Roy & Dixie
Joined: 29 Jan 2013 Posts: 151 City/Region: Silver Springs
Vessel Name: C Way
Photos: C-Way
Posted: Fri Aug 29, 2014 11:15 pm Post subject: Honda 2000 extended fuel system |
I'm excited; my new Honda 2000 is due for delivery by FedEx tomorrow. I had thought the holiday weekend would cause it to arrive mid week next week. I have a 3 gal Atwood tank on order from WM (my old steel 5 gal tank that I had planned to use had rusted badly while just sitting around unused and empty for a couple of years) and plan to modify the Honda cap to accept Atwood fuel fittings so as to draw fuel from the 3gal tank. I will construct a platform on which to set the gen, stb aft. This will put the fuel cap on the gen a little more than 3ft above the cockpit floor. I understand there is a limit to the height fuel will be drawn by the vacuum caused by the Honda fuel pump. Has anyone tested the height the fuel can be drawn? I would like to set the 3 gal tank on the cockpit floor straight down from the gen with min length fuel line. _________________ When you come to a fork in the road, take it.
It's not the destination that is important, it's the trip.
"C-Way" Silver Springs, FL |
BRAZO
Joined: 29 Jul 2008 Posts: 650 City/Region: Full-time Travel
State or Province: NV
Vessel Name: Meyer Meyer
Photos: BRAZO
Posted: Sat Aug 30, 2014 8:03 am Post subject: |
We have two eu2000i hooked to a 12 gallon marine tank on our motorhome. I found this information from another site:
Ok, kiddos. Today I did some goofing with external Fuel tanks and the Honda EU2000i. Interesting results!
Background: I coupled an Atwood 12 gallon marine tank to an EU2000i. At the loads we typically run, this means about 4 days of non-stop fuel (3 GPD). But because this rig will be trailer mounted I wanted to see how much vertical distance the EU2000 could suck fuel out of the aux tank and into the genny tank at sea level. My goofings gave some interesting answers:
NOTE: the measurements given below are from the surface of the fuel level in the aux tank to the top of the generators gas cap. The bulk tank is at atmospheric pressure and no pressure or vacuum is allowed. Ambient temp was 93F at 23 feet above MSL. The generator tank was pre-filled to within 1/4 inch of the topmost thread on the cap (ie, nearly "full to the brim")
Results:
0 to 30 inches: ran fine for all loads up to and including 1600 watts
30 to 34 inches: ran ok, with the occasional miss, at loads up to 1000 watts.
>36 inches: Nada. Full stop after 10 mins or so. Repeated tries could not cure this and the genny can not overcome this lift. Anything over 36 inches kills the genny after a minute or two.
So at sea level, the safe "do not exceed" differential level should be 30 inches. Running the numbers for elevations of 4500 feet and a 105F ambient temperature shows you can safely and reliably run up to 26 inches of draw on the playa. If you are the conservative type, make this number 20 inches and you should be absolutely golden up to 7000 feet MSL.
So now we know. :mrgreen:
NEXT UP: I want to investigate the effects of installing a fuel demand regulator and allowing the aux tank to operate in "California SCAQMD mode" (ie, the tank can pressurize up to 5 psi to keep fuel vapor emissions at nil levels)
Parts list:
Fuel cap: Great River: http://www.amazon.com/EXTENDED-FUEL-HON ... B004BJ5YKM
Fuel Tank: Atwood: http://www.attwoodmarine.com/store/prod ... fuel-tanks
Fuel Line and primer bulb: Atwood: http://www.amazon.com/Attwood-CARB-Univ ... B009RJK532
Final note: the right way to feed the EU2000 is from a tank located at the same level, or slightly higher. In a perfect world, this is what you SHOULD do. Unfortunately I am constrained to a less-than-perfect world and the tank will be slightly lower than the genny. If you can get the tank slightly higher, do it. It works better that way! _________________ 2008 CD22 Twin 50hp
Full-time Travel - Sprinter4x4, International, C-DORY 22 |
BRAZO
Photos: BRAZO
Double post |
Roy & Dixie
Vessel Name: C Way
Photos: C-Way
Posted: Sat Aug 30, 2014 10:35 am Post subject: |
BRAZO, you answered my question 200%. I had also wondered if the gen would shut down right away if you exceeded the lift capability of the gen pump. Common sense says "yes", as vacuum in the gen tank would prevent fuel flowing into the gen fuel bowl. You confirmed that, along with the "30in ideal max lift ability". Then you mentioned a controlled pressure in the aux tank, which would push fuel up to the gen. I have been thinking about that also. Keep us posted as you learn more concerning that.
I viewed your photos of your gen location. Is that your fuel tank that the gen is sitting on? If so, I have never seen one like that.
Thank you for the excellent answer to my original question. I'm sure many others have wondered the same thing. |
BrentB
State or Province: IN
Photos: BrentB
Posted: Sat Aug 30, 2014 5:26 pm Post subject: |
Your links do not work
Try using https://bitly.com/ also used by Twitter who used TinyUrl previously
go well _________________ Brent Barrett |
Joined: 02 Nov 2003 Posts: 20820 City/Region: Pensacola
Posted: Sun Aug 31, 2014 7:43 pm Post subject: |
We use a West Marine plastic "crate" on the swim step--works great for either the EU 1000 or 2000. We did have a plywood board with cleats on the bottom and holes for the feet bored out for the 2000. For the 1000 the generator sits on the bottom of the crate (which is up side down).
Most experiments to draw fuel out of C Dory tanks have not been successful (to my knowledge) for the Honda. We just put our 6 gallon tank on about the same level as the generator--and it works great. _________________ Bob Austin
nmitch2859
Joined: 28 Apr 2013 Posts: 71 City/Region: virginiabeach
Vessel Name: Delfin
Photos: Delfin
Posted: Sun Aug 31, 2014 9:01 pm Post subject: |
I have a 25 C-D. My 2000 is mounted on the starboard side in the motor well. I tried to run a hose from the primary filter wit a quick disconnect. Leaked and did not work. I did buy the extended run system from Northern Tool. I made a stand for the tank. It mounted in between the cockpit hatches. I do leave the hose connected. No problem. I run an extension cord from gen to shore power outlet. With door open, on eco mode. And at speed I cannot here it. It does use atmospheric pressure and the pump. Neal _________________ Neal J |
