Honda BF150 uneven rpms
msgchef
City/Region: Washington
Photos: Seaweed
PostPosted: Mon Mar 09, 2015 9:59 am    Post subject: Honda BF150 uneven rpms Reply with quote
Got Seaweed out for my first run. I noticed something in the engine rpms, at 4000 the engine seemed to be uneven in its sound, just a bit of up and down in revs rather than one smooth sound. It disappears at higher rpms and lower. I didn't play around too much to determine the range but will do so next outing. Hopefully I am explaining it well enough to get some guidance.
thx
Paul
BrentB
City/Region: Greenwood
State or Province: IN
Photos: BrentB
PostPosted: Mon Mar 09, 2015 11:44 am    Post subject: Reply with quote
Search on
Honda + ECM
in the Google search box
for previous postings
Brent Barrett
msgchef
Photos: Seaweed
PostPosted: Mon Mar 09, 2015 12:33 pm    Post subject: Reply with quote
Indeed, lots of info
Most not very complimentary of Honda Support.
My inexperienced question is.. Other then probable performance issues is there a negative effect of the health of the engine running extended time at that rpm level.
thx
Paul
skiptowns98033
City/Region: Cornet Bay
Vessel Name: Plan C
PostPosted: Mon Mar 09, 2015 1:30 pm    Post subject: Reply with quote
IF it's the same issue I had with the ECM on Plan C, Les at EQ said it would not be a problem. Hopefully it's either under warranty or you have better luck with customer service than I did.
Good luck!
msgchef
Photos: Seaweed
PostPosted: Mon Mar 09, 2015 1:58 pm    Post subject: Reply with quote
oh no, 2006, way past that. Talking to Ray, previous owner, he seems to be in the camp, it's slight spot of in between economical running of the engine and just when the V-Tech system kicks in to add power with less fuel economy. He said when he ran it, it was a range of 100-200 rpms and just try and stay out of cruising in that range.
We'll see with more time on the water, what I learn.
thx again
Paul
dotnmarty
City/Region: Sammamish
Vessel Name: LIZZIE II
Photos: Lizzie
PostPosted: Mon Mar 09, 2015 2:26 pm    Post subject: Reply with quote
I had a similar problem with a new Honda 50 efi. Found water in the gas and debris in the gas tank. A clean out and fresh gas fixed it. Good luck
MartyP
BrentB
Photos: BrentB
PostPosted: Mon Mar 09, 2015 3:07 pm    Post subject: Reply with quote
I agree with Marty
rule out bad gas, water in fuel, dirt, dirty fuel system, old fuel filters, replace gasoline with alcohol free gas,check battery cables at battery and on outboard, etc .......first
C-Hawk
Vessel Name: C-Hawk
Photos: C-Hawk
PostPosted: Mon Mar 09, 2015 3:25 pm    Post subject: Reply with quote
Honda EFI engines around that time frame had a problem with surging. Honda had a fix for it, don't know if it was a recall or not.
2008- CD22- "C-Hawk" Sold
KJ6VVB
A Brat I am, At sea I be
msgchef
Photos: Seaweed
PostPosted: Mon Mar 09, 2015 4:39 pm    Post subject: Reply with quote
That's a good checklist to work, it will take some time. Some of those items are visual checks, how does one check for bad/old gas? I have 85 gal left from Prev Owner. It will take some time to run thru that.
PostPosted: Mon Mar 09, 2015 5:59 pm    Post subject: Reply with quote
My '08 BF90D had this problem. It was a few hundred RPM surge/sag. It occurred in mid range RPMs. Above 4K and below about 2K the surging did not occur.
Honda changed the ECM to fix it. I just squeezed in before the expiration of the warranty.
The guy who had the boat before me (he bought it new) said he never had a problem with the motor. However, he only ran it fast or slow (trolling).
Look for Honda Service bulletin 61 in the C-Brats tech library.
BrentB
Photos: BrentB
PostPosted: Mon Mar 09, 2015 7:13 pm    Post subject: Reply with quote
Pull and inspect plugs
Either re use them or replace, most will do the later for peace of mind and is inexpensive.
Add anti seize to threads and boot grease to the tips
Check plug wires for cracks or breaks and check they firmly
attach to the plugs.
It could a bad wire, loose plug or poor connection.
You are checking all related components but condemning the ECM which is expensive
How old is the gas?
An external fuel filter like a Racor that uses a clear bowl is very useful to check for water and dirt
If not present I recommend installing one
Then take a cruise for a couple of hours and check the bowl contents.
The tanks may need to be drained and cleaned,
If ECM is the problem, I would post the info with us and file a request for replacement with a dealer and Honda.
Maybe they will replace it and offer at reduce price, and they want to see the bad comments. It is worth the effort
BrentB
Photos: BrentB
PostPosted: Mon Mar 09, 2015 7:24 pm    Post subject: Reply with quote
m2cw having a good relationship with a dealer, shop and mechanic would be better and they could work magic (maybe) with Honda.
Rcbeach
City/Region: Ocean Pines
State or Province: MD
C-Dory Year: 2014
C-Dory Model: R-25 Tug
Vessel Name: DreamChaser
PostPosted: Mon Mar 09, 2015 8:03 pm    Post subject: Reply with quote
You are close to Mobil East Marine in Alliance, NC. They are an excellent dealership for CDorys and Honda outboards. I would discuss your problem with Gene the Owner. He has always been able to help me with my outboard issues. Good luck!
msgchef
Photos: Seaweed
PostPosted: Mon Mar 09, 2015 8:22 pm    Post subject: Reply with quote
Yes, Gene is going to be my mechanic. I met him prior to buying and he spent allot of time sharing knowledge. He runs a good shop.
thanks
BRAZO
City/Region: Full-time Travel
State or Province: NV
Vessel Name: Meyer Meyer
Photos: BRAZO
PostPosted: Mon Mar 09, 2015 8:46 pm    Post subject: Reply with quote
We had a very slight pinch (we had our paddles in the splash well) in the fuel line that caused a similar problem.
Good luck.
2008 CD22 Twin 50hp
Page generation time: 0.0489s (PHP: 66% - SQL: 34%) - SQL queries: 28 - GZIP disabled - Debug on
