spike in water pressure
DuckDogTitus
City/Region: Gig Harbor
C-Dory Year: 1988
Vessel Name: C-Miner
Photos: Hemingway
PostPosted: Mon Jul 21, 2014 11:58 am    Post subject: spike in water pressure Reply with quote
what would cause a sudden spike in water psi? the motor is a 90hp merc. while cruising from Blakely to FH suddenly the alarm went off and PSI spiked to 15+psi. I shut everything down and switched to kicker while I could inspect. the motor never overheated and I couldn't find any problems. a gave it a few moments, fired it back up and the problem did not repeat.
I did some reading on poppets being stuck open or closed, but I'm not really familiar with what the poppet is in the first place.
Dustin
potter water
City/Region: Logan
C-Dory Year: 1997
C-Dory Model: R-21 Tug
Vessel Name: Poopsy
Photos: Still C-razy
PostPosted: Mon Jul 21, 2014 1:17 pm    Post subject: Reply with quote
Hmmm. I didn't know that merc's had a water pressure sensor or display. What year is the motor? I owned a 1999 merc, and it had nothing like that. I don't even know why water pressure...in the cooling circuit I presume...would even be sensed or displayed somewhere.
Testosterone Tales-Amazon.com
KG7RC
Aurelia
Photos: Aurelia
PostPosted: Mon Jul 21, 2014 1:20 pm    Post subject: Reply with quote
Sounds like temporary cooling water blockage if the PSI is for water. Nice to have such a gauge when normally you just get an overheat alarm a few minutes later.
Greg
Greg, Cindie & Aven
Gig Harbor
Ari - 19 Cruiser sold 2023
DuckDogTitus
C-Dory Year: 1988
Photos: Hemingway
PostPosted: Mon Jul 21, 2014 1:24 pm    Post subject: Reply with quote
its a 2005 model 90ELPTSW4.
I got the alarm one other time when I realized we went through a nasty kelpy area in rip coming out of bellingham last year. It was the first time I had heard such a thing so I shut everything down and investigated, the motor was wrapped in seaweed. I cleaned it and we were underway again. i did not however notice any difference in PSI (that time) but didn't look. I was concerned about heat.
this time, when i shut everything down I raised the motor and did find a bunch of kelp came off, so the possibility is the same. but what's odd to me is I thought that psi would more likely DROP if there was a clog from vegetation... not increase.
either way everything seems to be fine and I ended up boating another 30-40 miles after that with no weird instances in heat or psi....
DuckDogTitus
C-Dory Year: 1988
Photos: Hemingway
PostPosted: Mon Jul 21, 2014 1:26 pm    Post subject: Reply with quote
I just wanted to see if there was anything to be concerned about. I'm planning on taking the wife to Sucia and West Beach in a couple weeks and I want to make sure everything is in tip top shape. the drive alone is about 2-3hrs for us just to the launch, so its a trip.
Bill K
City/Region: Toledo
State or Province: OH
Vessel Name: NIC'L PIC'L
Photos: NIC'L PIC'L
PostPosted: Mon Jul 21, 2014 3:58 pm    Post subject: Reply with quote
I have a water pressure gauge on my 90 Honda and it tells me my water pump is working ok.
I would take a piece of weed eater cord and feed it into water tell tail outlet the next time you get a pressure spike.
Something plugging the outlet is the only reason I can think of for the pressure to spike.
Bill Kelleher
KA8BFT
redbaronace
City/Region: Puget Sound
Photos: redbaronace (Name TBD)
PostPosted: Mon Jul 21, 2014 4:16 pm    Post subject: Reply with quote
I hope you do not need to fill your tanks while at West Beach. My brother in law got gas there this weekend because it is non-ethanol fuel. He only put around 12 gallons though when he saw that it was priced at $5.69 per gallon. Yiiikes!!!
PostPosted: Mon Jul 21, 2014 4:21 pm    Post subject: Reply with quote
Most likely a little piece of debris-as when you went thru the kelp bed. It is also nice to have an IR thermometer on board--that way you can check a number of areas on the accessible parts of the engines--and see if there is localized heating.
95% chance this is OK--and it is not worth looking for that other 5% since it cleared up in short order.
DuckDogTitus
C-Dory Year: 1988
Photos: Hemingway
PostPosted: Mon Jul 21, 2014 5:50 pm    Post subject: Reply with quote
interesting, thanks for the feedback guys. I really thought that a clog would have caused the opposite reaction and a drop in pressure.
and in regards to the fuel prices... yes I'll probably top off before we go, but even on Blakely the fuel was about the same-ish. $5.30 or $5.39 if I recall correctly...
digger
City/Region: Spokane
Vessel Name: C-Sik
Photos: Snoopy-C
PostPosted: Mon Jul 21, 2014 9:39 pm    Post subject: Reply with quote
The kelp could have sent debris through the intake, slightly plugging the discharge pee hole, while also starving new water from entering the engine. That is why I installed the pressure gage to alert a person prior to an alarm...however, usually you only see the pressure change after you hear the alarm and start looking for the problem. I try to look at the gage when I know I went through some debris -- usually, a pressure drop indicates a plug. Most of the boat shops I spoke to wondered why I would want a pressure gage -- that is the reason. Also, sometimes getting debris off the prop is as simple as putting the engine in reverse and giving it a little throttle.
Page generation time: 0.0371s (PHP: 62% - SQL: 38%) - SQL queries: 23 - GZIP disabled - Debug on
