. They did not damage any thing they just stopped the water flow. |
rjmcnabb
Joined: 01 Sep 2007 Posts: 159 City/Region: Pender Island (Southern Gulf Islands)
Vessel Name: Luna
Posted: Sat Mar 28, 2015 11:55 am Post subject: |
Dan,
Do you use a water softener? Yours sound suspiciously like resin beads.
Rod _________________ Rod & Jane; Victoria 18 sloop (Vickie) - gone; Islander 26 Bahama sloop (Callisto) - gone; WW Potter 19 sloop (Spring) - gone; Com-Pac 16 sloop (Bummer II) - gone; Nimble 24 yawl (Chatelaine) - gone; Nimble Vagabond cruiser (Loligo) - gone; C-Dory 22 Cruiser (NoddyBleu) - gone; Com-Pac 19 sloop ('Winkle) - gone; San Juan 24 sloop (Loligo^2) - gone; C-Dory 16 cruiser (Luna); Catalina Capri 18 sloop (Later) |
smckean (Tosca)
Vessel Name: Tosca
Photos: Tosca
Posted: Sat Mar 28, 2015 6:47 pm Post subject: |
beermanPDX said:
Quote: | There is no real filter on my 25, but there is an "inlet strainer". |
I have no such filter/strainer near the pump; nor can I find any sort of filter/strainer anywhere in the water lines from the tank to the last fitting.
The original factory installed FloJet water pump must have been replaced by the previous owner. There is a Jabsco Par Max 2.9 installed now. I'm going to assume that the water filter/stainer beermanPDX speaks of was removed at that time (likely to create more room near the hot water heater).
I will check around for a new Jabsco, or Shurflo, or other water filter/strainer to install (assuming I can squeeze it in somewhere). |
Alyssa Jean
Joined: 02 Nov 2003 Posts: 2375 City/Region: Guemes Is.(Anacortes)
Vessel Name: Alyssa Jean
Posted: Mon Mar 30, 2015 11:41 am Post subject: |
Sandy,
If it is just an inline type filter it could possibly be installed in the compartment under the dining table. The hose from the tank runs along the port side to the pump. _________________ David and Kate
Alyssa Jean 16 Angler
K7KJR C-Brats #51 |
Posted: Mon Mar 30, 2015 10:39 pm Post subject: |
There are several places where the filter can be installed, but be sure it is before the pump.
One thought about filtering water you put in the tanks, of C Dorys: you want to not use a Charcoal type of filter, which removed chlorine. I want to have the residual chlorine to avoid any bad guys from growing in the tank. However, I do use a particulate filter when filling tanks on boats and RV's. In line when from the water tank, or with a Brita filter, we do filter the final drinking water. |
smckean (Tosca)
Vessel Name: Tosca
Photos: Tosca
Posted: Wed Apr 01, 2015 11:43 am Post subject: |
Quote: | If it is just an inline type filter it could possibly be installed in the compartment under the dining table. |
Nope. I've looked thoroughly from the water tank to the pump. It's possible I guess, but I can't imagine I missed it.
My guess is that you had to remove it when you replaced the water pump (2012?). I'm going to guess that the Jabsco ParMax you used to replace the FloJet was bigger, and given the additional pink hard insulation around the water heater, there just wasn't room for a filter. My plan is to install a filter in that compartment under the dining table. It looks like there is room there.
BTW, I'm presuming the lack of a filter/strainer is the reason that I have been having problems with water flow to the galley due to clogged fixtures (all fixed now). |
