Oil and oil filters on a Honda 50 EFI
jack keifer
City/Region: Boise
State or Province: ID
Vessel Name: C-Squirt
Photos: C-Squirt
PostPosted: Sat Aug 09, 2014 1:17 pm    Post subject: Oil and oil filters on a Honda 50 EFI Reply with quote
This question is for a Honda Tech, if there is one out there. The C-Squirt has a Honda 50 EFI. When I did the last oil change, I noted the Honda filter was $15 which adds a lot to cost of the service. The primary use of the C-Squirt is trolling. Generally that means at lest 3 hours at idle for every hour underway. We always start and end our trips on plane so the engine is thoroughly warmed before and after trolling. Average fuel consumption is slightly more that 3/4 gallon per hour. So we use about 75 to 80 gallons per 100 hours. I do use and will continue to use the Honda filters for reasons covered elsewhere. However I am looking for an opinion on changing the filter every other oil change. The oil at change has only slight discoloration and no fuel odor, so does not appear to be getting any fuel dilution.
Thanks fro any insight.
Jack
Jack
Previously 22 cruiser "Loafer's Paradise"
Now 16 cruiser "C-Squirt"
PostPosted: Sat Aug 09, 2014 1:45 pm    Post subject: Reply with quote
I am a long way from a Honda Tech. My rule of thumb is to change motor oil every year, or every 100 hours, which comes first (for outboards). With low fuel usage such as yours, I would only change the filter every other time. Keep in mind that some engines (mainly diesels) will run for years without being shut down, and they use a good filter system, which allows for changing filters, without shutting the engines down. There are some "add on" filters, such as Gulf Coast Filters, which claim long intervals between changes.
If you are not going to use a motor for several years, then change the oil before shutting down (best time to change is before longer storage interval) and putting a storage additive as well as fogging the engine before prolonged storage.
colobear
City/Region: Denver
Photos: C-Cakes
PostPosted: Sat Aug 09, 2014 2:14 pm    Post subject: Reply with quote
Go to NAPA and you can find one of their filters for less $ than the official Honda brand. Just give them the Honda number and they should be able to help. Likewise oil. Look at the specifications of the oil and you can find a perfectly good non-Honda brand that will give you the same protection.
Patti and Barry
formerly C-Cakes, now
rving around N. America
bcassal
City/Region: BLoomington
State or Province: IN
Vessel Name: Carpy
Photos: Carpy
PostPosted: Sat Aug 09, 2014 4:21 pm    Post subject: Reply with quote
I use Sierra filters in my BF40's Like Bob mentioned, I change the oil at 100 hr intervals and change the filter every other time or at least every fall. Every fall I change the fuel and oil filters, spark plugs, and lower unit oil and look for anything else that needs attention.
The 40's seem happy!
Carpy
westward
C-Dory Year: 1985
Vessel Name: TBD
Photos: Steady Eddy
PostPosted: Sun Aug 10, 2014 12:08 am    Post subject: Reply with quote
Be sure to use marine oil, which encapsulates water. Non-marine engine oils allow water to separate. Mike
BrentB
City/Region: Greenwood
Photos: BrentB
PostPosted: Sun Aug 10, 2014 3:10 pm    Post subject: Reply with quote
I was under the impression the difference was due to additives
from
http://www.carbibles.com/engineoil_bible.html
Brent Barrett
BrentB
Photos: BrentB
PostPosted: Sun Aug 10, 2014 3:44 pm    Post subject: Reply with quote
Marine oil spec sheet is located
at
http://www.nmma.org/assets/cabinets/Cabinet456/FC-W%20Combined%20Certification%20Procedure%20Manual%20%289%2006%29%20%282%29.pdf
other interesting info
at
http://www.nmma.org/certification/certification/oil/fc-w.aspx
Interesting NMMA does not address the plethora of fuel additives but I am biased and see all of the hype
PostPosted: Sun Aug 10, 2014 5:59 pm    Post subject: Reply with quote
IMHO, it's like crossing a flooded road, "IF IN DOUBT, CHANGE IT OUT", the price of a filter is insignificant wrt a big engine service! Mr. Green
On edit: Gee whiz Jack, you recently thought you ran out of fuel because you weren't sure how much your tank held or how much was in them... Cry Spend a few bucks! Rolling Eyes
Sorry if it seems as if I'm picking on you, not trying to! Embarassed
Page generation time: 0.0413s (PHP: 64% - SQL: 36%) - SQL queries: 21 - GZIP disabled - Debug on
