Overheating alarm question
cdory25
City/Region: Flagler Beach
Vessel Name: Shoal Mates
Photos: Blues Cruiser
PostPosted: Tue Feb 18, 2014 8:18 pm    Post subject: Overheating alarm question Reply with quote
I'm hoping this has happened to someone else so they can help me figure this out. As I prepare for a lengthy journey traveling 100+ miles south on the St. Johns river to the St. Johns River gathering in a week, I remembered a problem I have had since I've owned Blues Cruiser.
After cruising above 4k rpm for a while (sometimes you just gotta get somewhere) the hot engine alarm comes on (light next to the key) making an awful, annoying and loud noise (beep, beep, beep...) The only way to stop it is to turn off the motor and wait 5 minutes or more.
The motor (Honda 135) doesn't appear overly hot and the 'pee hole' is clear and flowing normally. The motor has 500+ hours on it and was serviced last summer including a new water pump impeller. I could disconnect the alarm but don't want to risk damage to the Honda. Any ideas? I don't have time to take it in for a repair and still do the float next weekend.
Thanks!
BrentB
City/Region: Greenwood
State or Province: IN
Photos: BrentB
PostPosted: Tue Feb 18, 2014 8:41 pm    Post subject: Reply with quote
How many thermostats does it have and when were they last replaced? I am thinking it is the thermostats or a sensor
m2cw
Brent Barrett
T.R. Bauer
City/Region: Wasilla
Vessel Name: C-Whisperer
PostPosted: Tue Feb 18, 2014 8:59 pm    Post subject: Reply with quote
I think your motor could be having a sensor issue. Normally when and if they really do overheat you know it. But, I'm not sure that when the alarm goes off the temperature is actually high enough to call it a real overheating condition - just getting close. Checking the thermostat never hurts either and it could be partially stuck closed.
cdory25
PostPosted: Tue Feb 18, 2014 9:00 pm    Post subject: Reply with quote
Possibly. That's what I'm hoping a knowledgeable C-Brat can tell me.
BrentB
Photos: BrentB
PostPosted: Tue Feb 18, 2014 9:06 pm    Post subject: Reply with quote
I bought Yamaha Diagnostic Software and cables to pull codes from the ECM. Has anyone scanned it for codes?
DaveS
City/Region: Arlington
Vessel Name: Sea Shift
Photos: Sea Shift
PostPosted: Tue Feb 18, 2014 9:07 pm    Post subject: Reply with quote
I vote Thermostat. I keep a spare on board and it only takes 15 minutes to change it out. Laughing
Dave S.
"Sea Shift"
C-Brat #16
cdory25
PostPosted: Tue Feb 18, 2014 10:20 pm    Post subject: Reply with quote
DaveS wrote:
I vote Thermostat. I keep a spare on board and it only takes 15 minutes to change it out. :lol:
I like it! Did you have similar symptoms?
PostPosted: Tue Feb 18, 2014 10:35 pm    Post subject: Reply with quote
Most likely a Thermostat, but also there may be salt build up. Do you always rinse the motor with fresh water after each salt water use? I would not ignore the alarm. Also a IR therometer should be part of the kit, to check the temps.
cdory25
PostPosted: Tue Feb 18, 2014 11:17 pm    Post subject: Reply with quote
Most likely a Thermostat, but also there may be salt build up. Do you always rinse the motor with fresh water after each salt water use? Also a IR therometer should be part of the kit, to check the temps.
ALWAYS rinse after using. What's an IR thermometer?
Thanks!
texasair
City/Region: Cypress, Texas
State or Province: TX
Vessel Name: Bixby's Cub
Photos: Bixbys Cub
PostPosted: Tue Feb 18, 2014 11:44 pm    Post subject: Reply with quote
May not be the motor. I had an intermittent hard to find overheating alarm.
Turns out it was not the motor at all. Problem was in the controls located in the shifter and throttle.
DaveS
Photos: Sea Shift
PostPosted: Wed Feb 19, 2014 2:23 am    Post subject: Reply with quote
I have had on two occasions. The first time I didn't have a replacement thermostat with me, so would motor along on my twin engine until the overheated one cooled down, then would run it until the alarm sounded again and shut it down again. The second time I had a replacement thermostat and changed it out when I arrived at the destination of my overnight trip.
FYI, when I arrive home after cruising, I faithfully flush my engines with salt away.
DaveS
Photos: Sea Shift
PostPosted: Wed Feb 19, 2014 2:27 am    Post subject: Reply with quote
Thanks!
InfraRed Thermometer. Handy to have. Another good use for them is to check your trailer hub temperatures.
cdory25
PostPosted: Wed Feb 19, 2014 9:43 am    Post subject: Reply with quote
Can you use an OBD II scanner?
This happened once a long time ago and a friend cleaned out the 'pee hole' and that seemed to fix it for a while but it has done it a couple times in the last year. That's it though, only about 5 times in the last 1000 hours. It's just decided to act up right before a planned adventure next weekend. I had it serviced last summer and they changed the impeller and said no codes.
Oh and the gas gauge has suddenly stopped working, probably because I didn't have a full tank last time it was stored.
Lacking an IR thermometer I guess it wouldn't hurt to change out the thermostat. What tools do I need and where would you suggest I procure said thermostat(s) in a timely matter. What temp? Internet or Dealer?
Thanks!
BrentB
Photos: BrentB
PostPosted: Wed Feb 19, 2014 11:38 am    Post subject: Reply with quote
Here is a kit
http://www.brpdiagnostics.com/honda-dr-h-outboard-diagnostic/
There may be others but you can search the web for them
I would invest in a set of Honda factory manuals, too
m2cw is replace all thermostats first
I would suscept a loose connection at the meter or tank , blown fuse or a bad ground
I purchase parts locally and on the net
Boats.net and BOE at http://www.boemarine.com/categories/honda-engines-gens-pumps/outboard-parts.html
sale Honda parts (both have online diagrams) but I would contact a local dealer first for a couple reasons....... they work on the OBs on a regular basis thus knowledgable and they have sevice or tech bulletins which are invaluable sources of information but I dont access to them .. second I am not a master mechanic sometimes it is money well spent to have a pro perform the work ....folks like Marc at Wefings, Les Lampman, Matt Gurnsey at Kitsap are on the list and freely provide keen insights and good service with peace of mind
best
cdory25
PostPosted: Wed Feb 19, 2014 12:59 pm    Post subject: Reply with quote
I talked to the BJ at First Coast Marine in St. Augustine and he thinks that replacing the thermostats, that's right, there's two of them, at $70 is the cheapest fix and I should be able to DIY. If that doesn't fix it then it would pretty much have to be the sensor. They will be in Monday so thanks to all for your help! Maybe I'll try a wax thermometer after to be safe...St. Johns gathering next weekend!
Thanks!
Page generation time: 0.0853s (PHP: 46% - SQL: 54%) - SQL queries: 33 - GZIP disabled - Debug on
