Fish Box Macerator Pump
Westie
City/Region: Bodega Bay
Vessel Name: True North
Photos: Westie
PostPosted: Mon Jan 26, 2015 9:42 pm    Post subject: Fish Box Macerator Pump Reply with quote
The macerator pump on my starboard fish box stopped working. I have a few questions I could use some help with:
1) is there a fuse? I wasnt able to locate anything in the main panel
2) Can you remove the filter cover in the fish box? Mine seemed pretty tight and I didn't want to break it. My guess is something got jammed in there
Any other fish box advice is welcome. I sure loved it when it was working properly!
Bill K
City/Region: Toledo
State or Province: OH
Vessel Name: NIC'L PIC'L
Photos: NIC'L PIC'L
PostPosted: Mon Jan 26, 2015 9:52 pm    Post subject: Reply with quote
Look for an inline fuse somewhere in the positive wire.
Bill Kelleher
KA8BFT
redbaronace
City/Region: Puget Sound
Photos: redbaronace (Name TBD)
PostPosted: Tue Jan 27, 2015 12:12 am    Post subject: Reply with quote
Could be a fuse. Could also be your pump failed.
We have rebuilt and replaced those pumps several times already on the various tomcats that we owned..
Other times if we turned it on and heard no sound, it was an electrical problem.
Good luck in your troubleshooting.
Pacificcoast101
City/Region: Torrance
Vessel Name: No Pressure
Photos: No Pressure
PostPosted: Tue Jan 27, 2015 12:55 am    Post subject: Reply with quote
Check the fuse box first. There should be a 20 amp fuse for each pump. If the fuse is good, remove the black rubber cap on the end of the pump and use a flat head screwdriver to manually turn the pump a few rotations. This will sometimes clear any debris caught in the impeller. If this doesn't work you may need to replace the pump. I've had to replace my starboard pump, and the hardest part is getting to it inside the stern.
Phil Garner
2008 Tomcat 255
No Pressure
My Photos
PostPosted: Tue Jan 27, 2015 9:30 am    Post subject: Reply with quote
While it might be a fuse, I'd bet the pump has failed. I've had 4 Johnson macerator pump failures in my fish boxes in about 3 years. Last year I replaced them both with Whale Gulper Grouper pumps. Hopefully, those will last a bit longer.
Discovery
City/Region: LOA, UTAH
Vessel Name: Discovery
Photos: Discovery
PostPosted: Tue Jan 27, 2015 10:00 am    Post subject: Reply with quote
The above image is from the "Dreamer" album, but I did the same modification to the fish box's on Discovery. It allows better access to the macerator pumps, also to the bilge pumps.
Use a 6" screw-in type deck plate. Get a plate with an "O" ring, and use 4200 to set the plate in. They don't leak if well bedded with 4200, and contain a good "O" ring.
Brent and Dixie,
1984 22' Classic sold 2003
2003 24' TomCat sold 2005
2006 CD 22' Angler Sold 2014
Westie
Photos: Westie
PostPosted: Tue Jan 27, 2015 10:21 am    Post subject: Reply with quote
Thanks for the replies. That mod looks good.
BrentB
City/Region: Greenwood
State or Province: IN
Photos: BrentB
PostPosted: Tue Jan 27, 2015 10:23 am    Post subject: Reply with quote
Check the voltage at the fuse too
Brent Barrett
Westie
Photos: Westie
PostPosted: Sun Mar 11, 2018 9:18 pm    Post subject: Reply with quote
My fishbox macerator pump finally blew! Any advice for a pump to replace it?
I also need a switch for the other pump. My mechanic blew that when debugging the other. The day was actually great as I rewired every battery terminal connection!
Any suggestions?
True North
2006 Tomcat 255
PostPosted: Sun Mar 11, 2018 10:07 pm    Post subject: Reply with quote
Any suggestions?
My Whale Gulper Grouper pumps are still going strong after 3 years. They are slower than the Johnson macerator pumps but appear to last much longer (in my experience, your mileage may vary).
Page generation time: 0.1218s (PHP: 87% - SQL: 13%) - SQL queries: 27 - GZIP disabled - Debug on
