PDF Manual for Victron BMV-600 Series
Post new topic   Reply to topic    The C-Brats Forum Index -> Documents
jkidd
City/Region: Northern, Utah
Vessel Name: Voyager
Photos: Voyager (JK)
PostPosted: Mon Jun 09, 2014 9:07 am    Post subject: PDF Manual for Victron BMV-600 Series Reply with quote
This is the manual for the Victron Battery monitor.
Manual-BMV-600S-600HS-602S-EN-NL-FR-DE-ES-IT-PT-SE.pdf
 Description:
Download
 Filename:  Manual-BMV-600S-600HS-602S-EN-NL-FR-DE-ES-IT-PT-SE.pdf
 Filesize:  808.97 KB
 Downloaded:  7118 Time(s)
Jody Kidd
KE7WNG
Northern, Utah
Bill K
City/Region: Toledo
State or Province: OH
Vessel Name: NIC'L PIC'L
Photos: NIC'L PIC'L
PostPosted: Mon Jun 09, 2014 10:49 am    Post subject: Reply with quote
Thank You, it is good to have both kinds of manuals.
Bill Kelleher
KA8BFT
PostPosted: Mon Jun 09, 2014 1:39 pm    Post subject: Reply with quote
Just a note that Victron has now come out with the 700-series battery monitors. I believe these have replaced the 600-series, so anyone buying one now will likely be getting a 700-series unit. I did a bit of reading around the time they were switching over, as I bought a second monitor (for the RV; already have a 600 in the boat) just about that time. From what gleaned, anyone who has the 600 series can convert to the 700 by just getting the new gauge (face); the rest of the system remains compatible (shunt, wiring, etc.).
Here is a link to the manual for the 700-series monitors:
http://www.victronenergy.com/upload/documents/Manual%20-%20BMV%20-%20700%20700H%20702%20-%20%20EN%20NL%20FR%20DE%20ES%20SE%20PT%20IT.pdf
I decided the (clearance-priced) 600 would suit my needs (hey, it's only the RV, not the boat Very Happy), but some of the changes are these:
1) During setup you get scrolling text describing parameters in regular words, vs. "H-1" or something like that where you have to look up what that is.
2) Readout now has "watts" in addition to the other values.
3) There is a SOC "gas gauge" bar always on screen (i.e. when you are looking at values other than SOC).
4) New history value: Total kwh charged and discharged.
5) The "02" model (702) has a choice of three things to measure on the second bank, vs. just voltage (now one of two voltage readings or battery temperature, which requires optional temp sensor attachment).
6) Interface with Victron Remote via Internet (I didn't really seek to understand this function).
Here is a blog post that covers it all in greater detail:
http://www.victronenergy.com/blog/2014/01/12/bmv-702-insights/#more-165
Seems like a great deal since they are only about $15 than the (non-clearance-priced) 600's were (they say same price, but I see them at about $164 and the 600 when it was current was around $149; still seems like a great deal to me for what it gives you).
PS: I see that the 600 manual was somehow uploaded as an always-available-here .pdf. Let me see if I can figure out how to do that for this manual.
Edit: Okay, I tried using the "Add an Attachment" function below, but it came back with a message of something like "Sorry but you have already used your 5mb upload quota." Maybe I'll try again later. Meantime, there is the link above.
jkidd
PostPosted: Mon Jun 09, 2014 3:26 pm    Post subject: Reply with quote
Sunbeam just attach the PDF in the document forum and it should work.
PostPosted: Mon Jun 09, 2014 3:36 pm    Post subject: Reply with quote
I think the problem is that it is 8.6 mb (the limit seems to be 5mb for an upload to this forum). I'll see if I can reduce it and try again.
Okay, I think I have saved just the English language portion, which is a smaller file (the link in my post above should still go to the multi-language original).
Manual-BMV-700-700H-702-EN.pdf
 Description:
Manual for Victron BMV 700 Series battery monitors (with all languages except English excised).
Download
 Filename:  Manual-BMV-700-700H-702-EN.pdf
 Filesize:  876.38 KB
 Downloaded:  1333 Time(s)
PostPosted: Mon Jun 09, 2014 5:42 pm    Post subject: Reply with quote
I just installed the Victron 700, bought it from Microtech in Ferndale, WA, just a few miles away, $158, and the guy made me several more short cables, a black one to go from the battery to the shunt, and red and black jumpers to wire the two house batteries in parallel. The only setup I had to do was to tell the Victron the amp hours instead of its default, which is 200 (see other thread, I think my two batteries have 133 amp hours). Did I miss some necessary setup step?
jkidd
PostPosted: Mon Jun 09, 2014 6:34 pm    Post subject: Reply with quote
Looks good Pat you can test it by running the battery down a little and comparing it to a state of discharge chart http://modernsurvivalblog.com/alternative-energy/battery-state-of-charge-chart/
Then adjust Cb by what ever percent of error you have.
Post new topic   Reply to topic    The C-Brats Forum Index -> Documents All times are GMT - 5 Hours
Page generation time: 0.0451s (PHP: 71% - SQL: 29%) - SQL queries: 22 - GZIP disabled - Debug on
