Changing Lettering on Used Hull
Rob & Karen
City/Region: Franklin
State or Province: TN
Vessel Name: Life of Riley
Photos: Life of Riley
PostPosted: Tue May 28, 2019 2:07 pm    Post subject: Changing Lettering on Used Hull Reply with quote
We have changed the registration numbers on a used hull and find that the old lettering is still visible in the fiberglass. The glass appears whiter where the old numbers used to be. We have already applied the new numbers but are not real happy with the finished look. Is there a way to remove the shadow of the old numbers from the glass? Hoping to work this our before tackling the larger boat name graphics. Thanks.
Rob & Karen
PostPosted: Tue May 28, 2019 2:43 pm    Post subject: Reply with quote
1. Rubbing compound and a good buffer. Wax it after you apply the new numbers.
2. If that didn’t work, wet sandpaper (1500 and up) with water. Use a rubber block and keep it wet. Light pressure for short periods.
I removed pinstripes and the gel coat had yellowed. The compound worked for me.
http://www.c-brats.com/modules.php?set_albumName=pin-stripe-removal&op=modload&name=gallery&file=index&include=view_album.php
PostPosted: Tue May 28, 2019 4:12 pm    Post subject: Reply with quote
What mark said.
The easier way is to remove the old numbers, and then compound and buff the whole area and then put on the new numbers but hind sights is always 20/20.
Alan
City/Region: Endicott
State or Province: NY
Vessel Name: Katyusha
PostPosted: Tue May 28, 2019 4:14 pm    Post subject: Reply with quote
The problem is that the gel coat around the letters is faded, and the gel coat under the letters is not. Accordingly, it is virtually impossible to eliminate the shadowing.
If you are registering your boat in the same state that you bought it, you may be able to get the old registeration number from your DMV. (Really)
Good luck!
Boatless in Endicott
PostPosted: Tue May 28, 2019 9:06 pm    Post subject: Reply with quote
Alan wrote:
... If you are registering your boat in the same state that you bought it, you may be able to get the old registeration number from your DMV. (Really)...
In my state once a boat has a registration number that number stays with the boat when ownership transfers. So you don't have this issue with the numbers. Still occurs with names and other markings though.
PostPosted: Tue May 28, 2019 11:08 pm    Post subject: Reply with quote
The compound, polish and wax is certainly the way to go. However, the ghost will fade with time. It is always at its worse when you first remove. the old letters/numbers.
Page generation time: 0.0624s (PHP: 42% - SQL: 58%) - SQL queries: 20 - GZIP disabled - Debug on
