DARN Racor filter
Jake
PostPosted: Mon Mar 16, 2015 8:57 am    Post subject: Reply with quote
Maybe someone could refresh my memory. Probably nothing to do with outboards but aren't there certain installs where the racor (filter with drain) are not permitted?
Jake
Chester
City/Region: home
Photos: Chester
PostPosted: Mon Mar 16, 2015 10:44 am    Post subject: Reply with quote
Can't have the clear bowl on inboard engine applications. They have a metal bowl with a drain that is OK for those applications.
Jake
PostPosted: Mon Mar 16, 2015 11:07 am    Post subject: Reply with quote
Thanks Chester, I wonder why the difference?
BrentB
City/Region: Greenwood
State or Province: IN
Photos: BrentB
PostPosted: Mon Mar 16, 2015 11:40 am    Post subject: Reply with quote
I have read that Aquabloc is chemical treatment to the filter media.
This article
at
http://continuouswave.com/whaler/reference/fuelFilter.pdf
None of the tested filters will stop water once the filter is full and each filter tested will trap at least one and half cups of water before allowing it to pass to your OB
Brent Barrett
Larry H
City/Region: Tulalip,
C-Dory Year: 1991
Photos: Nancy H
PostPosted: Mon Mar 16, 2015 1:56 pm    Post subject: Reply with quote
Jake,
Inboard gasoline engines and fuel systems are regulated by the US Coast Guard. Those regs do not allow for plastic bowls and drain valves.
Outboard engine boats are exempt from those inboard regs.
For maximum safety, follow the inboard regs.
Larry H
A C-Brat since Nov 1, 2003
Blueback
City/Region: Qualicum Beach, Vancouver Island
C-Dory Year: 1990
Vessel Name: Blueback
Photos: Blueback
PostPosted: Mon Mar 16, 2015 5:25 pm    Post subject: Reply with quote
Larry H wrote:
Both Mercury and Evinrude sell a fuel filter that has a screw on metal canister. (Like an oil filter)
No plastic bowl or drain to worry about.
Right on Larry,
I have a Mercury with no problems.
I'm in the third stage of life:
1-Learn to catch fish.
2-Catch fish -hopefully-
3-Work at rebuilding the endangered runs of salmonids on the West Coast
AstoriaDave
City/Region: Astoria
PostPosted: Mon Mar 16, 2015 6:07 pm    Post subject: Reply with quote
Jake, An IB installation has the fuel filter within the engine housing, open to the bilge. If a plastic or glass bowl broke, fuel would flood the bilge. On an OB installation, typically the filter is external to the bilge and cockpit, and the fuel would go overboard. Still better to have a metal unit, IMHO.
Dave Kruger
Astoria, OR
Blueback
C-Dory Year: 1990
Photos: Blueback
PostPosted: Mon Mar 16, 2015 6:35 pm    Post subject: Reply with quote
The fuel may go overboard on some OB installation via the splash from a bowl failure, but not on mine as I don't consider that the ideal location for the filter. Secondly spilling fuel overboard is not good either from an environmental point of view. A metal filter canister gets my vote.
Geoff
PostPosted: Mon Mar 16, 2015 10:45 pm    Post subject: Reply with quote
The clear bowl can also help to check for water in the fuel system. A solid metal canister without a drain only allows you to check for water by taking the filter off.
You could have a separate water separator, but those usually have bowls and drains which seem to be inappropriate in some installations.
PostPosted: Mon Mar 16, 2015 11:45 pm    Post subject: Reply with quote
When the clear bowl is in the Lazarette, (as in many of the C Dorys) there is some slight risk of fuel spill, but not the explosion risk that an inboard boat has however. Since I regularly check the bowl as part of the pre start inspection, I consider this risk minimal…and acceptable.
As for letting water thru--I had an incident where there was minimal water in the Racor, but the water separator of the outboard was full. I suspect that it was a little water over a long time. I was not checking the water seperater in the fuel line under the cowl of the outboard as often as I should have been.
Jake
PostPosted: Tue Mar 17, 2015 8:48 am    Post subject: Reply with quote
Larry H wrote:
Jake,
I wonder if it depends on boat size. I see quite a few yachts on boattest.com with inboards and plastic bowels and drains. Maybe different for diesels? Just curious. My stern drive has the full metal with no drain but would be nice to have visual and ability to drain rather than just change every year.
AstoriaDave
PostPosted: Tue Mar 17, 2015 10:24 am    Post subject: Reply with quote
Jake wrote:
Larry H wrote:
Jake,
Jake, my recollection is that clear bowls are OK for IB diesel installations but not for IB gas, because diesel's flash point is so much higher than gasoline's. A broken bowl in a diesel system is a hell of a mess, but not the fire hazard caused by a broken bowl in a gas IB system.
Page generation time: 0.1427s (PHP: 78% - SQL: 22%) - SQL queries: 30 - GZIP disabled - Debug on
