A Fishin C Guest
Posted: Thu Oct 23, 2014 8:38 pm Post subject: UFP torsion suspension, UFP Vault Hubs/Bearings, brakes ? |
looking at buying a new 4000 lb single axle Tuff Trailer at a good price.
noticed the torsion suspension, disc brakes and vault hubs are made by UFP. (I see pacific trailers uses these currently)
Anyone have any experience good or bad and how long have you run these products?
thanks |
Flint
Vessel Name: Grace Full
Photos: Grace Full
Posted: Fri Oct 24, 2014 9:02 am Post subject: trailers |
I have a 10,000 lbs. double axle Pacific trailer. It has the Vault hubs and I have not had any problems with it. I have towed my boat from Marathon, Fl. to Lake Powell and back with no problems. I have the hubs checked very year before I start towing long distances. I only have disc surge brakes at this time but over the winter I'm having electric over hydraulic disc brakes put on. I have a Venture 26ft. C-Dory that I tow. |
Posted: Sun Oct 26, 2014 10:34 pm Post subject: |
After my experience with the broken tongue on a single axle trailer rated at 5200 lbs, I would be very uncomfortable with a single axle trailer rated at 4,000 lbs. You have the trailer weight--difficult to envision a trailer weight at least than 800 lbs (even an aluminum--my 18 foot Caracal trailer weight is 890 lbs, single axle)
If you only want it as a "yard" trailer--that is where it is kept in a storage yard, and only to the ramp and back--a few hundred yards….OK..
But you are banking on your C Dory weight being less than 3200 lbs. I suspect that is going to be hard to achieve.
That does not mean that a single axle trailer will not be satisfactory--I got about 10,000 miles on the single axle C Dory trailer, before it failed--and I 10 is rough (but so is I 5)….I would want one rated at more than 4000 lbs
I got the build sheet on my "new" used tandem axle trailer--and it is rated at 7,000 lbs. Enough for the C Dory 22. _________________ Bob Austin
A Fishin C Guest
Posted: Mon Oct 27, 2014 12:41 am Post subject: |
Hi Bob, the 4000 lb trailer carries 4000 load capacity. it is not the GVW. I accept that some like to go with heavier trailers (you do a lot more miles than I do) but I would be happy with a 4000 lb load capacity. Currently my trailer is a King KR 3100 (came with the boat) . 3100 lb load capacity.
Calculated weight for my boat would be 3500 to 3700 lbs and I carry most of my gear in the truck. This trailer I am looking at is heavily built with 5" c-channels all welded and 5200 lb axle. Cost is a factor also.
Have you have any experience with UFP parts? I wonder if better or worse than tie down or kodiak.
Thanks tho.
Stefan |
Posted: Mon Oct 27, 2014 1:23 am Post subject: |
Stefan:
Thanks for the comment--and I don't know how things work in Canada--and if their definition is different than in the States:
Definition of GVW/VCWR:
Quote: | GVW (Gross Vehicle Weight) is not a limit or specification. It is obtained when the fully loaded vehicle is driven onto a scale. The Gross Vehicle Weight, should not exceed the Gross Vehicle Weight Rating (GVWR) or the vehicle’s warranty could be voided. Refer to the owner’s guide for the specific vehicle. |
From Loadrite:
Quote: | To determine the load capacity requirement of your tow vehicle, refer to the Vehicle Identification Label attached to the trailer on the left frame rail just behind the tongue junction. It will display the maximum load-carrying capacity of the trailer. It is required to show the Gross Vehicle Weight Rating (GVWR) which is the load-carrying capacity plus the weight of the trailer itself. It is the trailer operator’s responsibility to ensure that the total weight of the boat, engine fuel, water, gear and trailer do not exceed the GVWR capacity. |
From a tire site:
Quote: | The combined capacity of the tires must equal or exceed the Gross Vehicle Weight (GVW) of the axle. |
Since this is scale weight--I have always considered this to include the trailer weight. I believe that this is Universal--at least in the states.
If your trailer has a load carrying capacity of 4000 lbs, which you think that it has, it is better.
To my knowledge I have not bought a UFP--but an axle or hub might be UFP specifically, and one would not know it. |
NewMoon
C-Dory Year: 1991
Vessel Name: Cindy Sea
Photos: Cindy Sea
Posted: Mon Oct 27, 2014 9:08 am Post subject: Re: UFP torsion suspension, UFP Vault Hubs/Bearings, brakes |
A Fishin C wrote: | looking at buying a new 4000 lb single axle Tuff Trailer at a good price.
thanks |
No experience with torsion axles or vault hubs, but I replaced my Pacific Trailer's ancient drum brakes with UFP disks, new UFP actuator, and thermoplastic brake lines a year ago. Towed the ~12K lb trailer about 5200 miles so far. The new brakes work wonderfully, even without electric over hydraulic. _________________ Richard Cook
"Cruising in a Big Way" |
Posted: Tue Oct 28, 2014 11:00 am Post subject: |
Richard, what's a "thermoplastic brake line"? To me, thermoplastic means it's formed by heat and gives up the gohst when heated. Not what I'd want for a brake line, so I must not understand. P;ease educate me.
Boris |
NewMoon
C-Dory Year: 1991
Photos: Cindy Sea
Posted: Tue Oct 28, 2014 12:38 pm Post subject: |
You do have to watch for any brake line, but I had some tire monkey put a jack right under of a Thermoplastic brake line--and it had to be replaced (a trip to Pacific trailer to get a new part: fortunately we were only an hours drive away. |
