Tomcat Hull Zincs?
Westie
City/Region: Bodega Bay
Vessel Name: True North
Photos: Westie
PostPosted: Sun Dec 21, 2014 11:51 pm    Post subject: Tomcat Hull Zincs? Reply with quote
Hi There,
I'm pulling out my 2006 Tomcat for the first time since I took ownership of it in October. If I remember, there where zincs on the hull. I wanted to replace them but cant find any detail on what type of zinc anode to buy or how to go about changing them.
Any advice?
Dreamer
Photos: Dreamer
PostPosted: Mon Dec 22, 2014 12:22 am    Post subject: Reply with quote
There are no hull Zincs on the TC. The Zincs are on the engines, where the possibility of corrosion lies. I had Honda's which had 3 Zincs. Check your manual for Suzuki's Zinc location. Everything in the boat which uses the 12v ground system is protected through the engine ground and Zincs.
Dreamer- Sold 25 Feb. 2013
Westie
Photos: Westie
PostPosted: Mon Dec 22, 2014 1:03 am    Post subject: Reply with quote
I'm sure I saw a metal plate under each hull in the back. Could that be something else?
PostPosted: Mon Dec 22, 2014 1:23 am    Post subject: Reply with quote
If you have trim tabs, the "planes" (the part that is like an airplane wing flap) are metal plates of a sort, and they often have anodes mounted on them (in salt water the anodes would likely be zinc).
There are also things like sintered bronze plates for radios and such, but you'd be unlikely to have two (whereas the trim planes/zincs would be a pair).
(I don't know the TC specifically though.)
gulfcoast john
City/Region: PENSACOLA
C-Dory Year: 2010
Vessel Name: Cat O' Mine
Photos: CAT O' MINE
PostPosted: Mon Dec 22, 2014 1:14 pm    Post subject: bracket anodes Reply with quote
Westie
Expect to find 2 round clamshell anodes on the underside of the engine bracket as Armstrong rec'd. Access the hex bolt from the access plates on the top of the bracket with ahex wrench and the 2 halves will come apart. Armstrong said put some sealant around the hole to keep seawater from filling bracket. Google round Martyr hex anode to see parts.
Cheers!
[/code]
John and Eileen Highsmith
2010 Tom Cat 255, Cat O' Mine
Yamaha F150, LXF150
PostPosted: Mon Dec 22, 2014 2:21 pm    Post subject: Reply with quote
As John has inferred, I believe that Westie is referring to the bracket and not the hull persay. The bracket is made of aluminum and has an anode on each side.
dgeorges
City/Region: Highlands Ranch
Vessel Name: FRESH FISH
Photos: FRESH FISH
PostPosted: Wed Dec 24, 2014 12:09 am    Post subject: anodes for Westie Reply with quote
hey Westie,
Martyr Anodes is a great company in Canada that specializes in the right anodes for every type of condition imaginable. Here's their web page:
http://www.martyranodes.com/
Check out their tech data regarding the right anode for your situation and you'll see that Zinc is NOT always the best route to take (depending on the type of water you are boating in). Additional specific info on zinc, magnesium, and aluminum anodes is available at: http://www.martyranodes.com/resources/marketing-literature
If you have tech questions, their people are very helpful and down to earth. They love to talk to customers. Good luck.
DG
"Ain't no nookie like Chinookie"---Ray Troll
CD 22 Cruiser "FRESH FISH: 2018 to present.
CD 16 Angler "OPA": 2013 to 2019.
Westie
Photos: Westie
PostPosted: Sun Jan 04, 2015 7:10 pm    Post subject: Reply with quote
Thanks for the feedback. I pulled the boat out on Dec 30th and there were anodes on the hulls. I didn't take pictures but they were definitely there and in great shape. I dont have the previous owners contact info but they must have added this on at some point.
In any regard, I love this boat!
Page generation time: 0.0361s (PHP: 63% - SQL: 37%) - SQL queries: 25 - GZIP disabled - Debug on
