2015 Repower
Goto page 1, 2, 3  Next
kennharriet
City/Region: Grangeville
State or Province: ID
Vessel Name: Lochsa
Photos: Lochsa
PostPosted: Sat Mar 14, 2015 8:22 pm    Post subject: 2015 Repower Reply with quote
Considering a repower for Lochsa which is a 22 Cruiser. Currently I have a 1999 carburated Honda BF75. I am happy with it except for the need to choke and scream until warmed up that I am sure is annoying in a marina. It also has approximately 1500 hrs. but runs very good. I don't have to do anything at this point as the BF75 should last several years with continued good maintenance.
I am considering a new Tohatsu TLDI 2 stroke MD90 or the 4 stroke Tohatsu 90. I understand they are the same motor as the Honda 90. I am open to all options at this point including waiting a few years to see what new technology brings to the outboard market. Thanks in advance for the collective wisdom from the group. Ken
SEA3PO
City/Region: Chester
Vessel Name: SEA3PO
Photos: SEA3PO
PostPosted: Sat Mar 14, 2015 8:49 pm    Post subject: Reply with quote
I was all ready to repower.... trade in my Yamaha twin 40hp and buy some Honda 50's......Until I found out that no one wanted to take my Yamaha 40 motors in on trade and if they did they would only give me $1600 each for them... Yeow ! they only have 400 hours on them... I sure would expect more.... I could sell them on EBAY and get twice that amount but what a bother.... so I rebuilt the carburators and will keep them....
Joel
SEA3PO
chimoii
C-Dory Year: 2017
C-Dory Model: R-25 Tug
Vessel Name: Chimo
Photos: Chimo
PostPosted: Sun Mar 15, 2015 12:31 pm    Post subject: Reply with quote
I was at the boat show in Vancouver and dropped by the Yamaha booth. My mind drifted to wondering how Chimo would run with twin 70's instead of 60's. It's the same block. The 70 picks up 6lbs in weight but the real difference is in the gearing, 2.33 vs 1.85, and undoubtedly the fuel flow to shift the torque curve. My daydreaming ended when I thought of the dollars involved and the fact that i spend 90% of my time running at approx. 3800 rpm and almost never above 4200. Nothing to be gained.
Chimo: a word of greeting, farewell, and toast before drinking once widely spoken in the Inuktitut language in northern Canada.
williwaw
City/Region: Portland
Vessel Name: Williwaw
Photos: Williwaw
PostPosted: Sun Mar 15, 2015 1:04 pm    Post subject: Reply with quote
That's a good point on RPM and horsepower in engines with the same block. I once had to decide between a Honda 135 and 150 and was leaning toward the 150 until I realized that extra HP only shows up at the very top of the RPM range. Since I rarely ran flat out I saved thousands by going with the 135.
DrewbirdII
City/Region: fanny bay
Vessel Name: Drewbird II
PostPosted: Tue Mar 17, 2015 2:17 am    Post subject: repower 2015 Reply with quote
Thought I put in my two cents worth here. I just repowered with a new 2015 Mercury 90 command thrust and couldn't be happier. I had a 1997 Honda which is a fine motor and very reliable but doesn't compare to the new Merc. The Mercury swings a big 15x17 prop with the 22 C-dory fully loaded for cruising. I have put on about 40 hrs this winter fishing and one cruise over to Chatterbox Falls. No need to use trim tabs except for trimming side to side and when I drop the motor trim down I can push the bow down nicely. With the trim tabs and motor trimmed down it will really plow , nice in big chop. The best part is fuel consumption , way less than the Honda, And a real nice "quiet" cruise at 20 kns. @ 4000 rpm. It's max speed is 31 kns @ 5800rpm which is too fast for me but nice if you need it. The best part I like is the weight loss of 30 lbs from the Honda, no belts to change, no valves to adjust and I can do my own maintenance. But I am still nervous because it is a new model. Good luck on your decision! Jim.
potter water
City/Region: Logan
C-Dory Year: 1997
C-Dory Model: R-21 Tug
Vessel Name: Poopsy
Photos: Still C-razy
PostPosted: Tue Mar 17, 2015 11:39 am    Post subject: Reply with quote
Johnson E-Techs. You won't go wrong wrong from fuel economy to reliability to torque and to weight.
Also, I do like the Tohatsu. 20 million Asian professional fisherman can't be wrong. I've had several Tohatsu engines and all have performed extremely well.
But re-powering a 22, i'd go with E-techs in a heart beat. I don't own stock i the company, but I've been running an e-tech on my fishing boat and it has been flawless. I replaced an older Johnson 25 hp 2 stroke with a new e-tech 25, and the top speed on the fishing boat went from 18 mph to 27 mph. Same prop pitch. Torque was fantastic and almost dumped me from the bench in the boat when I hit the throttle on the e-tech the first time.
Just something to think about. I also believe the hp equivalent e-techs are lighter on the transom. Something most 22's need.
