Posted: Mon Aug 25, 2014 12:19 am Post subject: |
The Promariner 1240i plus is a 40 amp charger--3 bank. Not using one bank should not be an issue. I would hook up to each bank--and I might consider turning the ACR off when on the battery charger.
I wouldn't ever let that battery get to anywhere near the 10.5 volts they speak of in the instructions. 12.2 is where I put the limit.
They speak of using 10 amps for charging. I charge my East Penn Group 31 (105 ah /68#)at 30 amps, but monitor the temperature. The Optima group 31 size is (75 ah/ 59#) is a smaller battery, so I would limit the charge. Don't toss that 40 charger however. _________________ Bob Austin
CDory23
Photos: CDory23
Posted: Mon Aug 25, 2014 7:12 pm Post subject: |
Well I've had the last few days off and finally going to stick with my last solution. After researching more about Optima I couldn't justify paying that kind of money with the quality control and the charging requirements. I returned them, and ended up barely fitting two standard lead/acid group 27 SuperStart (Johnson controls) deep cycles which have a RC of 180 and 600CCA and 750CA- a dual purpose battery.
What a headache all of this battery and wiring has been for me.
I will get all of my wiring labels done on Wednesday (proffesional labeler available at work), and connect everything to battery terminals. I have no room for any buses, but to me its not a big deal connecting everything to the battery terminals solely since I"m able to have the group 27s in place. I am putting a LED light on the control panel to view my ACR status. I am also putting a switch on my ACR ground to rid of parasitic load, and allow me to charge both batteries independently when out of water. I Also I bought a Diode that Blue sea systems recommended for my start isolation since I have twin outboards. Blue sea systems technical support was very helpful.
I could not find charging requirements for my Johnson 27's but I believe since they are the standard lead/acid my 1240i plus 40amp charger should be fine for them.
Thanks for all the help from everybody. |
Posted: Mon Aug 25, 2014 11:32 pm Post subject: |
The one simple suggestion I would recommend is a battery voltage monitor (LCD)--and a $15 from WalMart, or $5 from Amazon will work fine, with a two way Bat 1, off, bat 2 switch--the simple voltage will allow a reasonable state of charge, and prevent overcharging etc. |
