Bowline cleat location
blackfish
City/Region: saltair
Vessel Name: raincoast
Photos: Raincoast
PostPosted: Wed Jul 02, 2014 4:52 pm    Post subject: Bowline cleat location Reply with quote
Hello all
On the advice of some of the great cbrats I met at the pender harbour gathering. I've purchased a couple of Lewmar Composite Cleats
For securing the bowline in the cockpit.
where exactly to put them I'm not sure Crook
Any advice on a final location would be appreciated.
Or better yet a picture
Thanks Dave
lloyds
City/Region: sublimity
Vessel Name: undecided
PostPosted: Wed Jul 02, 2014 7:23 pm    Post subject: Reply with quote
I put mine behind the bulkhead about 4". Works for me.
PostPosted: Wed Jul 02, 2014 8:11 pm    Post subject: Re: Bowline cleat location Reply with quote
blackfish wrote:
Hello all
Thanks Dave
Dave- Your 2004 gunnel is probably a little different than my 1987, but you can see where I put mine to be up out of the way and stay out of the drainage pattern in the photo below.
More importantly, just alongside the end of the cabin is 1) easy to reach and not in the way of getting into and out of the boat, and, 2) as well as not being in the way during fishing.
Some considerations to think about. Good Luck!
Casey
City/Region: The Villages(FL)
Vessel Name: "Dessert 1st"
Photos: Dessert 1st
PostPosted: Wed Jul 02, 2014 11:26 pm    Post subject: Reply with quote
We like to keep 'fixed lines (bow and stern) on both port and starboard. To keep things orderly we use a Harken "cam cleat" for line handling. Having the lines already in place makes line handling very easy when you dock.
http://www.westmarine.com/buy/harken--cam-matic-aluminum-harken-150-cam-cleat--114652/zoomImages
Best,
Casey&Mary
colobear
City/Region: Denver
Photos: C-Cakes
PostPosted: Thu Jul 03, 2014 12:25 am    Post subject: Reply with quote
We have the cam cleats as well and find them extremely handy and easy to use. Speaking frankly, and with the best of intentions, just about every time we see someone hurriedly untying their docklines when approaching the dock it seems a lot of effort and often, needless drama. Our camcleats are on the sides of the cabin just above cleat shown by Seawolf Joe. We did install a full size cleat on each side of the "walkaround about 6inches forward of Joe's cleat. We did that in order to have a midships cleat for springing. It too has been very handy
Patti and Barry
formerly C-Cakes, now
rving around N. America
hambone
PostPosted: Mon Jul 07, 2014 11:46 am    Post subject: Reply with quote
Best,
Casey&Mary
I have used my Cam cleats now for two years and love them. Great invention.
Hawg Hunter Productions.
Chester
City/Region: home
Photos: Chester
PostPosted: Mon Jul 07, 2014 2:17 pm    Post subject: Reply with quote
I mounted cleats vertically on the forward, inside edge of the cockpit coaming. Look at Sea wolf's photo and notice where the dock line falls. Right there.
I used dock lines which can't reach the props should one of them come loose. 15' I think.
rjmcnabb
City/Region: Pender Island (Southern Gulf Islands)
Vessel Name: Luna
PostPosted: Mon Jul 07, 2014 10:03 pm    Post subject: Reply with quote
Hi Blackfish,
I decided against cleats for this purpose; to be big enough I thought them intrusive. I keep both sides rigged the same way, and use whichever side is necessary (usually starboard, and I like to back in.) Both bow and stern lines are the same length (about 2/3 of boat,) and I tie their ends together with a double sheet-bend. You can place the knot as you like to control what falls into the cockpit, but it stays neatly against the coaming, especially if you lay it inside the midship cleat. It almost never gets wet, is too short to reach the prop, and when you step onto a dock you take control of both bow and stern. I leave the midship breast-line tucked inside the window, and that is usually what I tie off first. The double sheet-bend is easy to tie, easier to release, and extremely secure, even flogging in the water.
(An extra bonus: no drilled holes!)
Rod
Rod & Jane; Victoria 18 sloop (Vickie) - gone; Islander 26 Bahama sloop (Callisto) - gone; WW Potter 19 sloop (Spring) - gone; Com-Pac 16 sloop (Bummer II) - gone; Nimble 24 yawl (Chatelaine) - gone; Nimble Vagabond cruiser (Loligo) - gone; C-Dory 22 Cruiser (NoddyBleu) - gone; Com-Pac 19 sloop ('Winkle) - gone; San Juan 24 sloop (Loligo^2) - gone; C-Dory 16 cruiser (Luna); Catalina Capri 18 sloop (Later)
Page generation time: 0.0364s (PHP: 64% - SQL: 36%) - SQL queries: 21 - GZIP disabled - Debug on