Testosterone Tales-Amazon.com
KG7RC
jennykatz
City/Region: naples
Vessel Name: Little Treasurer
Photos: Jennykatz
PostPosted: Tue Mar 17, 2015 8:07 pm    Post subject: mercury Reply with quote
I'm glad someone bought a merc with command thrust bigger prop I've been thinking about trading /selling my f115 yamaha and buying a new merc 115 hp with command thrust a 15 in prop and maybe be able to go to a 17 pitch instead of a 15 in pitch .
Yamaha's are in demand so maybe sell it ? Still deciding We have the CC-23 venture weighs about 3000lb VS. 2000 lb for 22CD so 115 would be good enough same lower unit as their 150 hp
williwaw
Photos: Williwaw
PostPosted: Tue Mar 17, 2015 8:29 pm    Post subject: Reply with quote
We have an E-TEC 115 on the back of our CC23. No complaints. Perhaps the things I like the best are the lack of oil/filter changes and the extended service intervals. Even if you play it safe you still only have to go in every other year!
chimoii
C-Dory Year: 2017
Vessel Name: Chimo
Photos: Chimo
PostPosted: Tue Mar 17, 2015 10:20 pm    Post subject: Reply with quote
That's really interesting. How many miles do you get on a gallon of oil? What does a gallon cost? Proprietary oil or Walmart?
Thanks
williwaw
Photos: Williwaw
PostPosted: Tue Mar 17, 2015 10:53 pm    Post subject: Reply with quote
The best performance is when using the Evinrude xd100 synthetic oil as that allows a 100:1 mix (about $40 a gallon). So you'll need one gallon for every 100 gallons of fuel you burn. And just to be clear, you don't actually mix the oil yourself - you have a 2 gallon tank (ours is mounted between the fuel tanks but it believe it can be up to 20 feet away).
There's a low oil alarm that will sound at the helm and a NMEA 2k message is also sent when low. If you run out of oil there's a "get home" mode that will automatically engage and provide reduced power allowing running without oil.
Is it cheaper than changing oil/filter? I don't know but for me that's not really the issue. I like the lower hassle of just occasionally adding oil to the small tank.
You can find the Boattest.com write-up here.
DrewbirdII
PostPosted: Wed Mar 18, 2015 2:43 am    Post subject: Re: mercury Reply with quote
[quote="jennykatz"]I'm glad someone bought a merc with command thrust bigger prop I've been thinking about trading /selling my f115 yamaha and buying a new merc 115 hp with command thrust a 15 in prop and maybe be able to go to a 17 pitch instead of a 15 in pitch .
My c-dory is well over 3000 lb when loaded for an extended cruise. Fishing with four adults and gear, full of fuel ( I keep it full in winter) barely effects the performance at all. The only issue it has is running too light, then the stern gets too much lift and the prop will ventilate on a hard take off or sharp turn. With an average load its all smiles. The 115 merc in command thrust would probably be too much for a 22' c-dory, but maybe fine for the 23'.
PostPosted: Wed Mar 18, 2015 5:23 pm    Post subject: Reply with quote
I was in Bellingham Honda, a couple of years ago trying to get my Honda to run. Whilst I was there, a guy picked up his E-Tech motor which was in for it's first service. I don't know how many hours that was.
What I remember was the bill came to $1000. The proud owner was flabbergasted. The guy on the other side of the counter told him how cheap he was getting off. I certainly remember that interchange, as I was as impressed as the guy getting the bill. He paid to get his motor back, same as I did.
If you're considering an E-Tech, I'd ask how much the regular services cost and how often they're needed. Fortunately for me, I can service the Honda myself, mostly by changing the oil, checking the filters and lubricating various joints.
PaulNBriannaLynn
City/Region: Fort White
Vessel Name: TBD
Photos: Lorelei
PostPosted: Wed Mar 18, 2015 6:23 pm    Post subject: Reply with quote
The lack of oil changes seems to be a big selling point for BRP. Does an E-tec load up trolling at low RPM like all my previous 2 stroke motors would?
I just want to point out that I did my annual oil changes and filters for both our Honda 40s last weekend. It took me probably 10 minutes for both motors. The burden of an oil change seems to be a little overblown.
A well known boat builder that I respect told me they don't use E-tecs because they are much louder and vibrate more. I thought that was interesting, but have no experience running a modern E-tec.
I'm sure they are a fine motor. We all have our preferences, but its like a ford, chevy, dodge debate. Any modern outboard is going to be reliable, even a two stroke. Did I mention I love my Hondas?
BrentB
City/Region: Greenwood
State or Province: IN
Photos: BrentB
PostPosted: Wed Mar 18, 2015 6:25 pm    Post subject: Reply with quote
Wow. What do they do at 300 hour service? That seems expensive
Brent Barrett
BrentB
Photos: BrentB
PostPosted: Wed Mar 18, 2015 6:28 pm    Post subject: Reply with quote
I was thinking fuel and water filter, plugs, water pump, thermostats
, lower unit oil, and some labor
Page 1 of 3
Page generation time: 0.0696s (PHP: 66% - SQL: 34%) - SQL queries: 28 - GZIP disabled - Debug on
