90hp Suzuki shuts down at idle
mdoug
City/Region: Meredith
State or Province: NH
Vessel Name: Mikey
PostPosted: Fri May 23, 2014 4:58 am    Post subject: 90hp Suzuki shuts down at idle Reply with quote
My 90hp Suzuki is shutting down when idling after we run it to the marina from Bear Island. Makes docking a challenge. Marina mechanic can't seem to fix the problem. Also, he reports gas in oil. This is a 2005 model with many hours.
Anyone have a clue?
Mikey
katkt
C-Dory Model: 24 Tomcat
Vessel Name: Katie Kat
Photos: Katie Kat
PostPosted: Fri May 23, 2014 8:30 am    Post subject: Reply with quote
Carbed or fuel injected?
PostPosted: Fri May 23, 2014 11:05 am    Post subject: Reply with quote
If its not the low idle adjustment then may be a leak in the auto choke vacuum line? Just guessing but that is where I would start.
Jazzmanic
Photos: C-Dancer
PostPosted: Fri May 23, 2014 12:33 pm    Post subject: Reply with quote
mdoug,
I hope you're not experiencing the infamous Suzuki corrosion problems experienced by many Suzuki motor owners of that vintage. That's one of the symptoms.
Has your boat been moored in the water or dry stored? Check out this thread:
Suzuki Corrosion
Peter & Caryn
Email: pjamero@gmail.com
mdoug
Vessel Name: Mikey
PostPosted: Fri May 23, 2014 3:28 pm    Post subject: 90hp suzuki Reply with quote
fuel injected
mdoug
Vessel Name: Mikey
PostPosted: Fri May 23, 2014 3:29 pm    Post subject: 90hp Suzuki Reply with quote
Thanks!
mdoug
Vessel Name: Mikey
Jazzmanic wrote:
mdoug,
Suzuki Corrosion
Nope
mdoug
Vessel Name: Mikey
PostPosted: Fri May 23, 2014 3:32 pm    Post subject: 90hp Suzuki, 2005 vintage Reply with quote
Lots of bad reports online about this vintage suzy. My mechanic is baffled. I plan to buy a new engine.
digger
City/Region: Spokane
Vessel Name: C-Sik
Photos: Snoopy-C
PostPosted: Fri May 23, 2014 4:32 pm    Post subject: Reply with quote
If 1 of the fuel pumps is driven by the camshaft, a ruptured diaphragm can leak fuel into the crankcase via the valve train area. That could explain the gas in the oil.
BrentB
City/Region: Greenwood
State or Province: IN
Photos: BrentB
PostPosted: Fri May 23, 2014 5:21 pm    Post subject: Reply with quote
Has it been scanned with diagnostic software?
Maybe just a bad sensor
Brent Barrett
rogerar
City/Region: SW FL
Vessel Name: Duck
Photos: Duck
PostPosted: Sat May 24, 2014 6:02 am    Post subject: Reply with quote
Idle speed is controlled by the IAC (Idle Air Control). It is electronic and must be diagnosed by plugging the motor into a computer w/ SDS(Suzuki Diagnostic Software). Are you getting any trouble codes?
If its leaking exhaust from corrosion, you should get 1 or more trouble codes from the engine.
mdoug
Vessel Name: Mikey
PostPosted: Sat May 24, 2014 6:05 pm    Post subject: Reply with quote
Thanks
mdoug
Vessel Name: Mikey
PostPosted: Sat May 24, 2014 6:07 pm    Post subject: Reply with quote
Yep. Marina ran all diagnostics, found only a timing issue that may be a false alarm,
mdoug
Vessel Name: Mikey
PostPosted: Sat May 24, 2014 6:09 pm    Post subject: Reply with quote
Nothing other than a possible timing issue. Marina returned Mikey to me running ok yesterday, So far, so good.
Thanks to all for the help!
BrentB
Photos: BrentB
PostPosted: Sat May 24, 2014 9:33 pm    Post subject: Reply with quote
thanks
Any explanation on gas in the oil?
How old are the thermostats?
The IAC can be removed and cleaned with throttle body cleaner and a few Q tips
Page generation time: 0.063s (PHP: 51% - SQL: 49%) - SQL queries: 32 - GZIP disabled - Debug on
