Fiberglass cut?
D5800877351
Vessel Name: N/A
Photos: D5800877351
PostPosted: Mon Aug 01, 2005 11:15 pm    Post subject: Fiberglass cut? Reply with quote
Hi all, I need some tips and what to use to successfully make a clean, sparking cut though fiberglass. Things like bits, glue, and techniques would be much appreciated.
I know most of you guys could do them cuts while in your sleep but my problem would mostly be how to conceal the cut from water to enter and "contaminate" the insides, thanks again.
David
Almas Only
City/Region: Richmond
Vessel Name: Alma's Only
Photos: Alma's Only
PostPosted: Tue Aug 02, 2005 6:50 am    Post subject: Reply with quote
David:
What are you planning to cut: drilled holes, sawed holes, size, location, etc. and for what purpose (bolts, screws, instrument mounts, etc.? Give us a little idea what you're up to.
David on Alma's Only
2003 CD22 Cruiser with Honda 90
gljjr
City/Region: Fall City
C-Dory Year: 1982
Vessel Name: Migratory Dory
Photos: gljjr
PostPosted: Tue Aug 02, 2005 2:54 pm    Post subject: Reply with quote
For drilling holes either use a hole saw or a forstner bit. The forstner bit has a cutting edge on the outer edge of the hole and a centering pin. Between the centering pin and the outer edge it will have 1 or 2 cutting blades. The advantage of the forstner bit is the cutting edge will give a nice clean cut. I think they will usually give a better hole than a hole saw will.
If you are using a saw you can often clamp a sacraficial piece of plywood to the part you are going to cut on the gelcoat side. This will help prevent chipping.
Gary Johnson
KB7NFG
Page generation time: 0.0297s (PHP: 45% - SQL: 55%) - SQL queries: 21 - GZIP disabled - Debug on
