Kelly & Brian
Joined: 07 Mar 2014 Posts: 5 City/Region: Springfield
Vessel Name: Kelly Lynn
Photos: Kelly Lynn
Posted: Tue Mar 18, 2014 1:18 pm Post subject: 2007 C-Dory 22 Cruiser: Springfield, MA $44,499.00 |
2007 C-Dory Cruiser in EXCELLENT condition. Great Cruiser in all weather! This cruiser has been garage kept, never docked, fresh water use, never fished from, never bottom painted with a LONG aluminum dual axle trailer (newer tires). Powered by a 2007 75HP Honda four-stroke gas sipper with 292 hours.
Description: V-Berth, Pilot seats(port seat reversible/faces the rear or forward facing), dinette converts into a 6'2" berth, privacy curtain in berth, Side sliding windows and opening center window, Bomar hatch forward. Equipment: Lenco Trim Tabs, Norcold DC refrigerator, Xantrex 1000 watt inverter, Guest dual battery charger (20amp), Shore Power (30amp), Garmin 548 Chartplotter/depth finder & water temp., Lowrance VHF radio, Pyle stereo system, storage under berth, Sink (20 gallon holding tank), Kenyon butane stove top. Pump out toilet (5 gallon holding tank), Dri-Dek, Bimini, Dual Batteries, Swim platform, windshield wipers, anchor tensioner, Coast Guard package, dock lines, fenders. You will not find a better one out there, taken care of meticulously. Great boat for all weather.
413-519-1125
Email: Jupiler13@hotmail.com
You can see more pictures in the C-Dory photo gallery, page 15 4th row.
This boat looks like it just came from the factory. You will not be disappointed.
Reason for selling it: My wife is going to spend the summer in FL and I will be traveling to and from FL because of work reasons. No time to use it and it would be a shame /selfish to let it sit.
Brian Bujnicki |
Kelly & Brian
Photos: Kelly Lynn
Posted: Mon Apr 07, 2014 4:00 pm Post subject: |
2007 C-Dory 22' Cruiser; 2007 C-Dory Cruiser in EXCELLENT condition. Great Cruiser in all weather!
This cruiser has been garage kept, never docked, fresh water use, never fished from, never bottom painted with a LONG aluminum dual axle trailer with spare (newer tires). Powered by a 2007-75HP Honda four-stroke gas sipper with 292 hours.
Cockpit:
46 long x 59 wide.
Comfortably fits up to 4 people.
Cabin:
Includes sleeping area and pilots station.
Dinette located along port side of cabin converts into 62 berth.
Pilot station and galley located on starboard side includes:
− Butane stovetop.
− Stainless steel sink.
− 18 gallon water supply with foot pump.
Forward section of cabin features a 63 V berth that is separated from the main cabin by a privacy curtain and includes two reading lights, portable pump out toilet, and Bomar 22 aluminum frame hatch with tinted lens.
Cabinetry composed of fiberglass with 3/4 decraguard marine grade plywood doors with teak wood trim.
Construction:
Fiberglass hull, decks, cabinetry and pilothouse are laid with the use of balsa core composite construction. The use of cored sandwich construction in the bottom, decks and bulkheads, in combination with the deeply molded plank lines, give the boat incredible strength and stiffness.
All color accents and top deck non-skid patterns are molded-in.
Hardware:
Diamond Sea Glaze windows with aluminum frames that are powder coated to match the color of the boat. Sliding side windows with screens and standard center opening window.
All deck hardware is stainless steel and through bolted. Top deck is 3/4 thick.
Deck hardware includes five through bolted SS cleats.
Non-Skid:
The top decks non-skid is molded in diamond pattern and the cockpit sole is coated in a gelcoat.
Performance Notes:
Two 23 gallon fuel tanks located under motor well (approximate range of 250 miles).
Boat will plane comfortably at a low speed of 9-10 MPH
Equipment:
Lenco Trim Tabs with LED indicator
Ritchie Compass
Shore Power (30amp)
Garmin 548 Chartplotter/depth finder & and water temp
Lowrance VHF radio
Pyle stereo system with four speakers total 2 speakers in pilothouse and 2 speakers on deck
Storage under berth
Kenyon butane stove top Pump out toilet (5 gallon holding tank)
Dri-Dek
Bimini Dual Batteries with switch
Swim platform with ladder
AFI windshield wipers
Anchor tensioner
Coast Guard package
Dock lines (2)
Fenders with fender covers
(2) Anchors
(3) Propellers-Two aluminum and One Stainless 4 blade.
You will not find a better one out there, taken care of meticulously. |
Kelly & Brian
Photos: Kelly Lynn
Posted: Tue May 13, 2014 7:49 pm Post subject: |
The Kelly Lynn has been SOLD thank you. |
