Gear Oil Drain Plug Gasket
Grazer
City/Region: Yukon
State or Province: YT
Vessel Name: C-Horse
Photos: Grazer
PostPosted: Mon Oct 20, 2014 3:30 pm    Post subject: Gear Oil Drain Plug Gasket Reply with quote
Hello All,
Putting the boats away for the winter is always a sad time of year, but sadder is trying to locate those gaskets for the plugs on the gear oil drain screw. As we all know, this critical component, must be replaced every time the screws (at least 2 per motor) are removed. Does anyone have a good source on where to purchase a good crush washer to fit all makes of my outboards (Honda, Tohatsu)? It seems to me the size of the drain screws are fairly similar on both engines (in terms of diameter and mating surface between the lower unit and screw).
Grazer
srbaum
City/Region: Portsmouth
Vessel Name: Osprey
Photos: Osprey
PostPosted: Mon Oct 20, 2014 5:56 pm    Post subject: Reply with quote
Grazer,
I order my lower unit screw gaskets and all other outboard parts from boats.net or partspak.com... easy to do from your best recliner.
Steve Baum
Homeport of Portsmouth, VA
PostPosted: Mon Oct 20, 2014 6:39 pm    Post subject: Reply with quote
Actually, I use those o-rings a couple of times. Haven't been caught out yet. Just look at them and see that they haven't been torn.
Is that cheating? They're expensive little buggers.
Hmm, I just lied, for a Honda they're either $0.63 or $1.32 @ boats.net. Just wait until you have some other parts to order (such as fuel filters,) and get 1/2 dozen of them. It's the shipping that makes them expensive. And don't put them somewhere that you'll forget about.
While I'm on the soapbox, remember that Honda anodes aren't necessarily zinc. They could (and should) be aluminum or magnesium. I called Honda customer service to see of what they're made, and they couldn't tell me. I do know the Honda ones are lighter than the non-Honda zinc ones. So I'll buy the Honda ones. I figure Honda knows what Honda needs.
shellndanm
City/Region: Chesterfield
Vessel Name: Linda M
Photos: Linda M
PostPosted: Mon Oct 20, 2014 7:57 pm    Post subject: gasket Reply with quote
Anyone have the part number for the gear oil gasket on a honda 90? Couldn't seem to find online. Thanks
PostPosted: Mon Oct 20, 2014 8:51 pm    Post subject: Reply with quote
Try this link: Honda 90 Lower Gear Case. Hope it's the right 90.
I think it's #40 or #53 in the diagram. Note that 40 is a plastic washer, 53 an o-ring.
BrentB
City/Region: Greenwood
State or Province: IN
Photos: BrentB
PostPosted: Mon Oct 20, 2014 9:01 pm    Post subject: Reply with quote
I have a Yamaha OB and bought a bunch several yrs ago when ordering other parts. eBay has a bunch of crushable washers listed but I use onlt factory items
Brent Barrett
Grazer
City/Region: Yukon
Photos: Grazer
PostPosted: Mon Oct 20, 2014 11:26 pm    Post subject: Reply with quote
Thanks for all your comments. I have looked at boats.net and yes the shipping is the expensive part, especially outside of the USA. I haven't checked out partspak.com yet. Any other on-line sites folks are using that have had success with for ordering engine parts would be greatly appreciated.
Grazer
BrentB
Photos: BrentB
PostPosted: Tue Oct 21, 2014 6:32 am    Post subject: Reply with quote
I ordered Yamaha parts from SIM Yamaha
Rcbeach
City/Region: Ocean Pines
State or Province: MD
C-Dory Year: 2014
C-Dory Model: R-25 Tug
Vessel Name: DreamChaser
PostPosted: Tue Oct 21, 2014 9:32 am    Post subject: Reply with quote
In 2004 or 2005 Honda made some design changes to their gear cases. Since that time I know for the 50 and 90 HP models an "O" ring is used not the plastic washer. Boat.net will give you the correct part and number.
srbaum
Vessel Name: Osprey
Photos: Osprey
PostPosted: Tue Oct 21, 2014 9:47 am    Post subject: Reply with quote
Grazer,
I have a 90 HP Honda 2002 on my 2001 C-Dory and a 90 HP Honda 2005 on my rigid hull inflatable. Both outboards use the old style nylon washer (Honda part number 90507-921-000 WASHER, NYLON ) on both oil drain and vent screws on the lower units.
BrentB
Photos: BrentB
PostPosted: Tue Oct 21, 2014 9:49 am    Post subject: Reply with quote
I bought boating items from BOE Marine and they also sell Honda parts in case you are shopping around. Jim at BOE provides excellent support just like Andy at SIM. Both businesses have forums on The Hull Truth as a fyi
TABMAN at Bennett Tabs is the gold standard on customer support. He is worth his weight in gold ten fold.
Rcbeach
C-Dory Year: 2014
PostPosted: Tue Oct 21, 2014 1:32 pm    Post subject: Reply with quote
Steve,
My mistake, on the 90 HP the change was made to an "o" ring in 2007. I checked with boat.net and nylon washers were used up thru 2006.
Dick
rjmcnabb
City/Region: Pender Island (Southern Gulf Islands)
Vessel Name: Luna
PostPosted: Tue Oct 21, 2014 3:25 pm    Post subject: Reply with quote
Hi Rcbeach,
Can you, or anyone else, tell me if the newer O-rings are a suitable replacement for the nylon washers? I never thought of a nylon one as being a "crush washer." "Crush washer" is what I think of as used on a spark plug, a kind of complicated toroid shape that squashes down when you torque the plug. Question
Rod
Rod & Jane; Victoria 18 sloop (Vickie) - gone; Islander 26 Bahama sloop (Callisto) - gone; WW Potter 19 sloop (Spring) - gone; Com-Pac 16 sloop (Bummer II) - gone; Nimble 24 yawl (Chatelaine) - gone; Nimble Vagabond cruiser (Loligo) - gone; C-Dory 22 Cruiser (NoddyBleu) - gone; Com-Pac 19 sloop ('Winkle) - gone; San Juan 24 sloop (Loligo^2) - gone; C-Dory 16 cruiser (Luna); Catalina Capri 18 sloop (Later)
Rcbeach
C-Dory Year: 2014
PostPosted: Tue Oct 21, 2014 6:32 pm    Post subject: Reply with quote
Rod,
The gear case that uses an "O" ring has a bevel where the fill/drain and check plugs are inserted to squeeze the "O" ring between the plug and the case making a tight seal and also allowing the plug to contact the case metal to metal to make for a secure fit. I assume that the gear case that is designed to use the nylon washer is flat. If an "O" ring is used on this configuration, the "O" ring may be destroyed if over tighten, allowing leakage. I do not have any experience with the older Honda models designed for nylon washers, maybe someone else can provide that information. I do know that the local mechanics where I live use the nylon washers on gear cases designed for "O" rings apparently without problems. I don't recommend doing that.
Dick
rjmcnabb
Vessel Name: Luna
PostPosted: Tue Oct 21, 2014 8:27 pm    Post subject: Reply with quote
Thanks, Dick. My OB is a 2005, I think, so I guess P/O probably did not substitute nylon for O-ring. I'll be very careful when I pull Luna for the winter. Cheers, Rod
Page generation time: 0.0636s (PHP: 41% - SQL: 59%) - SQL queries: 28 - GZIP disabled - Debug on
