Tug
Joined: 22 Jun 2007 Posts: 983 City/Region: Sault Ste. Marie
State or Province: ON
C-Dory Year: 1985
Vessel Name: Drifter
Photos: Drifter
Posted: Tue Aug 26, 2014 9:05 am Post subject: Throttle Control |
Here's the problem , lately I have noticed that when I am trolling at about 1 MPH . ( 1999 Suzuki DF70 ). my speed will suddenly start to climb. I almost seems that the throttle cable is slipping. I wanted to check if anyone had an idea what the problem might be before I started taking things apart. Thanks Tug |
Posted: Tue Aug 26, 2014 9:26 am Post subject: Re: Throttle Control |
Tug wrote: | Here's the problem , lately I have noticed that when I am trolling at about 1 MPH . ( 1999 Suzuki DF70 ). my speed will suddenly start to climb. I almost seems that the throttle cable is slipping. I wanted to check if anyone had an idea what the problem might be before I started taking things apart. Thanks Tug |
I'm not familiar with the Suzuki but on most throttle controllers (at the helm), there is a tensioning adjustment that controls how much effort it takes to move the throttle. I'd start there. _________________ Roger on Meant to be |
Joined: 07 Nov 2003 Posts: 7881 City/Region: marysville
Posted: Tue Aug 26, 2014 11:18 am Post subject: |
does it happen when you are turning? This happens to me sometimes as I turn left but then as I turn back to center or right the motor slows down again. Has to do with the length of the cable. _________________ Thomas J Elliott
Tug
C-Dory Year: 1985
Photos: Drifter
Posted: Tue Aug 26, 2014 12:30 pm Post subject: |
I never noticed it doing that when I am turning , mostly in a straight line.It probably is the throttle adjustment/control tensioner. I have had the motor 5-6 years now and as far as maintenance goes the only thing I do is do is the motor winter oil and lube change.I will apply a little grease in the cable connect points and see if I need any throttle adjustments. Thanks for the advice , I will see if this works and post the results. Tug |
